Question about Xerox Office Equipment & Supplies
How do we fix the error chainlink=123-314 appearing soon after powering the machine
Our Xerox machine says controller error error 116-324
Someone printing a web page or a document with text/image that the machine does not recognise. Delete the job from the server or PC from where it is being forwarded to the machine then power on machine. If the job is stuck on the machine queue then power on and as soon as the print job appears in the queue on the machine you need to deleteit. May have to log in as admin.
Jul 19, 2016 | Xerox Phaser 6600 Color Laser Printer...
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
It appears F13 error
hi sir we have ARISTON washer and DRYER model : AQXXMD129EX its a error coming F13 please help me soon
Dec 21, 2010 | Ariston Technologies AWD120 13 lb. Washer...
A pink colour line appear on me Dell studio1555
this is a problesm with the video card and/or the screen, it dont have more solution than replace the hardware, but in my opinion we spend the same money buying a new computer, as time passes the line is going to become in 2 lines and 3 ... etc
Oct 11, 2010 | Dell Studio s15577914CBK 1557 Laptop...
Erorr code 10-327
reset ur fuser module
press 0 and hold for 5 second than press start button
enter passcode 6789 and press confirm
press machine status and press tools on touch screen
press maintenance and diagnostics
nvm read /write
type chainlink 744-220
enter new value 0 and save
after close the log
restart ur machine
Sep 25, 2010 | Xerox CopyCentre C128 Black and White...
CANON GP405 ERROR E014 PROBLEM
when I start my machine the error code e014 appears and machine do not run.
Dec 24, 2008 | Canon imageRUNNER 400S Copier
Changing the drum
I fixed the problem (following the user's guide).
1. After reinstalling the new drum unit into the printer, keep the front cover open.
2. Press "Clear/Back" on the machine
3. Press "1" and when the LCD shows "Accepted", close the front cover.
May 14, 2008 | Brother DCP-8040 Copier
Kyocera Mita KM 1500
Still sounds like there is a problem with the fuser unit. The technician that replaced the parts should be able to troubleshoot the problem.
C6 = Fuser error. The unit is not heating up due to a bad Fuser lamp, fuse, or thermostat, or bad thermistor.
The circuit is open, and the machine won't work til the problem is repaired. Once open circuit is repaired/closed, the machine should reset on it's own after you power the machine down and back up.
Does the machine flash the C6 right away as soon as you turn it on OR, does the C6 show up after about 3-5 minutes?
If you get the C6 right away, then the circuit is open, and that needs to be fixed.
If you get a c6 after 3-5 minutes, then there is a good chance the lamp is bad.
Hope this helps.
Good luck
Feb 08, 2008 | Video Cameras
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
