Question about ASUS Computers & Internet
I have an Asus notebook laptop,would not power up or charge so looked on line for advice, following this I lifted up the keyboard and two strips under keypad came unattached how do I reconnect them
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
The plastic block it goes into has a section you pull out a bit with your finger nails, it will move forward and then push back in with the ribbon cable to lock it, its fiddly but not difficult
Posted on Dec 31, 2016
Asus U50F Disassembly and DC Jack Replacement
One thing for sure you'll probably need a soldering gun. Most times the DC Jack is soldered unto the motherboard which means you will spend hours desoldering the old one to get it off the board and then have to solder the new one onto the board.
Ok, on a laptop you need to get some cups and label them to put the screws in so you will know where they came from. Remove the Power Cord, Remove the Battery then start removing all the screws from the bottom of the laptop. Then remove all the devices from the bottom of the laptop such as the hard drive, the memory, dvd/cd drive, wireless card, etc. Take note of how the wires are on the wireless card, those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slot for screw. Some screws on the bottom case in inside of some of the device cases might have the icon of a keyboard next to it. Those screws hold the keyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but be careful because a cable might be attached to it. Then remove the screws that hold the keyboard in place that are under where the strip was and gently lift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift the lcd screen off, also note that you will have to pull the antennas cable and the lcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note of any cables that are attached to the palmrest and remove them then lift the palmrest off.
Next start removing any screws you see that hold the motherboard to the bottom case, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory of where things were.
Jun 05, 2012 | ASUS U50F Notebook
Disassemble
Ok, on a laptop you need to get some cups and label them toput the screws in so you will know where they came from. Remove the PowerCord, Remove the Battery then start removing all thescrews from the bottom of the laptop. Then remove all the devices fromthe bottom of the laptop such as the hard drive, the memory, dvd/cd drive,wireless card, etc. Take note of how the wires are on the wireless card,those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slotfor screw. Some screws on the bottom case in inside of some of the devicecases might have the icon of a keyboard next to it. Those screws hold thekeyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but becareful because a cable might be attached to it. Then remove the screwsthat hold the keyboard in place that are under where the strip was and gentlylift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift thelcd screen off, also note that you will have to pull the antennas cable and thelcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note ofany cables that are attached to the palmrest and remove them then lift thepalmrest off.
Next start removing any screws you see that hold the motherboard to the bottomcase, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory ofwhere things were.
May 16, 2012 | ASUS M3000Np Notebook
Remove toshiba keyboard
Remove the Power Cord, Remove the Battery. Look inside the battery compartment and see if any screws are there, if so remove them (the keys inside the battery compartment normally holds the strip that is above the keyboard). If you see a screw that has the icon of a keyboard beside it, then that screw holds the keyboard in place. Look along the bottom of the laptop for more screws that have the icon of a keyboard beside them and remove them. In fact you could just remove all screws from the bottom of the laptop just in case you have to remove the palmrest. Remove the screws from the covers that houses the memory and hard drive and check inside them for screws. Sometimes a keyboard screw might be inside them.
Turn the laptop over and remove the strip that is at the top of the keyboard by gently prying it off with a small flat head screw driver. Be careful because there might be a cable attached to it. If the strip above the keyboard is one big piece that requires the whole palmrest to be removed, then look along the sides and top of the keyboard for little catches that you can push to release the keyboard and it will come out without having to remove the palmrest.
if the you have to just remove the strip at the top of the keyboard, once it is removed there might be screws at the top of the keyboard that hide under the strip to remove. Once the screws are removed, gently try to lift the keyboard out. Small catches on the side might be holding it so you might have to work with pulling one side out first then the keyboard will come out. Be careful, there is a cable under the keyboard that plugs into the board. Remove the keyboard cable from the board then lift it all the way out.
May 15, 2012 | Toshiba Satellite M45-S331 Notebook
E8410 keyboard removal
Remove the power cord, remove the battery, turn the laptop over and remove any screws you see inside the battery compartment. Also look on the bottom and in the battery case for any keys that might have the icon of a keyboard beside them (they hold the keyboard in place). You might have to remove all the screws from the bottom case if the laptop's design does not have a separate strip that sits above the keyboard. Once you have the screws remove, turn the laptop over and open the lid. If there laptop has a strip above the keyboard, then pry it off gently because a cable might be under it. If it does not have a strip, but is all one big piece called the palmrest that surrounds the keyboard, then the keyboard might have little catches on the sides and at the top that you can move and wiggle the keyboard out. if not you will have to remove the palmrest. Also if you have the strip above the keyboard, once you remove it you might see screws that hold the keyboard then remove them.
