Question about Food Mixers
I recently purchased a set of basin and bath taps through amazon and noticed that the bottom of the bath mixer doesnt have a square piece for underneath the washer ...is there items missing ??
    Top Expert:
  • Food Mixers Master
  • 49,170 Answers
Contact amazon and complain of missing items
Posted on Dec 29, 2016
How do I fix a kitchenaid stand mixer that won't start?
First make sure it is plugged in.
Second make sure the outlet is not GFCI, check it with a lamp to ensure there is power.
Check the black screws on the side first after you unplug it from the wall. They will screw out with a dime or wide flathead screwdriver.
be carefull this is where the brushes go.
Caution: They are spring loaded. And the cap will fly if you are not careful. check both sides to make sure the brushes, little square shaped pieces of carbon, are long enough and making contact.
You can pick a new set up for your model on amazon pretty cheap and they are a snap to reinstall. If this fails you have to check the rear section of the mixer to ensure the circuit board does not have any burnt pieces on it. It will be obvious when you see the tiny PCB if there are any dead components. You can also pick these up on Amazon fairly cheap. Aside from that find an appliance repair shop where you live and have them fix it.
Dec 15, 2015 | KitchenAid K5SS Heavy Duty Commercial...
I turned on the tap and a grey filter and a yellow disk fell into the basin from the spout of the tap. I am unsure if another part went down the plug hole!
Contact Reece plumbing or take parts into Home Depot or Lowes and see if they can tell you what you need
Nov 26, 2015 | Food Mixers
KitchenAid mixer ring falls off
The trim ring news to be ta]ed in place with a plastic-face mallet. This type of mallet does not (if used properly) Mar the surface it striks.
Hold the trim ring in place while tapping it in place. It often takes patience to get it right.
The ring is properly in place when there is no place where you can insert a fingernail between it and the mixer body all around the ring.
Jun 08, 2017 | KitchenAid K45SS Classic Stand Mixer
We have a hansa canyon tap when we installed it everything seems ok but then we get a red flashing light and it turns off... help pls?
Have you solved this issue yet? I have the same problem with my basin and bath tap. Its driving me nuts trying to fix it!!!
Jan 03, 2011 | Food Mixers
Mixer head is loose beater scrapes bottom of bowl makes loud thumping noise
I assume you mean that the top half of the mixer, above the pivot pin, moves with respect to the lower half of the mixer, the stand part. There is a pin on which the top half pivots which becomes loose.
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
Apr 10, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
Top wobbles and beaters scrape bottom of mixing bowl when in use
Apr 08, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Springs on side under black screw, came out
Or, more helpfully, take them back out.  Look in the hole, and you will notice that when you look through, the hole turns square. At the end the square, there is a little tab / square in one corner.  It is generally *not* the same on both sides. You'll notice that the end of the piece you took out (the part that looks like a magnet) has one corner cut off -- so it's a rectangular box with one of the corners gone.  Line up the missing corner of the piece you took out with the corner that has the little tab -- this allows the piece to get past the tab and be fully inserted.  Reminder: check both sides, because they're not the same. And now, more helpfully, if you're curious, check out flea markets and get a broken Kitchenaid to take apart for $20 or so. Don't mess with your nice one. : )
Apr 24, 2009 | KitchenAid K45SS Classic Stand Mixer
Oil seal
1. Remove the acorn nut, hex nut, and washer that hold the "planetary" agitator section on the transmission shaft.
2. Remove the trim ring (if any) around the same.
3. The agitator section should now be able to be worked free.
4. Remove the retainer clip on the top of the agitator shaft. (Some models have a pair of hex nuts here; if so, remove those.)
5. Pry the gear up and off the shaft. Remove the square key from the shaft keyway at the same time.
6. Tap gently on the top of the agitator shaft to drive it out from the bearings and grease seal.
7. Recommend removing and replacing the top bearing at this time; it's inexpensive to replace, if you're in this deep.
8. Use a suitable diameter piece of round steel stock to drive out the lower bearing and oil seal. I don't recommend using the agitator shaft.
9. Clean thoroughly, insert a new bottom bearing and oil seal, drive in place with a rubber mallet.
10. Replace agitator shaft through oil seal and bearing, tap gently into place.
11. Fill cavity with approved lubricant. I use USP-grade mineral oil, as it is food-safe and provides satisfactory lubricity.
11. Install top bearing, tap gently into place.
12. Reverse steps 5-1 to reassemble.
Aug 24, 2008 | Food Mixers
Assembled parts incorrectly
The rectangular rods are the motor brushes. They will have a rounded shape to them and as long as you have the rounded edge match the rounded shape of the armature it does not matter unless there is some kind of groove to force orientation of the brushes.
Dec 16, 2007 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Mixer attachment
make sure attachment is turned full counter clockwise to release point give a good tug if doesnt work try a light tapping with a rubber hammer or lobster wooden hammer
Nov 20, 2007 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
119 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
