Question about Electrolux Dishwashers
I do not know the model of electrolux dishwasher. the door pops open after the first minute after started. thank you kindly for advice
SolutionGuy
  • 331 Answers
SOURCE: Dishwasher door won't open all the way
You;ll need to remove the "kick" panel first. Use a 1/4" nut driver or socket. Then open the door and remove the 2 phillips screws that mount the dishwasher to the underneath of the cabinet. Then scoot the dishwasher out about 6 inches or so. You'll be able to use a flashlight and look closely at the door hinges and spring assy. to see what's hindering the full extension of the door. You MAY need to take the water valve off to get it to scoot out so you can work on it. Don't take the copper pipe off of the valve, just remove the screws that hold the valve onto the frame. And don't forget to KILL THE POWER TO THE DISHWASHER PRIOR TO SERVICING!
Posted on Aug 01, 2007
  • 641 Answers
SOURCE: It seems to start, then stops after a few minutes..
Jon, check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Posted on Aug 13, 2007
  • 1462 Answers
SOURCE: AEG Dishwasher 35080VI inbuilt - door pops open
usual door closure is onto a hook coming out of the top of ther cabinet just under the worktop. this needs adjusting to come out a little
Posted on Sep 02, 2008
dragonsthatk
  • 547 Answers
SOURCE: Electrolux Dishlex Door wont shut
spring it catch still working you just may need to replace it
Posted on Feb 26, 2009
mmoorree
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
The problem seems to be the loosening of the screws that hold the interior stainless steel skin to the door frame--not the latch.
With the door in the open position you should find a total of twelve screws (5 on each side and 2 on top at each side of the latch). The screws have a particular type of head which may require a trip to the hardware (its a $1,000 dishwasher take the time to get the right screwdriver). They are called TORX screws the size on my dishwasher was a T 15. These type of screw heads were designed to fit automated torque drivers at the factory that set the screws to the proper tension. So some care should be given when you retighten them. Turn until the screw is snug and there no movement of the inner door skin but don't over tighten. Giving it that extra 1/4 turn can be enough to strip the screw out and create a bigger problem.
Yes--you shouldn't have to be doing this to a KitchenAid appliance that cost this much--but I suspect that this will become a feature of periodic maintenance. The heating and cooling generates enough movement that overtime these screws work themselves out. My wife who was the once to make the right diagnosis noticed that the screws at the bottom were almost entirely out.
Posted on May 07, 2009
Why can't I get the lights to go on to start it?
Hello Vanessa, thanks for your submission!
I understand that you are unable to operate your Electrolux dishwasher and the lock symbol on your control panel is on. This means that your dishwasher control has been locked and you would need to disable it in order to start the dishwasher. If you could provide me with your model number I can explain how to disable the control lock. You can locate the serial tag (which lists your model number) on the inside left hand wall of the dishwasher. With that information I can assist you further. -Matt
Apr 10, 2016 | Electrolux Dishwashers
;dishwasher on loc - cannot release
Hello Ruth, thank you for your post!
From what you have described your Electrolux dishwasher is stuck on loc and delay start continues to operate. I would suggest performing a reset on your dishwasher and you can do that by disconnecting power from it for at least ten minutes. If you continue to experience issues with your dishwasher can you respond back with your model number? You can locate the serial tag (which lists your model number) on the inside left hand wall. With that information I will be happy to help you further. -Matt
Mar 06, 2016 | Electrolux Dishwashers
Where can I get a Electrolux dishwasher guide from?
Hello Friend, that's a great question!
I can help you locate the guide of your Electrolux dishwasher. May I have your model number please? You may normally find the serial tag, which lists your model number, on the right side as you open the door. Thank you! - Z
Jul 21, 2014 | Electrolux Dishwashers
F0
Hello Friend, this is Z. I am pleased to help you!
I see that your post is listed under Electrolux Dishwasher; however please help me understand what your concern is? Is your dishwasher getting an error code F0 or are you seeking an Owner's Guide? May I have your model number please? The serial tag, which lists your model number, is typically located on the right side as you open the door. Thank you!
Jul 14, 2014 | Electrolux Dishwashers
Elctrolux dishwasher won't start, display won't light. Any suggestions?
Good Morning Friend,
I understand your Electrolux dishwasher, model# EWDW6505GS, seems like it is not receiving power to the control panel. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. If you are still not receiving any lights, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing your control panel to not have power.. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Electrolux EWDW6505GS Fully Integrated...
Why does The pump runs continuously even with the door open?
Good Afternoon Martin,
I see that you are having trouble with the pump continuously running on your Electrolux dishwasher, model number ESL6114. From this model number, I am showing that this is a European model and questions would need to be directed to the manufacturer in that specific country. I could possibly find a number for you if I can kindly give me the country you live in or the country where your dishwasher was manufactured or purchased. Looking forward to hearing from you.
-Best Regards-
WP
May 08, 2014 | Electrolux 23 in. ESL6114 Built-in...
Electrolux Dishwasher door won't close or latch shut
Contact a professional to replace the door switch or adjust it.
Aug 07, 2012 | Electrolux Dishwashers
Electrolux ewdw6505gs model dishwasher commd panel does not power
Read publication 5995509477 of Electrolux name factory Parts Catalog. You will see the POS NO 12 Part no 7154671401 name Latch Assembly, door w/shield. This relay stay open. a little bit of WD-40 and he working correctly.
Apr 22, 2010 | Electrolux EWDW6505GS Fully Integrated...
Electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
Aug 31, 2009 | Electrolux EDW5505ESS Built-in Dishwasher
Aug 13, 2007 | Electrolux 23 in. ESI6104 Built-in...
Dishwashers Logo
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
