Question about Inverter Electronics - Others
Hi.I have a1050 va sukam inverter no power on the ac output
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Check your fuse. If it's a clear fuse and you can easily see it burnt or good this will tell you if it needs replacing. If it's a ceramic fuse you can use a multi meter to check for continuity.
Posted on Feb 02, 2017
  • 3 Answers
SOURCE: roadpro rppi-1500w inverter fault light no AC output?
you have a burned resistor near the corner
Posted on May 29, 2010
SOURCE: my sukam 800 VA inverter is dead
Dear customer,
We are extremely sorry that you have been inconvenienced through a Su-kam product. However, we pride ourselves on prompt and effective customer service. Please provide us with your name, contact number and address. Please give us the complaint number and date as well and we assure you to look into the matter at the earliest. Mail us at custserv@su-kam.com, We would do our best to resolve your grievance at the earliest.
Hoping to hear from you soon.
Su-kam Executive
custserv@su-kam.com
Posted on Jul 20, 2010
SOURCE: my sukam sinewave inverter its
Hi rutabairu,
We are extremely sorry if you have been inconvenienced through a Su-kam product. However, we pride ourselves on prompt and effective customer service. Please provide us with your name, contact number and address. Please give us the complaint number and date as well and we assure you to look into the matter at the earliest. Mail us at custserv@su-kam.com, We would do our best to resolve your grievance at the earliest.
Sarita
Su-kam Executive
custserv@su-kam.com
Posted on Jul 26, 2011
  • 11 Answers
SOURCE: My Sukam Inverter is not working, even if the power is on, and its continuously beeping! so how can I direct the power, and so that the switches connected with inverter also works fine?
The first thing I would check is to make sure that the polarity is correct... IE: That you have red connected to positive and black to negative, assuming you're connecting it to a battery that is.
Many inverters will actually self-destruct if the polarity is backwards... But some of the better ones will beep instead.
Posted on May 25, 2016
  • 44599 Answers
SOURCE: I have sukam inverter 1500va, when I put it on it shows overload without any load
internal problem
have it checked out by an accredited service repairer
Posted on Jun 21, 2016
internal problem
Jun 21, 2016 | Inverter Electronics - Others
May 25, 2016 | Inverter Electronics - Others
I bought New Inverter of 900 VA?
Now Batterybhai is India's first online multi-brand battery store in India, having a complete range of 100% genuine batteries from brands like Amaron, SF Sonic, Exide, Okaya, MtekPower, Sukam, DigiPower and AC Delco. I always buy batteries and other electronic products from this store, It prices are cheaper than other stores and provides free home delivery & installation. I suggest to all my friends and customer who wants to buy batteries and inverter must visit this store.
Jun 03, 2015 | Inverter Electronics - Others
Sukam 800VA inverter continuously beeping with 3 lights blinking. What could be wrong?
check batry voltage or 2nd problem in realay and capicitors or
3rd ic before that disconnect output line
May 05, 2014 | Computers & Internet
Can I use an 18 volt universal AC Power Adaptor on Fujitsu Lifebook P7120 which is a 16 volt laptop?
With voltage step down power supplies, output power is more important than data plate output V (volts). V times output A (data-plate amps) equals output Watts (or VA) under normal load. If the voltages are close and the output watts (VA) are very close (one or two watts) you are in luck as long as the connector is same size; AND THE POLARITY (+ & -) IS THE SAME for the old and replacement unit!
Jan 17, 2012 | Fujitsu LifeBook P7120 Laptop AC Power...
My sukam sinewave inverter its output is less than 10volts
Hi rutabairu,
Sarita
Su-kam Executive
custserv@su-kam.com
Jul 25, 2011 | Electronics - Others
My sukam 800 VA inverter is dead
If the regulating circuits 78xx had blown it means that the input voltage which may be 18 - 35 VDC has been fed to all ICs. Some of them or all may have burnt. I did not understand which crystal did you change (the 2 - 20 MHz Quartz may be), but I think that rather the PIC was damaged.
If you have Oscilloscope on hand, check the oscillations on PICs clock.
Jul 18, 2010 | Inverter Pure Sine Wave 1500w Inverter
Xantrex Inverter/Charger has no AC output
HI
Checking AC Output
1. After the battery voltage and connections have been checked, disconnect the inverter.s AC output wires from
the power distribution system and connect a light to the AC output of the inverter/charger.
2. Disconnect the remote panel to eliminate it as a possible problem.
3. Turn the inverter ON using the power switch on the front panel of the inverter. The 100-watt light should
illuminate. Measure the voltage at the AC output wires using the multimeter. The reading should be 114.126
VAC or approximately 230 VAC if the unit is an international model. If the light does not illuminate, there is
a problem with the inverter. Contact Xantrex technical support.
May 21, 2010 | Kitchen Ranges
I have a xantrex xplus 400. The power and fault led light up as soon as it is plugged in with no ac output.
If you have a load that is more than this inverter will take it will not output anything. Try just a light bulb if this does not work then the output if fried or the output fuse/breaker if it has one is blown.
Feb 16, 2010 | Xantrex Technology DC to Dual-Outlet AC...
Power inverter pc 500 once u put power to it the red light comes on and beeps but no a/c power
Hi there
Not a great solution but makes sense.
the ac adaptor for your alienware probably says input 240V ac 1.5Amps whilst the inverter can output 175W= 240V ac at 0.73Amps.
I am surprised it actually worked, i had to buy a 300W inverter to run my laptop. would suggest you do the same.
inverter is probably toast now anyway.
Feb 25, 2009 | Alienware PC Systems 175 Watt Power...
Electronics - Others Logo
1,292 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
