Question about Intel D845WN (KD845WNPAK10) Motherboard
Intel desktop board display stuck problem while booting
I have Intel P4 with Intel 845DGLLY motherboard pc. When I switch on computer, it displays the Intel Desktop Board and remains stuck there.
    President:
  • 1,447 Answers
It is the problem Ram bus please change memury module then solve your problem
Posted on Jul 21, 2009
D845GVAD2 no bios screen no beep no boot
Hello here is the intel homepage:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GVAD2
Try to renew the power supply, with one you know is working.
I think that`s the problem.
The problem could ofcourse also be the mainboard itselves failing.
There is not much to do about that, other than renew the mainboard or buy a new pc.
Good luck
Apr 08, 2013 | Intel D845GVSR Motherboard
No beep codes,only flashing cursor on display. Removed ram, got beep code. Tried different processor and memory, still same, no beep, no display, no boot. Cannot access bios settings. Sounds like dead...
Sounds like a bad motherboard. To be sure, I'd remove or unplug all devices (hard drive, CD-ROM, etc) and verify. Sometimes, those devices can prevent a bootup. If you've removed all those and same thing, bad board.
May 27, 2010 | Gateway GM5442 Refurbished Intel Desktop...
I HAVE D845GLVA Motherboard. Its on board display
You have to enter the bios. (F2) during P.O.S.T. enter the setuo and usually it is under legacy options.
Jan 29, 2010 | Intel Desktop Board D845GLVA...
IntelD865GBF starts up displays Blue INtel Desktop
remove Bios battery ..and try again ...probably it doesn't see something ...but its a good sign that the Intel blue appears
Nov 08, 2009 | Intel D865GBF Motherboard
Recover BIOS d845gebv2 motherboard my motherboard does not boot.monitor displays intel desktop board in blue screen
Right after you power the computer on start tapping F2 rapidly on the keyboard until you are in the BIOS setup. When you are in the BIOS setup, check to see that the computer recognizes your boot device and that your boot order is correct. Also, if you have changed any jumpers on your mainboard; change the back.
Sep 19, 2009 | Intel D845GEBV2 Motherboard
Intel desktop board D845wN - no screen display
HI,
Switch on your computer and listen for a beeb sound.... if no beeb sound available then your Motherboard has a problem.
if beeb sound comes then switch off your computer and see for the loose contacts on motherboard.
eg. remove ram, clean ram socket and put back the ram
your problem may solved.
thanks
ehsan (md_ehsan_1@yahoo.co.in)
Jun 15, 2009 | Intel Desktop Board D845WN Motherboard
No display
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
39
Apr 09, 2008 | Intel Motherboard
Won't boot, display stuck at Intel desktop board, can't go to BIOS
I had this exact same problem, turns out i just needed to unplug a couple USB devices that were conflicting with the startup. It worked inexplicably well. If you have an external HD i'd start by unplugging that, then other accessories.
Dec 31, 2007 | Intel D845WN (KD845WNPAK10) Motherboard
Mother Board Display Problem
you did not specify clearly what display problem your having...
Is it something like there is no display, or is it something that youre having problem adjusting something on your display. Pls make it more specific..
Anyway, if there is no display as you turn on your computer.
Check if it boots up and if you hear a beeping sound.
if it boots up, then try to reconnect the graphics card that should somehow solve the problem your having.
If it still hadn't try to reconnect your video to the onboard graphics card that your motherboard has.
Dec 16, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel D845WN (KD845WNPAK10) Motherboard Logo
209 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
