Question about Food Mixers
I purchased a set of basin and bath mixers and it seems the bath mixer is missing the square base to the taps unlike the basin taps supplied with a base and washer..it looks different when fitted..why
  • Ross Keen Dec 30, 2016
    Hi sean sissons, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? This is in the Food Mixer department, not likely you'll get a plumber in here.
SOURCE: Leaking oil at the base
A TV show "How it is made" was in the Kitchen Aid factory and they used a thick grease and no oil in the mixer. Does your unit get hot? Maybe its melting the grease (dark brown)..
Posted on Oct 31, 2008
  • 4 Answers
SOURCE: looking for older Hobart logo for N50 mixer 1965
Try here: http://www.pizzamaking.com/forum/index.php/topic,8682.0.html
Ron
Posted on Jun 10, 2009
  • 143 Answers
SOURCE: My wife's kitchenaid classic 250 watt mixer wobbles on the base
It sounds like your mixer likes to take a beating, ive never dropped one and for good reason, they weigh quite a bit. first check to see if all the rubber legs on the bottom are still there. if they are the only possible solution to fix it after being bent or warped is to either re-shape the part using a tool strong enough to do the job, or to replace the parts needed. the hinge pin part number is 16910. is the base is bent the part number is 240151-1. If the lower portion of the mixer itself is bent or warped this is a serious problem and will require you to dissassemble the entire unit. part number for the lower gearcase is 240350-4 Please not that all the parts list are white in colour. hope this helps.
Thanks
Posted on Oct 12, 2009
SOURCE: How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Posted on Aug 19, 2011
e_zidlicky
  • 4 Answers
SOURCE: Replacement Bowl for the KSMO35 Stand Mixer
If you are still looking for the bowl for your mixer, I have both sizes.
Posted on Jan 31, 2015
The drive gear in my 25-30 year old kenwood chef is rounded instead of having square edges. Can I purchase this part worked great until now
extremely unlikely as manufacturers stop carrying parts after 5 years and aftermarket suppliers and service agent after 10 years
you may get gears from alibaba site but the time taken , makes junking it for a new unit a better idea
Nov 23, 2016 | Kenwood Food Mixers
How do I change the gear oil in a food service mixer sp62
About 49 results (0.77 seconds) Search Results
    [PDF]Instruction Manual for Globe Mixers - Globe Equipment ...
    https://globeequipment.com/media/product.../Sp10_Owners_Manual.pdf
    Or call the Globe service department at 937-297-7247 and ask for contact .... Please remember that this manual or the warning labels do not replace the need to be alert, to properly train and .... gears or other parts and WILL void the warranty! 7. ... Lubricate the attachment shaft with a food quality grease or mineral oil. 4.
    SP62P 60 Quart Pizza Mixer - Globe
    www.globefoodequip.com/.../mixers/...mixers.../sp62p-60-quart-pizza-m...
    This mixer comes complete with an 60 quart stainless steel bowl, spiral dough hook and bowl ... High torque direct gear drive transmission; Oil bath transmission.
    Globe SP62P Gear Driven 60 qt. Commercial Planetary ...
    www.webstaurantstore.com > ... > Commercial Floor Mixers
    Commercial Planetary Floor Pizza Mixer - 3 HP. In stock ... What is White Glove service? ... Globe XXBOWL-62 60 Qt. Stainless Steel Mixing Bowl for SP62P Mixer.... Planetary grease fitting and gear oil meter. .... Globe SP62 and SP80PL MixerControls .... 2003-2016 WebstaurantStore Food Service Equipment and Supply .
Jan 30, 2016 | Globe Food Mixers
How do I install the shredder?
You need to access the accessory attachment point, it's behind the silver KitchenAid logo on the front of the mixer. You'll need to unscrew a set screw (black knob at the very front of the mixer head), newer mixers have a hinged cover, on older mixers, it just pulls out. Unscrew the set screw a bit and fold up or remove the cover.
Now you will see a hole with a hollow square shaft inside, this is where the various optional items attach to the mixer.
Specifically for the shredder, you will need to attach a slicing drum to the drive shaft provided with the shredder, insert it through the drum, and raise the little bar in the rear of the slicer assembly.
Insert the whole assembly into the front of the mixer so that the square drive shaft shaft fits into the square hollow in the mixer, then lower the little bar to lock into place.
Dec 31, 2015 | KitchenAid kitchen aid"" classic stand"
My mixer will not lock in the down position - is not affected by height of beater
Hello Wittwer,
I understand that you are having a problem with your head locking in the down position. This is a common problem when the set screw that holds the latch in place is missing. On the right side of the base up next to where the lock is you will notice a whole that has threads make sure that the set screw is there if not you will need to order a new one. Here is a link to sears parts direct where you can purchase a new set screw they cost $4.62.
Thank you for choosing FixYa.com
Justinbur167
May 11, 2011 | KitchenAid KSM150PS Artisan Series Stand...
We have a hansa canyon tap when we installed it everything seems ok but then we get a red flashing light and it turns off... help pls?
Have you solved this issue yet? I have the same problem with my basin and bath tap. Its driving me nuts trying to fix it!!!
Jan 03, 2011 | Food Mixers
Missing beaters
try this site for your beaters ..
http://www.euro-pro.com/europro/productdetail.aspx?pid=E6DC268A-EF52-4AB3-B332-7A8F5FD0AA85(Euro-Pro+Base+Catalog)
May 09, 2010 | Bravetti 623-715 Stand Mixer
Shaft keeps coming out
tighten the screw under the base that catches the pin. Turn the mixer upside down you can see the flathead screw in the casting. With the pin centered tighten the screw.
Apr 07, 2010 | KitchenAid K45SS Classic Stand Mixer
We just purchased the custom kitchen aid stand mixer on a boxing day special. We used it tonight to make cookies and then could not remove the bowl from the base. We are going to try the icecubes. If this...
The bowl screws into the base and can get quite tight if the mixer has been turning thick dough or other mixes. We usually tap the handle on the bowl with the palm of our hand a few times and that generally frees it. The other posibility is that the bowl was put into the base slightly askew. This could be more of a problem as this can cause the base plate to get damaged. Usually though if this happens you would have noticed some bad noises almost instantly you turned the mixer on.
Dec 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
I have to physically hold my Artisan mixer in place or it will go off the counter, even at low speeds. Seems to rotate fine as long as the head isn't down with an attachment on and in the bowl.
I think from your description that the the head connecting to the base shaft needs tightening. Put the mixer on it's side. Look up inside the base and you'll see a small set screw.
With a flat blade screw driver tighten that screw and it should stop moving. If it doesn't you probably need another shaft because it's worn.
May 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
96 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
