Question about GPS
Roadmate p100i updates - GPS
How do i update my magellan 5045 roadmate? when
Download and install Magellan's content manager software. Your GPS unit should be recognized after installation.
http://tinyurl.com/4rmxv3t
Mar 07, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
Need an update for magellan roadmate 1200
Magellan® RoadMate® 1200 Software Update Version 1.50/3.12 - Release Notes This update applies to Magellan RoadMate 1200. It includes the following features, fixes, and improvements:
Improvements:
  • Point of interest (POI) Search Improvements reduce POI search times
  • Map Draw Improvements improve zooming, panning, and time to display the map
The software update version corresponds to your current software version:
  • If you have software version 1.46 or 1.48, your software will be updated to v1.50.
  • If you have software version 3.10, your software will be updated to v3.12.
You can locate your software version by following these steps:
  1. Start at the Main Menu.
  2. Press the arrow on the bottom right of the screen.
  3. Select "User Options"
  4. Select "System Settings"
  5. Select "Next"
  6. Select "Product Information"
  7. Your software version is on the line titled "Firmware Version"
Download Update: (Click here:)
I WANT TO DOWNLOAD THIS UPDATE
Feb 07, 2010 | Magellan Roadmate 1200 Car GPS Receiver
I need free updates for my magellan gps
if you are looking for map updates I have not been successful in transferring data from one unit to another. That requires their "process" experimentation on bypassing their updates on a older roadmate 700 series caused alot of pain.
If you need a firmware update that is available at their website
If you have a unit more than 3 years old don't waste money on updates the new roadmate 1430 or 1470 run about $150 and the 1 touch navigation is much better than the older software. There have also been MAJOR improvements in the GPS receiver and sensitivity is far superior to those units built even just two years ago.
Dec 29, 2009 | Magellan Roadmate 1200 Car GPS Receiver
I want to update my Magellan RoadMate 360. How
Usually it takes a usb cable that plugs into the device, and you have to go the manufactor webiste.
Nov 16, 2009 | Magellan RoadMate 360 GPS Receiver
I need the software that is needed to attach the Magellan RoadMate 2000 to my computer so I can update it.We lost the original software in a flash flood.
there is no special software to install, but you must hook it to a computer running windowx xp sp2 or better. it will install automatically.
you can get your update version 1.56 HERE for your RoadMate 2000
bill
Oct 24, 2009 | Magellan RoadMate 2000 GPS Receiver
Can you download an update for a magellan roadmate 1430?
Yes you can: Enter your info here http://www.magellangps.com/support/
English Manual: http://docs.google.com/viewer?url=http%3A%2F%2Fwww.magellangps.com%2Fassets%2Fmanuals%2Froadmate_1430_manual_en.pdf
Magellan® RoadMate® 1430 Software Update Version 3.12: http://www.magellangps.com/support/chooser.asp?prodid=2056&supportid=806
2009 Spring Map Update: http://www.magellangps.com/products/map.asp?tab=0&PRODID=2194
As for connecting it to the computer, you'll need the usb cable that came with it. Then you'll want to do this:
Follow these steps to connect your Magellan RoadMate to your PC.
  1. Turn ON your Magellan RoadMate.
  2. Touch "Map" to display the map screen.
  3. Connect your GPS to your PC using the USB cable.
Oct 19, 2009 | GPS
I have a Magellan Roadmate 6000t and I Love it. I
if you have the 6000 NA (north America) version, you can get a map update HERE and get the latest maps.
if you have the Europe version, go HERE
i recommend you also get the update for your unit if you haven't already.
bill
Oct 08, 2009 | Magellan RoadMate 6000T Bluetooth GPS...
Maps Updates
where can i go for updated free magellan1200 maps to update my gps
Feb 09, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Your best bet is to contact Magellan directly. Their website is not the easiest place I've ever navigated. I did not see a specific listing for the Roadmate 2000, but when I queried them about upgrades for your unit, the response was Roadmate 2000/2200T. Manuals are available, but again nothing was noted about supporting the 2000.
I've provided their phone # is below. Good luck.
800-707-9971
Feb 29, 2008 | Magellan RoadMate 2000 GPS Receiver
GPS Logo
35 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
