Question about Bosch Washing Machines
My Bosch Exxcel 1200 makes a loud knocking noise when spinning. Is there a cure?
Its spinning OK but we have to switch it off as the knocking is so loud and sounds like a drill.
3 Suggested Answers
cjrepairs
  • 60 Answers
SOURCE: Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
Posted on Aug 16, 2009
barkencoa
  • 3463 Answers
SOURCE: bosch exxcel 1200 express spinning slowly
I would suggest that you remove the motor, and check the brushes for wear.
If they are less than 3 or 4mm long, then they need to be replaced.
Hope this helps.
Posted on Jan 07, 2010
BOSH EXXCEL 1200 EXCEL IS HAVING LOUD CRACKLING NOISE WHEN SARTING. THIS IS BEFORE THE DRUM STARTS TO TURN.
It the motor there are carbon brushes in there when they wear down they don't touch commutator... on motor what u here is arcking u shud b able to re place them u will need a model number and make, ..or remove motor and take with u to get right brushes if the moyor is badly burnt u will need to replace it if u continu to use like this it will only get worse
Oct 12, 2013 | Bosch Water Heaters
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
Front seal leaking in my bosch exxcel 1200
This video will show you how to change a door seal on this bosch bosch exxcel 1200
Mar 28, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch exxcel 1200 express spinning slowly
Hope this helps.
Jan 07, 2010 | Bosch Exxcel WFO 2465 Front Load Washer
Aug 16, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Exxcel 1200 Express Washing Machine spin not working
I had the same problem- machiine not spinning and a few days later not turning at all. Display would go from 11min to 1min.
I did 2 things - 1) changed the brushes on the motor- cost £7.50 .
2) whilst working under the machine disconnected pipe from drum to pump and emptied it- found 2 coins in the bellows.
Nov 09, 2008 | Bosch Washing Machines
Very loud noise BUt washes fine
could be wheel on back of drum check its not loose , only way to get to filter is to remove the pump from filter assembly lay it on the soap draw side to get to it easier
Apr 04, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Loud click / tap noise every couple of hours or so
Check your owners manual for a list of common noises it should make to see if it's on that list. Does this have an icemaker? That time frame could be an ice maker valve turning on for a few seconds to fill the tray (or dumping ice).
Oct 16, 2006 | Bosch Exxcel KSR34423 Refrigerator
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
