Question about Apple iPad Tablets & eReaders
Screen on my pad continually rotates and then locks for a while upside down. How can I stop it rotating?
SOURCE: Screen Rotation
you have to drop the device back to its native resolution 800x420 for the rotate function to work
Posted on Jan 09, 2008
sparkysbox
  • 61 Answers
SOURCE: screen rotate
Hello snapshots,
Here is what you do:
1) Click on a blank area of the desktop (not sure why, but sometimes this is necessary). 2) Press the toolbox button on your monitor. It is located in between the rotate screen button and the secondary "Esc" button. A tablet shortcut menu should appear in the middle of your screen. 3) Select "Settings" at the bottom left of the menu. This will open a "Customize Tablet Shortcut Menu Settings" Window. 4) In the "Auto Screen Rotation" portion of the window, make sure the "Enable ActiveRotate" box is checked.  5) If you choose, you may also want to click the "Calibrate" button. This will step you through customizing the ActiveRotate to your personal preference. 6) Click "Apply" and then "Ok".
Please note, that with the internal wi-fi connection enabled, you cannot use the X61 in tablet mode in certain orientations. Nothing bad will happen if you attempt to do this; but you will notice a message popup telling you this, as well as having the screen automatically switch orientations on you. This is normal and has something to do with the wi-fi antenna location.
Hope that helps!
Jeff
Posted on Mar 13, 2009
  • 5 Answers
SOURCE: Gateway xp tablet pc screen is upside down
Hey,
Give the CTRL + ALT + *An Arrow Key*, if not try, CTRL + *An Arrow Key*, or ALT + *An Arrow Key*.
Sorry, I just forgot which one xD.
Good Luck,
Alec
Posted on Apr 06, 2009
SOURCE: Webcam is upside down
Please download camera drivers as per Hardware ID of camera.
You can find hardware ID in device manager
Posted on May 13, 2010
Geekman
  • 32281 Answers
SOURCE: Asus Netbook - Keyboard locked on numbers
The number lock key has been pressed, press the NumLk key to turn off the number keys. There is a LED light that turns on when the NumLk key is press, just like the Caps lock key.
The upside down display is caused by unintentional pressing Ctrl-Alt plus the down arrow key.
Restore by pressing Ctrl-Alt plus the up arrow key.
ALSO
To change the display from portrait to landscape
Press Ctrl-Alt plus a left or right arrow key.
Posted on Jun 24, 2010
How to get my tablet to start rotating again. It is set to auto rotate but it won't stop working.
This varies by operating system which is why it is a good idea to post the brand, model, and operating system with a query.
For a Samsung Galaxy 10.1:
Type apps is the upper right corner. Then tap Settings from the all tab. Then in the left menu, tap screen. Then, tap auto rotate
For the Inspiron Dell 2-in-1 with Windows 10:
Go to Control Panel> Display>Change Display Settings and then make sure that the "Allow the screen to auto-rotate" is selected. Or try the following: Place the tablet into Pad/Tablet mode.
Click the Start Start menu and select Settings. Click System.
Click Display. Scroll down and toggle Lock rotation of this display to ON.
Or this might help:
Click the Start Start menu and select Settings. Scroll down and toggle Lock rotation of this display to OFF.
Nov 26, 2017 | Tablets & eReaders
How can I get the screen to rotate over to the correct position?
You might have your Orientation Lock on. If you are using iOS 7 or 8, swipe up from the bottom and disable Orientation Lock (http://cdn.osxdaily.com/wp-content/uploads/2013/10/stop-screen-rotation-orientation-lock-ios-7.jpg)
Alternately, the switch on the side of your iPad might be set to Lock Rotation, so go to Settings > General and see if Use Side Switch To: is set to Lock Rotation. This would mean that whenever the switch above the volume controls is down, the orientation is locked.
Sep 30, 2014 | Apple iPad Tablets & eReaders
My wallpaper is upside down I can't rotate my screen
Turn auto-rotation off form the multitasking menu
Sep 11, 2014 | Apple iPad 32 GB 3G Tablet PC
Acer how to setup
You are looking for an option called Rotation or Rotation Lock (varies by Android version and tablet). Once you find it, orient the tablet so it is in landscape mode, then turn off rotation. If you do not have an option on the bar at the top of the tablet (top pull-down you get by sliding down a finger from the top of the screen), then go to Settings, Display, and look for Rotation, Rotation Lock, or Screen Rotation.
Jul 17, 2014 | Acer Iconia A1-810-L888 7.9 inch MediaTek...
Why is my asus t100 lock screen upside down upon start up?
The operating system might be busy loading itself, and when you move it, that takes precedence over lower functions.
Have you waited for it to boot without moving it to see if it auto corrects?? If it does not, then you might have a problem with the sensor.
May 22, 2014 | ASUS Transformer Book T100
How do I remove volume icon from the middle of my iPad screen?
You might try this...you can set your side button on upper left corner edge of ipad to either mute volume or lock screen (stop it from rotating). Check how yours is set...Go into settings>general>Use side switch to:
see if it is set on mute. If it is switch it to Lock Rotation. Now that side switch will lock or unlock screen rotation.
See if that might stop your volume icon from popping up. Good luck!
Apr 30, 2014 | Apple iPad 64 GB 3G Tablet PC
My laptop screen is flipped upside down and i need to know how to reset my laptop!
No reset is necessary to fix this problem. Screen rotation is a typical feature on many laptops.
To rotate the display on the screen 180 degrees, simply press CTRL, ALT & down arrow on your laptop's keyboard.
Jun 14, 2011 | ASUS R1E-B1 Tablet PC
The screen stopped rotating. what can I do?
You will have to do a factory reset, which will restore the default settings on your device.
1) With the device powered off, press and hold the Volume Up and Power buttons at the same time.
2) When you see the Samsung logo, release the Power button, but continue to hold Volume Up until the recovery screen appears.
3) Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4) Press Volume Up to continue.
Mar 14, 2011 | Samsung Galaxy Tab Tablet PC
Hi. I have a problem with my fujitsu lifebook t4215. When windows is runnning and I change the notebook to tablet config, I cannot get the display/screen automatically rotated. Even when I press the Screen...
Do you have Windows 10? As there may be an issue with screen rotation.
However to check your settings:
  1. Place the tablet into Pad/Tablet mode.
  2. Click the Start menu and select Settings.
  3. Click System.
  4. Click Display.
  5. Scroll down and check the status of Lock rotation of this display .
Jan 05, 2018 | Fujitsu LifeBook T4215 Tablet PC
Rotate windows on a toughbook
Is it just that the window is upside down??
1. Try pressing Ctrl + Alt + arrow (left, right, up or down) to rotate the screen.
2.Press the hotkeys and arrow keys until you have the desired rotation. This works with most video drivers on Windows XP. If this doesn't work let us know.
Dec 09, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Tablets & eReaders Logo
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
John mullen
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