Be careful when you lift the keyboard out, there is a cable under it that has to be removed from the board.
May 13, 2012 | Fujitsu LifeBook E8410 Notebook...
Keys 5, 6, r, t, f, g, v don't work on Aspire 4720z. What should I do?
1.Power off the Acer laptop and flip the unit over. Slide the battery release lever over and lift the battery out of the laptop.
2.Turn the laptop back over and open the lid. Look inside the open area on the keyboard where the key would normally go. Check to see if the plastic retaining clip is still inside the hole.
3Locate the plastic retaining clip if it fell off the keyboard along with the key. Use a pair of tweezers to set the clip back inside the hole. Line up the holes on the clip with the four raised nodules inside the keyboard hole.
4.Set the key back onto the plastic clip. Push the key down until it clicks into place.
5.Flip the laptop back over if there are keys that are not working properly. Use the Phillips-head screwdriver to remove the three screws on the left side of the case that hold the keyboard in place. Turn the laptop back over so that you can see the LCD screen.
6.Push the thin end of a flat-head screwdriver under the LED indicator strip above the keyboard. Pop the strip upward and pull it off the laptop.
7.Lift the keyboard up towards you until the long ribbon cable running from the bottom of the keyboard to the motherboard comes into view. Unplug the cable from the port on the motherboard and then pull the keyboard and its ribbon cable off the case. Spray out the underside of the keys and the inside of the Acer laptop case with canned air.
8.Reassemble the keyboard, LED indicator strip and battery.
Sep 28, 2011 | Acer Aspire 4520-5582 Notebook
The right shift key does not work as well as a few of the upper left control keys...everything else seems to be working just fine.
Hi there , this might be the ribbon cable connecting the keyboard to the laptop , lay the screen flat , look at the left hand side of the lap top , there is a strip you can lift up , where the power switch is. lift the strip up , you will now see the two screws holding the keyboard down, unscrew them , slide the keyboard up slowly and lift , gentaly you will now see the small riben cable, lift the small black catch , then reseat the cable , push the catch back, and reseat the keyboard. now retry the keyboard ...
Nov 13, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
How do i replace the keyboard in hp dv6500
First thing is to take the battery out. Then you need to remove the access door that covers the wireless card and Ram memory. In the area where the battery sits, there are three screws, these hold the power strip in place. Remove those screws, now there are two more screws in there up against the battery compartment, these are marked with a keyboard icon, remove these two screws. Now, there is one more screw for the keyboard and that is in the wireless/ram compartment. It is down in a "tube" but marked with the keyboard icon. Once that screw is removed, turn the laptop back over and open the lid. With your fingernails pry up on the right side of the power strip and lift it gently, it will pop up, but be careful because there are a couple of flat cables that connect it to the motherboard. This strip does not have to be removed to remove the keyboard. Just shift it toward the display so that you can grab the keyboard at the top and lift it toward you to clear the power strip. There are no other screws holding it down. Once you lift it up at about a 45 degree angle shift it toward the display and this will allow the keyboard "catches" to release at the bottom of the keyboard. Look under the keyboard and there will be a flat cable attached to the motherboard, this is the last attachment. It is held in place by a tension clip. look at the white or light colored strip of plastic on the end of the cable socket, move this toward the display, it will slide forward releasing the cable. Reverse these processes to put the new keyboard back in. Just remember the keyboard slides under the palmrest at the bottom of the keyboard, watch the keyboard when you remove and you will see what I mean.
Oct 09, 2009 | HP Pavilion DV6500Z Notebook
Asus Eee PC keyboard won't re-attach to the motherboard. Help!
On the backside of the connector where the ribbon goes there is a small strip of plastic there.LIFT IT UP ON BOTH ENDS,SLIDE THE RIBBON DOWN INTO IT.WHILE THE RIBBON IS IN IT,PUSH THE STRIP OF PLASTIC BACK DOWN MAKING SURE THE RIBBON STAYS IN PLACE (ALL THE WAY DOWN) WHILE PUSHING IT DOWN.You may have to try it a few times to get it snug in the motherboard connection.Good luck!
Aug 11, 2009 | ASUS Eee PC 1000HA Notebook
Acer 3680 keyboard
Keyboard removal work one of two ways on about every laptop out there. 1- The screws holding it are on the bottom of the machine, sometimes marked with a K. 2- The screws are under the power button strip at the top of the keyboard, the strip snaps into place, so lift up on one side and work it up and off. Here's a couple of links for laptop breakdown diagrams. You should be able to find your machine there or at least a similar one to give you an idea.
http://repair4laptop.org/notebook.html
http://www.eserviceinfo.com/service_manual/datasheets_d_600.html
Jul 01, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
26 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
