Question about Sony Cell Phones
How do I get my Sony Xperia to hold its charge
    Top Expert:
  • Sony Master
  • 47,823 Answers
Replace the battery
Posted on Dec 29, 2016
I dropped my phone in the bath it was fine for one min till i turned the screen off and now it wont turn on it charges and i dont know how to reset it. how do we reset sony xperia xa?
hi there.
not sure if this is your phone as you did not give model number.
but try this.
First method:
  1. In order to switch off the phone hold down the Power button for a short while.
  2. Afterwards go to Settings and then to Backup & Reset.
  3. Then selec Factory Data Reset and tap Reset Phone.
  4. Choose Erase Everything if you are sure you want to clear all your data.
More items...
SONY Xperia XA F3113 - How to Hard Reset my phone - HardReset.info
www.hardreset.info/devices/sony/sony-xperia-xa-f3113/
or this one.
Restarting andresetting your device Sony Xperia XA support Canada English
or this.
Restarting resetting and repairing Sony Xperia XA support English
or this.
SONY Xperia XA F3113 How to Hard Reset my phone HardReset info
Dec 01, 2017 | Sony Cell Phones
My phone hasnt been used for a few mths when ive put it on charge theres a red light and the sony logo keeps flashing on and off
It's probably just charging. It's gone completely dead, no residual charge left at all, and it will do that because the phone is off and charging. After it does this awhile, you can turn it on while it finishes charging.
Mar 07, 2016 | Sony Xperia Z2
How do i unlock my sony xperia mir if i forgot security question answer
  1. Make sure the battery charge properly before doing this step
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA MIRO (ST23i/ST23a)
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA MIRO (ST23i/ST23a)
Nov 02, 2014 | Sony Xperia miro ST23i Smartphone -...
Sony xperia t troubleshooting
restore settings
or this one note all data will be deleted
How to Soft Reset or Reboot or Restart SONY XPERIA T LT30p ?
To soft reset SONY XPERIA T LT30p, press the POWER BUTTON KEY for several seconds, we will see the menu to restart or turn off. Choose restart/reboot than the SONY XPERIA T LT30p will do the soft reset or restart. This is safe to do because non of important data or applications will wipe or erase.
#Option 1, Hard Reset SONY XPERIA T LT30p with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA T LT30p smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & reset > Factory Data Reset > Erase internal storage > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA T LT30p
  6. The SONY XPERIA T LT30p will continue the step until ready to use in clean factory default.
#Option 2, Hard Reset SONY XPERIA T LT30p with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA T LT30p battery is charge properly or full charge
  4. Power off SONY XPERIA T LT30p
  5. Boot SONY XPERIA T LT30p to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
#Option 3, Hard Reset SONY XPERIA T LT30p with Hardware Key Button:
  1. Make sure the battery fully charge
  3. Turn off the SONY XPERIA T LT30p
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA T LT30p
You can choose the step options above to do hard reset while the SONY XPERIA T LT30p get problem or not running well. But we always suggest to do routine backup before your smartphone get problem. If SONY XPERIA T LT30p already stuck or run slowly or not responsive, then better try to do backup as you can because all important applications will be wipe or removed from SONY XPERIA T LT30p after doing master reset, but some data which saved at memory card will be safe, better to remove the microsd memory card before doing the hard reset.
Jun 16, 2014 | Cell Phones
How to nulock sony xperia s lt26i
solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
  2. Turn on SONY XPERIA S smartphone
  4. Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
  6. The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
  3. Make sure SONY XPERIA S battery is charge properly or full charge
  4. Power off SONY XPERIA S
  5. Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
  3. Turn off the SONY XPERIA S
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
Dec 19, 2013 | Sony Ericsson XPERIA S LT26I Nozomi Arc HD
I want to reset my phone.i forgot all the password and security details..how do i do it
Option : Hard Reset SONY XPERIA MIRO (ST23i/ST23a) with Hardware Key Button:
Nov 07, 2013 | Sony Xperia miro ST23i Smartphone -...
Mobile phone won't hold it's charge
try to update using update service fopr sony
Mar 25, 2012 | Sony Ericsson Xperia Arc
Cell Phones Logo
27 people viewed this question
Top Sony Cell Phones Experts
M_Butkus
john h
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
