Question about Refrigerators
My problem is when the evaporator Ices up the heater doesnt heat up to defrost the ice...No power is coming from source to the element...How to solve this problem ??
  • 878 Answers
SOURCE: Freezer Troubles
Skap, the question is whether the evaporator coils are completely frosted up or just the top section. Frigidaire has had a lot of issues with restrictions which would cause just freezing on the top half. I will attach some pictures. Your unit has an adaptive defrost. I believe that you can advance it into defrost by pressing the light switch 5 or 6 times. If you pull the bottom grill, there should be a tech sheet with the instructions behind it. Usually when this adaptive defrost unit fails, you will not have a freezer fan, for it runs through this adaptive defrost board. Your heaters are calrod and usually do not fail. They can become unplugged due to ice build-up. You can check to see if you have 120V getting to them after putting the unit into defrost. If not, check the defrost thermostat (bi-metal). If it's bulged, it's usually a bad sign. Defrost the unit with a hair dryer while unplugged. You have to remove the back freezer panel to get at the bi-metal, defrost the unit and check the drain pan.
Posted on Sep 11, 2006
  • 247 Answers
SOURCE: evaporator fan jams with ice buildup from drain
Could be that, or it could be the temperature sensor on the evaporator - if that goes, then as soon as the freezer starts a defrost cycle, it will think it's got the evaporator hot enough and will start cooling again.
Suggest you let the freezer thaw out then, with a voltmeter connected across the terminals on the board which connect to the sensor, turn the freezer on and see if the sensor reacts sensibly to the evaporator cooling down. It's usually done with a thermistor, but just for the moment, I can't remember whether it's usually a PTC or an NTC.
That way, if it is the sensor, you'll be spared the expense of replacing a serviceable pcb.
Posted on Apr 13, 2008
  • 1073 Answers
SOURCE: evaporator fan blade jams in ice buildup
check the defrost bimatal or defrost thermanstat it will be located on the evaperator suction line (large line) it should read continuity with the ref cold if it showes continuity then the defrost timer is the problem
  • 5568 Answers
SOURCE: GE built in Fridge does not defrost and freezer ices up
Defrosters are commonly controlled by a primitive timer and this may have a 'dry' and a 'wet' (humid) climate setting that will cause the defroster to cycle generally every 12 or 24 hours.
If set wrong (by accident or on purpose), it can allow too much frost to accumulate before attempting to defrost.
This can cause a gradual buildup of ice.
Also the heating element for the freezer may have failed open so it never heats at all. The connections that need to be checked are often buried between the in- and outside walls.
The timer is probably still OK since you apparently aren't having a problem on the refrigerator side.
Posted on Jun 10, 2008
  • 1122 Answers
SOURCE: evaporator coil iceing
if you can put the frig. in defrost this will tell the sensor to turn on and you will see the heater melting the ice,if you can't put it in defrost and the sensor still has ice on it,simply put it in your hand,as your hand warms up you should feel the sensor pop,this pop tells the heater to turn off,if no pop the sensor is bad,if no ice on the sensor put it in a glass of ice,chill it down and do the same hand test,you can also use an omhs meter to check it,all the sensor does is open and close,let me know what you find-mike
Posted on Oct 30, 2008
1996 amana side by side freezer somtimes doesn't maintain temp
hello it sounds like the element is faulty, as long as the fan is working, the element switches on when defrost thermostat sensor that the coil is icy up, but if you are not familiar on how to use a multimeter it is hard to know for sure, if you do know how to use a a meter , when the coil ices up and the fan is working check to see if there is power to the element, if there is power the element is faulty, if there is no power then you have a problem with the thermostat
Jul 23, 2010 | Amana SXD524VW Side by Side Refrigerator
Westinghouse silhouette frost free 522 fridge is not cooling properly top and bottom.freezer fan is still working,and the motor at the bottom in the back of fridge stay's constantly running and has done...
The heating element, located behind the back plate of the freezer, is probably not working. A failed heating element leads to a build up of ice around the evaporator coils in the rear of the freezer. If the back plate of the freezer is removed (ONLY DO THIS WITH THE APPLIANCE UNPLUGGED FROM THE POWER SUPPLY) and there is a large build up of ice around the evaporator coils then it's a fairly good indication that the heating element is not working. The heating element comes on periodically to defrost/de-ice the evaporator coils. Heating element is often activated by a small timer switch which turns the heater on for a set time every 24 hrs or so. Heating element may be open circuit or timer switch may not be operating. Most likely to be open circuit heating element.
Jan 01, 2010 | Westinghouse Refrigerators
Cooling coil ices up
you'll need a make/model # to order a defrost thermostat or heater element for the unit
Nov 06, 2009 | Cell Phones
Frezer ices up. checked heating elm, tests OK.
Hi, If you are getting solid ice below the evaporator coil, you need to unplug the defrost drain hole/
If you are getting frost and it's plugging the evaporator, you will need to test the bi-metal switch located at the top of the evaporatr coil. If that switch tests ok and your heater is ok, you will need to change the defrost timer.
Please let me know if this helps you or if I can assist you further.
Jul 16, 2009 | Refrigerators
501f freezer ices up the evaporator. After defrosting it works well until it ices up again.
Could be a couple of things. First measure the resistance of the defrost heater that is mounted on the evaporator coil in freezer compartment. Make sure to disconnect the power from freezer first. The disconnect the defrost heater and measure with ohm meter. It should measure in the 20 ohm range. If it measures as "open" replace the coil.
Next suspect is the defrost timer mounted in the front of the compressor compartment. If the heater coil is OK, I'd just replace the timer. It is tough to test.
Finally, there is a defrost termination sensor mounted on the top of the defrost heater that shuts off the defrost heater when it reaches a high temperature. If the coil tests OK, and you are going to replace the timer, you may want to replace the sensor too. It is awkward to test, the temperature of the sensor needs to be be below room temperature to close. The cost of the sensor is low enough that you may not want to replace the timer, then test the system, and then have to go back in to replace the sensor later.
Jun 13, 2009 | Freezers
My LG bottom freezer, french door evaporator fan ices up andmakes a loud buzzing sound. I have to unload the freezer and defrost with a heat gun. Lots of frost around the fan.
Defrost heaters are not coming on. Check with multi it frost, or ice freezing under the fan-blades. That my friend is a blocked drain hole. Otherwise ohm out defrost heater should read 30to69 ohms of resistance. Timer may be stuck, or a hi-temp safety switch is not closing (a small disc at the top of the coils) when it comes out of defrost. Carweful with that gun, Jim! Too much heat warps all that chinese plastic. Chris in bigbEar
Apr 20, 2009 | LG Refrigerators
Sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Check to see if the freezer side evaporator fan motor is running.
Sep 15, 2008 | Frigidaire FRS26R4A Side by Side...
Defrost problem diagnosis
you will need a multimeter. check continuity thro the heater and stats mounted on the evaporator
Apr 08, 2007 | Kenmore 72073 Top Freezer Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
