My System Sound is not coming All driver is their and task bar icon show so after all so not coming driver Wya pleaser help me ok
  • Douglessd
    Douglessd May 11, 2010
    Have you checked in the device manager to make sure there are no devices in the "Unknown" category? Look in Control Panel -> Admin Tools -> Computer Management -> Device Manager. If your sound device is under a the Yellow then its drivers are not recognized. You need to remove the driver and reinstall the correct driver. If *********** board has a built in sound card you will need to find the drives from the mother board web site. Don't use the automatic detected ones from Microsoft. Hope this helps. Let us know how you go? :)
Hi
my desktop icon shadow is their
how to remove icon shadow ok please sol the problem
Posted on Jul 24, 2009
    Sergeant:
  • 449 Answers
This happen usually when there is a resource conflict. Check there is no resource conflict. If there is no conflict, then check if Audio is Disable from BIOS. It is also possible that Audio Cable is defective. Also uninstall the drivers, reboot PC and install the drivers again. (ehteshamhusain@yahoo.com)
Posted on Jul 23, 2009
Wintheres no volume icon on my laptop
you need to enable the volume Icon to show it at the task bar to do it,click the start icon then choose control pannel select sound and audio devices check the "place audio icon at the task bar...good luck!
Sep 30, 2011 | Microsoft Windows XP Professional
Sound is not
1) Check the task bar sound icon mute active or not (Tick mark view on mute box)
2) Sound icon not in task bar check device settings.
3) Go control panel > System > Hardware > Device manager
4) Sound, Video, game controllers view problems.
5) Re-install Sound card driver.
Mar 26, 2011 | Computers & Internet
Sound low
There are several audio settings on the system that you can increase the volume from. You have one that is by the lower part of the system, it used to be like a tuning fork, some have theirs by the top of the keyboard by the switch, while some have theirs by the side of the system.
First you need to check the audio settings from your computer, by clicking on the speaker icon that is on the task bar of the system, then you increase it from there. Or you click on the speaker icon on the task bar then click on the mixer, then you increase all the volume you will see in the mixer settings. It will show you the operating systems volume, the systems volume and other sound systems volume on the system.
After doing that, the sound of the operating system will be high.
Dec 31, 2010 | Computers & Internet
Volume speaker icon not show
The volume speaker Icon wont show usually because you have no sound drivers installed. To confirm this,
1) Go to your control panel and double click on "Sounds and Audio devices"
2) The window that appears sholu show the device volume slider active - which means the driver works fine and is installed. If this is so, click on "place volume icon in task bar".
If not, you need to install the sound drivers for your device.
(Don't forget to rate my solution)
Dec 02, 2010 | Audio Players & Recorders
IM box will not appear
The system tray (in short: systray, nowadays also called taskbar notification area) is the icon strip normally located near the right end of the task bar, next to the clock.
Some Windows XP installations show a peculiar defect in that some systray icons disappear or, rather, do not appear, when the system is booted and the user logs on. The problem is even more prevalent on systems with autologon. The most frequently affected icons seem to be the speaker icon (sound volume) and the power/energy icon.
This has nothing to do with the hide inactive icons settings. The defect shows up when you don't have any icons set for hiding.
In any case, please make sure for now that you haven't activated that setting. Right-click the task bar, click on Properties, uncheck the last check box. You can reactivate it later if all other problems are identified or solved.
Check your Startup folder and the starter registry entries through Start, Run..., type: msconfig, press Enter, to check whether the programs are really started at system start, or use Task Manager (Ctrl + Shift + Esc) to see whether the processes are running.
Jul 03, 2010 | Yahoo Messenger
I dont have volume icon in my task bar. sound r working. just icon iz not there when i ''select show icon in task bar it says that '' volume control programe not installed
Are you using WinXP?
Is so open
SETTINGS
CONTROL PANEL
SOUND AND AUDIO DEVICE
First window opens make sure the checkbox is checked that says
"Place Volumn Icon in Taskbar"
Jul 18, 2009 | Computers & Internet
I have an acer t671 tower. it recognises a speaker but the sound does not come out
your sound drivers may not be correct.
Do you have a volume icon in your task bar.
If not then go to control panel then sounds and audio device.See in there if you have the option to show icon in task bar.If the colour is faded and you can't change the options then it probably is a sound driver problem So you will need to reinstall your driver
Jan 10, 2009 | Acer Aspire™ T180 PC Desktop
Asus M2V Audio problem
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
No sound on my laptop?
Start --> Control Panel --> Sounds and Audio Devices.
Make sure it is picking up the sound card and tick the box to show the icon in the task bar.
Click apply then open the sound control from the task bar and make sure nothing is muted.
Nov 27, 2007 | Emagic EMI 6|2m External Sound System
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
