Question about Honeywell Water Heaters
Manual for honeywell natural gas valve. Vr8204c 1084
    Problem Solver:
  • 14 Answers
Google for "Vr8204c 1084 manual" ... 1st item says:
http://www.warming-trends.com/manuals/HoneywellTroubleshootingGuide.pdf
68-0047 - VR8204; VR4204 Intermittent Pilot Dual Automatic Valve Combination Gas Controls
Pretty much chapter and verse - you don't usually get any more.XV66OI
This is an industrial valve. Are you safe to meddle with it?
Posted on Jan 03, 2017
How do I convert my rheem water heater from lp to natural gas model#21vp40-1p
Call Rheem
Generally the company does not support changing type of gas since propane burns much hotter and has more pressure than natural gas.
You need different gas control valve, and need cast iron burner and orifice than matches that specific gas control valve.
http://waterheatertimer.org/images/IMG_1826-LP-burner-450.jpg
http://waterheatertimer.org/Water-heater-manufacturers.html
Gene
Sep 14, 2014 | Water Heaters
Gas valve faultdetected
Copy following link to troubleshoot by type of gas control valve, and read how to replace gas control:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
There are basically two types of Honeywell gas control valves.
One for atmospheric-vented water heater, and one for power-vented
For both types of controls: 8 flash + 3 flash error: replace gas control valve.
Water heater does not need to be drained to replace this gas control.
Apr 01, 2013 | Honeywell Water Heaters
Blinking red light
Copy following link to identify type of gas control valve, and error codes.
With honeywell atmospheric gas control, steady blinking light indicates correct operation.
Read product manual, and perform regular maintenance as outlined in product manual.
Mar 25, 2013 | Water Heaters
Pr sw failed to close
Troubleshoot by type of gas control valve
Repeated 3 flash on power vented honeywell gas control thermostat means system in lockout.
Repeated 3 flash on atmospheric-vent Honeywell gas control valve means temperature sensor failure.
Take apart gas control, and buy temperature sensor if sold separately at AO Smith dealer.
http://waterheatertimer.org/How-to-replace-Honeywell-gas-control-valve.html
Add a comment with more information
Mar 23, 2013 | Rheem 40 Gallon FVR NATGAS Low WATER...
Whirlpool 6th sense natural gas water heater 50 gal. Bought brand new today. Upon installation, discover low gas pressure running to unit. Turned out that gas line had under ground leak so had to turn...
1) Be careful before you Call Whirlpool 1-877-817-6750.
Be careful what you report so not to void warranty because installation protocol was not followed. Whirlpool will cover gas control valve, and possibly the installation of valve which takes about 15 minutes and does not require emptying water heater.
************So make sure you report installation that is consistent with installation shown in manual.
2) Whirlpool will also answer this same question later today with invitation to contact them.
3) Copy following link to identify gas control valve, and download service manual:
4) If dirt or debris gets into gas control valve, it will cause it not to work. Such as broken gas line. Debris can enter gas line.
Or if too much pipe dope was used on gas connection, or stray teflon tape got into line and then into valve, or end of pipe got dirty during installation, and then dirt got into gas control.
Take off gas line and use vacuum cleaner to see if something can be removed by suction. Clean up the joints.
5) It appears you have ordinary Honeywell gas control valve on atmospheric vented water heater with 9 year parts-labor warranty..
Unknown error code, so it is hard to look up solution in service manual.
Add a comment if you want expert to look up error code in service manual.
Feb 13, 2013 | Water Heaters
Rheem 300170 HWS service manual
1) Rheem does not post service manuals.
Call Rheem and ask why, since the other big manufacturers, AO Smith and Bradford White do post service manuals.
2) You need new propane gas control valve, and matching combustion parts to fit existing tank.
http://waterheatertimer.org/pdf/Rheem-Water-Heater-parts-catalog.pdf
3) Rheem does not recommend changing gas type, especially from natural gas to LPG.
LPG is higher pressure, and burns much hotter and requires cast iron burner, unlike the lighter-weight metal used for Natural gas burner.
The manifold tube and thermocouple must match the gas control valve, and gas-type and have correct thread for propane.
The combustion chamber and heat transfer surface can also be heavier metal for propane heaters.
Feb 08, 2013 | Water Heaters
How do l replace the electronic gas control valve on a whirlpool hot water heater tank?
Whirlpool is made by American water heater.
Gas valve is made by Honeywell.
Whirlpool electronic control is version of Honeywell 'Icon' gas valve: There are several versions of this gas valve.
http://waterheatertimer.org/pdf/Bradford-White-service-manual.pdf
Start page 24 shows: Testing, disassembly and replacement of typical Honeywell gas valve.
Whirlpool phone number 1-877-817-6750
Whirlpool manuals:
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
Aug 10, 2011 | Whirlpool Water Heaters
My Honeywell Water Heater Thermostat will turn on for 30 seconds. Then it shuts down- wait 5 seconds turn it off EITHER with the ON/OFF switch OR by turning thermostat to off & back on immediately! If...
Time to call qualified service technician. And watch what that person does to learn about your water heater.
I assume you have Honeywell Icon gas valve. Honeywell makes different several model numbers.
Here is 'typical' Honeywell Icon gas valve service manual for Bradford White, that may or may not apply to your water heater. It shows testing for Icon and disassembly instructions, and error codes.
http://waterheatertimer.org/pdf/Bradford-white-service-manual-44943-D.pdf
Gas water heaters today require yearly service that includes cleaning burner parts and combustion chamber, checking vent and air intake, electrical connections, testing gas valve, checking gas pressure, bleeding air out of gas line, etc. These are things you can learn to do by reading service manual, and making sure you have a spare water heater around to connect real quick if experiment goes wrong.
If Icon gas valve is problem, that control is modular and can be replaced without draining tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 07, 2011 | Honeywell Water Heaters
Water Heaters Logo
115 people viewed this question
Top Honeywell Water Heaters Experts
Lickzee
gbob59
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
