I would like to know what would be a good high end integrated stereo receiver amplifier, or a few to look at. It needs to run a whole house audio system that has 12 sets of speakers. The speakers are all 8 OHM's, but I want a real good powerful amp to power the system so as to not tax the amp and risk blowing the circuits which happened in the past. Music source would be CD, Satteliete and IPORT. Thank you for any assistance. Pat
  • Pat Jul 21, 2009
    Good Idea...Thanks
  • 431 Answers
Hi I am Vortash you dont say what wattage the speakers you have in your home are , or if the speakers are wired in paralel or series .
As you can appreciate a series system will decrease the Wattage required but increase the ohms of the system as you will have a total of 96 ohms per channel in series and in a paralel connection , the Ohmage will be reduced by each speaker attatched ex 8ohm becomes 4 ohm etc as per Ohms law and the bridging of two resistances , if you haven't taken this into consideration then this may be why you are blowing the amps you have been using .. Audio systems are one of the most missconcepted sysytems there is as the layman thinks all he has to do is put a bigger amp on and he gets more sound .. sorry to say this is untrue it requires balance .
I dont mean to sound condescending but I have attended to hundreds of systems that have been damaged as a result of this oversight and dont wish you to fall at the same hurdle .. If you want a supreme system then you will have to match the Speakers to the system and not Visa versa as they are already installed .. Most theater systems are designed specifically with the speaker system they come with and adding to them only overdrives the amp and eventually leads to burn out ..
Your best bet is to go to an audio department of choice and take with you all details of your speaker system .. how wired distance of cable run etc ( as the longer the cable the more resistance ) and a engineer would be able to work out exactly what you require and probably save you loads of dosh in buying the wrong one and having to either have it repaired or replaced ,and if the system did fail then you would have recourse to get repair or your money back .. as it would have been designed and recomended by them for your specific needs .. Hope this helps and i have not waffled on too much lol Regards vortash
Posted on Jul 21, 2009
Cant get sound from my receiver and amp together
if you are hooking up 2 units to run together, take a pic of the back of both units, and post them here
Mar 06, 2013 | Denon Pma-520 Integrated Stereo Amp...
Kenwood Stereo integrated amplifier A-58
hi i have bought kenwood hi fi with following parts -
integrated amplifier - A-58
cd player - DP-M58
stereo receiver - T-58L
twincassette player - X-58
turntable - P-38
but I can't get owner manuals from anywhere. Can you help me with it please ? marek922@vp.pl
Jun 29, 2012 | Kenwood Audio Players & Recorders
I am thinking of replacing my now very old JVC AX 330 amplifier with a Marantz PM7003 amplifier and want to know if this is a suitable replacement in terms of power output etc.
You, sir, are a rare adherent to stereo-only electronics. Are you replacing it for cause (showing its age)? The PM7003 is only 2 x 70 watts like the JVC but it also has separable preamp/amps so you COULD upgrade or augment the power output with external amps and still control it all locally.
Of course, any current AVR's do that too and bring digital sources and multichannel audio to the mix for as little as the PM7703 may cost.
Jun 23, 2011 | Audio Players & Recorders
The ic tda7293 is exploited, and I have no further information on the motherboard, I need to find the service manual, thanks
TDA7293 is a high-power high- voltage DMOS audio amplifier IC made by STMICROELECTRONICS. Its rated output power is 100W and maximum operating voltage is120V. And it is a monolithic integrated circuit in Multiwatt15 package which is intended for use as audio class AB amplifier in Hi-Fi field applications, such as home stereo, self powered loudspeakers and Topclass TV.
Feb 07, 2011 | Audio Players & Recorders
Hello, sorry for my english, please. I have an AIWA stereo integrated amplifier, It`s Rx-N5. In this system, the display is dead but the amplifier and the tuner are good. Please, can you help me? I think...
Try searching somewhere like DiploDocs . com website for a service manual. It seems to me you know what you are doing, all you need is a service manual :-)
Best Of Luck
Sep 02, 2010 | Audio Players & Recorders
Connecting an Altec Lansing ADA995 subwoofer system to a stereo
I have this exact Altec Lansing speaker system and I'm currently just using it with my Dell computer. But, I know you don't have to install these speakers to any high powered receiver for good sound quality. The subwoofer has two separate 200 watt RMS combined amplifiers built in for it's single knob controlled dual 6.5" bass drivers and 2-way magnetically shielded satellites, which are amplified together by any source that has an analog or digital volume control. The speakers act as a preamp receiver to any volume or frequency tone level controlled audio source. These input sources can also equalize the speakers receiving input signal for bass, treble or mid-range adjustments. You only need to obtain the proper adapter to hook up all the speakers to your desired component or device. Besides a computer, for example a TV with a variable audio out function or a mp3 player will work. The adapter that i am referring to is similar to what is included with certain 5.1 Logitech brand computer and multimedia speakers specifying gaming console and TV connecting. It has all three color coded 1/8" connector inputs on one end and RCA jack outputs on the other. This can be purchased more easily online then offline at stores such as Ebay for a fairly inexpensive price. However this adapter will not decode true 5.1 surround, but instead give a 5 channel stereo effect. I guess if one was looking for an inexpensive alternative solution to purchasing traditional high end home entertainment audio equipment, the ADA 995s are one of few computer speaker models in my book that can do a decent job.
Jun 19, 2009 | Altec Lansing ADA995 Speaker
I need cables for a 1991 Panasonic shelf audio system
Hi Will, I searched for flat cables ,seem to no longer be stocked. If you are interested in selling the whole system let me know. I have one working condition with cables, would like to have spare units(parts). I will check one more site on cables for you.
Contact Gregg at: GreggASef1@zoominternet.net
Feb 06, 2009 | Panasonic Audio Players & Recorders
Looking for a good amplifier
Any 2-channel (or greater) receiver or integrated amp with at least one Tape Monitor loop; or any separate amplifier - will work. I would look fror one with true > 100 watts per channel, all channels driven, 20-20000kz + a few dB, with less than 0.5% Total Harmonic Distortion (in other words clean and powerful) should suffice. Specific brands don't matter. I'm partial to old Carver amps.
However, should you get a multi-channel amp for the 901's you will be limited to using only 901's on it as the required Active Equalizer would affect all speakers attached to the amp, and conventional speakers would not sound right and could possibly be harmed by it's drastically-altered frequency response. Since using the Tape Monitor on modern DSP Receivers disables their digital inputs, that would limit what you could listen to, should you later decide to go with Cable Box, DVD, SACD, DVD-Audio, Blu-Ray, DTS etc.
* There are no some multichannel receivers out there that allow separating the preamp-amp circuitry for each channel to allow for differences in speaker processing. I think Marantz had one.
However, having a 901-based multichannel setup myself, I would highly recommend getting the Full Monte for video listening (below)...
In that case a separate stereo amp for the 901's would work. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
So to sum it up, I think you should start with a powerful, clean amp with few bells and whistles for the 901's and maybe later add a multichannel receiver with all the magicfor source control, DSP and to drive the other channels.
Jan 05, 2009 | Onkyo TX-DS747
MID-RANGE DISTORTION
hi it is an amp module failure inside £129.00 plus vat 4 hours to replace total strip out £380.00 total to do these are made by samsung and rebadged horrible things dump it thats my advice regards kirk
Oct 14, 2008 | Denon AVR-3806 Receiver
21 people viewed this question
 Grubhead
Grubhead
