Question about Cameras
Cannot import photos off my camera sd card,
My computer is showing me the following error message when I try to import photos from my camera sd card: the following error occurred while finding photos and videos to import: the filename, directory name, or volume label syntax is incorrect. when I open up the dcim files, there are some new files showing with special character file names and some empty files with the same character file names and I cannot delete them.
    New Friend:
In your case, you'd better go insert this camera SD card to another computer and see whether it is still recognizable there?
Also do an antivirus scan there? And then, go try to save or copy data out to have another try.
If such problems are really caused by some SD card problems, save data backups well and go repair this camera memory card latter.
Posted on Jan 19, 2017
  • KerHer0
    KerHer0 Jan 19, 2017
  • 502 Answers
I would try a different card in the camera, and format it before using.....if that works then you may have to use some special software to retrieve the photos off the bad card if they are important to you....
Posted on Dec 29, 2016
I am having nikon coolpix S3200 camera, i tried to import pics to my desktop through card reader but i am not succeed and when i replaced back SD card in camera and tried to view photos i got an message...
A program such as "Pandora Recovery" has worked for me when I had deleted photos off of a SD card.
Not as many photos I used the free version up to 1 Gb. Suggest attempting to copy, if possible, the 3.2gb to another drive before starting any recovery.
If priceless photos suggest finding a professional recovery service and pay the $$
Hopr this helps?
Jun 29, 2017 | Nikon Coolpix S3200 16 MP Digital Camera...
How do I import photos from my camera?
There are two ways to import your photos.
One, your camera should have an sd card which you can eject and put into your computer. The sd card should have all your photos and videos in it. Typically the card is located near the battery and you can press down on it and it should pop out. You may also need a sd card reader or micro sd card reader if it doesn't fit in your computer.
Second, your camera should also have a usb port, whether micro or mini or whatever. It should have a port to connect to your computer through a usb cable. In this case, just connect your camera to your computer and it should show up on your computer like an extra drive where you can go in and see all your photos.
Also, the folder that holds everything is usually labed DCIM i believe.
Hope this helps.
Oct 26, 2012 | Cameras
I have a FinePix A900 camera with a 1 GB SD card. I connected a cable in the A/V Out to watch the photos on a TV set. At this moment something went wrong. The camera LCD becomes black and no picture was...
First of all, it is never advisable to copy a picture from the computer to a memory card or camera. Most of the time, it will corrupt the card and sometimes the camera. Second, the procedure for connection to a tv needs to follow a detailed procedure. This is different for each tv and camera. For example, on my tv, my camera and tv need to be off, I make the connection, turn on the tv, set the tv menu to "photos", turn on the camera, and then follow the on-screen prompts from there. If I change that order, I have problems.
Jun 19, 2011 | Fuji FinePix J10 Digital Camera
Canon Power Shot A480 memory card error showing on screen I have checked side locked button
If it's a brand new card, it needs to be formatted with the camera. If it's been used before, the files may have been corrupted when plugged into your (or another) computer.
Nov 08, 2009 | Canon PowerShot A480 Digital Camera
SD card won't show my pictures message says...
put it to the card reader into the computer then copy all of the photos into the computer and the put it back into the camera and in the menu there is a function to format the card. That should work
Nov 05, 2009 | Cameras
Coolpix L20 usb cable will not work
The cable itself might be to blame. You should hope so, since the alternative is not good news. These cables are pretty much standard and available in any Radio Shack or Best Buy.
If that doesn't work (and you can return the cable if that's the case), I would recommend getting a cheap card reader rather than using the camera and cable to import your photos. Your camera takes SD and SD-HC cards. To be safe, you should be sure to get a card reader that can accept SD-HC cards (not all of them can).
With a card reader, it's even easier and faster to import photos. You insert your memory card into the reader, which attaches via USB on your computer, and it shows up just like a disk drive. then drag and drop your photos where you want them.
Sep 12, 2009 | Nikon COOLPIX L20 Digital Camera
Can't access photos on 2 GB SD camera card.
You may try some photo recovery software to rescue the files on your digital camera sd card, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Mar 22, 2009 | Canon PowerShot A540 Digital Camera
File errors, distorted photos.. I hate the Samsung L100!!
regarding the use, you have to check if you are using the right memory card for your camera.
you can only use 2GB sd card or 4gb sdhc card.
try this and if you still have an error message. you better send the camera for service.
Jan 19, 2009 | Samsung L100 Digital Camera
Nikon D40X - playback
Try formatting the card then using it again. Does this work?
Jan 10, 2008 | Nikon D40x Digital Camera
Cameras Logo
111 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
