Question about GPS
Updae roadmate p100i - GPS
Can I charge my Magellan roadmate with USB cable connected to the computer?
It depends on the Roadmate that you have. :
- If your Roadmate has a separate plug-in port for charging your unit IN ADDITION TO a USB port, then no, your Roadmate cannot be charged using your computer via the USB cable.
- If your Roadmate only has a USB port available for charging your unit, then yes, you can charge it via your computer via USB.
However, please note, according to Magellan, charging your unit using your PC via USB can take up to 12 hours to charge vs. 4-6 hours when using the vehicle power adapter.
FYI: This is mainly due to USB constraints on pretty much all electronic devices. USB cannot carry the same amount of power to a device. It uses what is commonly known as a 'trickle' charge to recharge a device. It carries much less current than a full-blown charger (like an AC power adapter).
Apr 18, 2010 | Magellan RoadMate 1340 GPS Receiver
Magellan roadmate 800 update maps
http://www.peopleswireless.biz/magellan-rm800-traffic-kit.html
No You Will Need A traffic kit
Jul 05, 2008 | Magellan RoadMate 800 GPS Receiver
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
Can i upgrade my roadmate 1200 to include Portugal?
I also have a RoadMate 1200 and I wanted to update my map as well.
After extensive research (and periodically checking up on this every couple of months), I have found that the RoadMate series devices do not allow for any official map upgrades.
There have been reports of successful third party software installations on the RoadMate. Installing a third party software program (or "firmware") would completely change the menu on your GPS. It would be like installing Windows Vista on an iMAC. If it is possible to run an alternative firmware on the RoadMate, then it would be quite possible to download a usable map of Portugal. I have not seen any evidence of this yet. When I do I will let you know! :)
Also, an alternative firmware installation should only be done by an expert computer user. And an expert user knows that alternative firmware will void the warranty and that alternative firmware is VERY risky.
Sorry,
Steve
Jul 15, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Magellan RoadMate 700
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Power wont come on
get a new unit like any magellan mastreo series 4000 or higher or roadmate 800 or higher,i had a 700 they start having alot of problems after i did my research on here.i have the mastreo 4000 and the roadmate 800 both work great.
Feb 23, 2008 | Magellan RoadMate 700 GPS Receiver
Maps upgrade for my 360 GPS
same probelm. have unit for 2 years. Couldn't find any map updates
Dec 22, 2007 | Magellan RoadMate 360 GPS Receiver
Language on Magellan Roadmate 300
You'll have to obtain a copy of the Magellan Roadmate manager disks, load them into your computer, connect the GPS to your computer using the USB cable and the use the "Roadmate Manger settings" to change the language.
Sep 15, 2007 | Magellan RoadMate 300 GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
