Question about Cell Phones
My Xperia XA won't hold its charge - Cell Phones
I dropped my phone in the bath it was fine for one min till i turned the screen off and now it wont turn on it charges and i dont know how to reset it. how do we reset sony xperia xa?
hi there.
not sure if this is your phone as you did not give model number.
but try this.
First method:
  1. In order to switch off the phone hold down the Power button for a short while.
  2. Afterwards go to Settings and then to Backup & Reset.
  3. Then selec Factory Data Reset and tap Reset Phone.
  4. Choose Erase Everything if you are sure you want to clear all your data.
More items...
SONY Xperia XA F3113 - How to Hard Reset my phone - HardReset.info
www.hardreset.info/devices/sony/sony-xperia-xa-f3113/
or this one.
Restarting andresetting your device Sony Xperia XA support Canada English
or this.
Restarting resetting and repairing Sony Xperia XA support English
or this.
SONY Xperia XA F3113 How to Hard Reset my phone HardReset info
Dec 01, 2017 | Sony Cell Phones
How to nulock sony xperia s lt26i
solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA S smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
  6. The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA S battery is charge properly or full charge
  4. Power off SONY XPERIA S
  5. Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
  1. Make sure the battery fully charge
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA S
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
Dec 19, 2013 | Sony Ericsson XPERIA S LT26I Nozomi Arc HD
What 16" tire size won't rub on scion xa
the correct size of tire is listed on the drivers side door frame
Oct 15, 2012 | 2005 Scion xA
Mobile phone won't hold it's charge
try to update using update service fopr sony
Mar 25, 2012 | Sony Ericsson Xperia Arc
I have Xperia X 10 mini from Sony Ericsson. I left it charging overnight as I do every night since I've got it. And today when I woke up, I took the phone and instead of it being fully charged and
Chances are your phone got too hot during the night and overcharged the Lithium Ion battery. If those batteries are exposed to too much heat then they won't have the battery life they used to have. You need to purchase a replacement battery or contact your wireless carrier to see about getting another one.
Jan 24, 2012 | Sony Ericsson XPERIA X10 Cell Phone
Why isnt my xperia mini x10 pro not charging? my wall adapter doesent charge it, neither does computer adapter.. any advice?
read the tip on the below link and know some of the reasons why your phone won't charge.
The tip was posted by me.
Click here: http://www.fixya.com/support/r8742993-phone_charge
Good luck.
Jun 23, 2011 | Sony Ericsson XPERIA X10 Cell Phone
How long does it take to charge the battery
Usually 2 to 3 hours BUT
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
May 28, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
