Question about Water Heaters
My Vaillant atmomag produces very hot water as long as water pressure is set to lowest possible & temp is turned high, but it then cuts out. Is there an automatic cut off if the heater gets too hot??
After running hot for about 10 mins it cuts off and runs completely cold. I then switch the water off and wait a short time and it then starts to run hot again. I have tried increasing the water pressure or turning the heat down further, the water is then not hot enough
5 Suggested Answers
  • 21 Answers
SOURCE: gas water heater running only cold water
Sounds like it is the pressure diaphram.This is a object that looks like a space ship or ufo undo all the screwss on the flatish side after isolating the water supply revove old diaphram & install a new one
Posted on Dec 03, 2009
  • 43501 Answers
SOURCE: Have an Atwood LP water
You have a bad thermostat/ECO.... the ECO cuts out and will keep you from relighting till it cools.
Here is a site that has parts for your heater, but you will need to know the exact model number to get the right part.
Atwood parts
Posted on May 23, 2011
  • 5245 Answers
SOURCE: I have a Paloma Whole
Open following link to identify specific gas control anddownload possible service manuals for that specific product.
Posted on May 19, 2012
  • 6 Answers
SOURCE: hi my vaillant combi gives hot water for only 15 seconds then runs cold turn the tap off, run the water again & gets hot then runs cold some told me it might be the diverter valve can any body hel
yes it is your expansion vessel it sounds under charged to me?your expansion vessel needs to be recharged to 1 bar at least,but check manufacturers instructions it could state different.if the heating is fine and your getting hot water in intervals your diverta valve is moving and working?
Posted on Dec 12, 2012
Vaillant combi boiler no hot water
Is it electric? Do You have power? Is the temperature setting on high setting?
Sep 20, 2014 | Water Heaters
I turned up the water temp on my gas water tank, and water leaked from the side I need to repalce the pressure release valve or is this normal?
Any time your pressure release valve goes off you should replace it. the t&p valve responds to the temperature and pressure its possible that the setting you chose was to hot, or its possible that the relief valve was just worn out. I would replace that and keep your temp setting between B and C. another possibility is thermal expansion, check and make sure your expansion tank is good and if you don't have one I highly recommend it.
Jun 28, 2014 | Bradford White M45036fbn 50 Gallon Natural...
Hot water pressure valve blows
it is set to go off at 210 degrees or 150 lbs turn down the temp setting if the water is very hot it is unlikely that your water pressure is that high . if it still goes off replace the valve it is also possible that the gas valve which is also a thermostat is malfunctioning and allowing the water to get to hot. if so replace.
May 05, 2014 | Rheem Water Heater Pressure Relief Valve
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
Electric wh high temp shut off button keeps resetting
Water heater has upper and lower elements. Only one t-stat. Check to see where tstat is set to. Turn down to lowest level. If breaker still resets then replace tstat. It is letting the water get to hot no matter what setting it's on. So water is getting so hot that it trips breaker.
Dec 28, 2012 | Water Heaters
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
I have a hot water heater that when running seems to build up an excessive amt of pressure. We just replaced the pressure valve because the old one started leaking when the hot water was running for any...
The most likely problem is that the thermostats are set too high. Remove the thermostat cover plates and look to see where the thermostats are set. The range should be between 120F and 135F. Liquids expand with heat so the higher the temp, the high the pressure. Decrease the setting on the thermostat until the leak stops.
The other likely cause is a head of air trapped in the top of the tank. After drawing hot water, it wiill be displaced by the incoming cold makeup water. This will compress any air in the top of the tank. As the water heats, the air will heat and pressure will build - possibly causing the leak. You can purge the tank of air by opening the pressure relief valve until water comes out (which I assume that you have already tried).
Dec 09, 2010 | Whirlpool Water Heaters
Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Oct 10, 2009 | Water Heaters
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
Water Heaters Logo
48 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
