Question about HP Pavilion DV5234US Notebook Laptop
Stuck DVD tray
The DVD tray is stuck shut on my HP laptop. When I press the manual eject button, a light goes on, the drive makes noises, but the DVD tray does not open. I have tried sticking a paper clip into the hole in the door, but that has not helped. This tray is really stuck fast. I have also tried banging the tray, and even prying the tray gently, but with no luck. Since these method do not work, are there any other methods I can try?
  • HP Master
  • 32,281 Answers
Turn off the computer and then use the paper clip to open the DVD tray.
If this doesn't work, then something is jaming and stopping the tray from opening. In this case, remove the DVD drive and dismantle the drive (ie. remove the metal cover to reveal the internal components and remove the CD ot DVD disc.
If nothing works the the DVD drive is faulty and needs to be replaced, these drives are not expensive.
Posted on Jul 21, 2009
Acer aspire dvd wont open with eject button
Whether you use your DVD drive to install software, make backups of your personal files or watch movies, having that drive onboard makes your computer more useful and more versatile.
While DVD drives function normally most of the time, sometimes a DVD will become stuck in the drive, and the tray will refuse to open.
Knowing what steps to take to resolve the situation allows you to start enjoying the advantages of the DVD drive again.
Log on to your computer and click the "Start" button. Choose "Shut down" from the menu and then choose "Restart." Wait for the computer to restart, then press the eject button repeatedly.
Remove the DVD if the drive pops out.
Since there is no hole skip this and go to cleaning the lens.
Shine a flashlight on the DVD tray and locate the small hole near the eject button.
This is the bypass hole and it allows you to eject a DVD when it becomes stuck.
Insert an unbent paper clip into the hole and push it in until you hear the DVD begin to spin. Push the paper clip in until the drive pops out.
Remove the DVD and insert another one.
Use the bypass hole again if the new DVD becomes stuck.
If the new DVD sticks as well, you need to clean the laser lens on the DVD drive.
Insert a laser lens cleaning DVD and close the tray.
Run the laser lens cleaning program at least three or four times to make sure the lens receives a thorough cleaning.
Restart your computer and insert a DVD to test the unit.
Oct 19, 2012 | Lifetime Acer Aspire 4810TZ-4011...
Dvd stuck in cpu
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
Apr 01, 2012 | HP Compaq 6830s Laptop
Hp 6930p the dvd drive is stuck (doesn't open)
Hello gilaz111, to 'open the DVD Drive "Tray."
Look by the {side} of the [Tray].
There is a Pin-hole located right next to the"DVD Eject Button"
The best "Tool" to use is a [Paper Clip] or a 'small object' similar to it.
Place the "Paper Clip" in 'gently' and "Push."
'If all goes well?'
The DVD Tray will open!
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 17, 2011 | HP EliteBook 6930p Notebook PC
Loaded a cd to upgrade firmware, firmware would not load. eject button would not eject. read manual, says to push eject at the same time you plug in the electric cord,still would not eject. Any...
Please try in this way.
Disconnect power.
Connect power back, and keep REPEATEDLY pressing the eject button while you connect. If still no ject press power on button while you keep hitting the ehect button. You need to press eject on the unit, do not use the remote.
If that does not work, then the unit must be taken apart.
Dec 09, 2010 | Cameras
DVD tray will not go in
To verify there is nothing stuck in your drive, turn off your computer and try manually pushing the tray in GENTLY and feel if there is something blocking the tray moving. If there is nothing preventing the tray from moving manually push the tray in - start your computer and try it again. Use the eject function in windows explorer and try the retract button again. If teh button will not work try pushing the tray in manually again. Once the tray starts moving in it should automatically retract the rest of the way. If the unit will not retract on it's own by either method then the drive should be replaced.
Jul 29, 2010 | HP Pavilion Slimline S3123W Desktop PC -...
Well we have a acer computer and the cd drive is stuck
If pressing the eject button does not eject the tray, look for the small pin hole on the cd drive and insert a paper clip to press that hole. It would manually eject your CD tray. Hope this helps.
Nov 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
Will not eject DVD is working is stuck I think I might need to open laptop
Power down the laptop and restart it. As soon as it restarts press the open button on the dvd drive and it will open. You may have to try a few times but it will work.
Sep 29, 2009 | Dell Studio 1737 Laptop
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
Stuck CD/DVD tray on HP Pavilion laptop
hi ther
how r u ??
u just do it manuly but not by the button
in teh tine hole poke it with a paper clip try it untile u get resistance and push
if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 22, 2008 | HP Pavilion DV5234US Notebook Laptop
Stuck dvd disc.
Hi there
Page 80 in the instruction manual tells you how to do this.
In case you don't have a manual, do the following:
While the unit is off, press and hold the stop key (shown on the unit as a button with a small black square on it) for about 5 seconds. It may take longer to eject depending on the disc.
Hope this helps
Feb 24, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
HP Pavilion DV5234US Notebook Laptop Logo
465 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
