Question about Water Heaters
Valliant vrt350f boiler heating generator fault
3 Suggested Answers
mrhotandcold
  • 248 Answers
SOURCE: Boiler not operating for the central heating
overheat stat
Posted on Oct 21, 2009
packrat1948
  • 528 Answers
SOURCE: i have a valliant ga
Match it up with the factory one and see if it still happens.
Posted on Feb 08, 2011
How do i reset the thermal cut off switch on a vaillent boiler?
Hi, what model Valliant and are there any fault codes showing?
Feb 21, 2015 | Water Water Heaters
Water to hot for gas boiler boiler gos off
It could be dyslexia, but I think you want to know what may be wrong with your boiler in this case!
This is a VERY old design. The diaphragm is on the water section, this operates a switch to turn ON the pump, and a further device causes the diverter valve to divert boiler water from CH duty to HW duty.
From your description it appears that the boiler is shutting down on internal boiler water temperature (too high), your 'briefly too hot' HW symptom may be caused either by the boiler side of the secondary heat exchanger being blocked/caked in sludge, OR the DHW side of it being scaled. Either way a new or replacement (descaled) secondary heat exchanger MAY inprove things. It's not easy on these old clunk-pots, and EVERY disturbed seal will subsequently leak, so get a good supply of o-rings and fibre seals before you start ("you" being the competant fitter you employ)
Dec 20, 2012 | Water Heaters
Valliant vuw 282 boiler
check gas pressure and when water gets cold see if voltage to gas valve loose pressure switch wiring could also do it or unit overheating and shutting off
Dec 17, 2017 | Water Heaters
My dad has a valliant boiler VP4 ZE15 IT IS AROUND 3 YEARS OLD IT ISNOT IGNITING I HAVE TURNED PRESSURE UP AND HELD THE BUTTON IN FOR A MINUTE. i CANNOT FIND WHWERE THE RESET BUTTON IS TO TRY THIS PLEASE...
Turn the power off at the wall , wait 60 seconds and the boiler will automatically reset.
Modern boilers are complex re safety and the boiler will only start if the exhaust fan is running and is up to speed .
The vacuum caused by the fan trips a switch and allows ignition to continue
If the pilot light does not come on it does not warm up the thermocouple which turns on the main gas valve.
If you go to the Valliant website they will supply you with a user guide
Sep 28, 2009 | Water Heaters
Brand new valiant condensing boiler installed will not work
Valliant boilers have software that can be used to diagnose the unit. The software can be purchased at the plumbing supply house that the boiler was purchased from. You can also get tech. service by email as well. It sound like there is an issue with the electrical controls with it. Or the controls were wired wrong.
Technical enquiries 01634 292392 or technical@vaillant.co.uk
Apr 01, 2009 | Water Heaters
Valliant turbomax manual
hi ian
most boiler manufacturers now days have downloadable manuals on there web sites.
just type in "vailant boilers" and flix through until you find the correct page. if they haven't a download you can request a copy on the "contact us" page .
i hope this has been some use
Jan 23, 2009 | Water Heaters
Water Heaters Logo
75 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
