My machine 5335 but i changing 5235 machine fuser roller, sir its same roller
5 Suggested Answers
tech435
  • 284 Answers
SOURCE: UF-8000 jamming and not transmitting consistently
what exactly is the error code on your machine, and if you replaced some of the fuser parts already you might have pinched the ribbon cable by the fuser
Posted on Nov 05, 2008
  • 4 Answers
SOURCE: fuser problem with Brother MFC 9420CN laser all in one
Unplug the printer and allow it to cool.  Then gently wipe off the surface of the photo-sensitive drum with a cotton swab.  If this doesn't work you may need to replace the drum.
Posted on Dec 02, 2008
DellTech1
  • 52 Answers
SOURCE: change rooler on fuser
The process in general is lengthy.. If you can get to the spot where the pinch rollers are, and if the symtoms are paper not pulling through.. I watched my Service Group, that I use to hire, use regular rubbing alcohol on the rubber wheels, as they get dry and slick ? ..and this renews the grip again. This also will clean your main fuser roller when you use the wrong paper in it .
Posted on Aug 08, 2009
zakirdgl
SOURCE: paper is getting stuck in the fuser rollers
remove the fixing unit and clean the charge roller (aluminume roller) in case you are cleaned for long time this coudbe in black color clean well and refix it, the machine will be alright.
Posted on Mar 05, 2013
I have copier ir 400s sir i am getting error when i started the machine the error is E014 thank you
This is an indication that the fuser ( hot rollers on left side of copier ) are not turning. This could be caused by several things. Try turning the green knob behind front door. Does it move smoothly? If it doesn't then remove the left side fuser door and remove the fuser assembly. The bearings for the upper and lower rollers could be bad. If the fuser moves easily, then it could be a white gear that is located on the upper right of the fuser assembly. This is the drive gear for the fuser. The gear tends to wear out over time and has to be replaced. This should get you in the right direction to solve the problem.
Mar 28, 2011 | Canon imageRUNNER 400S Copier
I need the unique code for nokia 5235
1 - Switch on your Nokia 5235 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5235.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5235 would then display the message "SIM Restriction Off" and will be unlocked!
Each Nokia 5235 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 5235 mobile phone at www.mobileunlocksolutions.com.
Feb 11, 2011 | Nokia Cell Phones
Sir, i have Konica 7145 machine. i have any 10 mints after F-35-3 error, or some time F-35-9 eroor
Hi the error codes you are getting f-35-9 and f-35-3 are common error codes for this machine
First do not reset the machine using 25 dipswitch 3-1 until you resolve what is wrong
The errors are related to the fuser unit assembly parts f-35-3 is the th1 thermistor f35-9 is also an issue with th1
I can tell you that the thermistors th1 and th2 have been changed a nuber of years ago you will need to replace them both also any other parts in the fuser like the web upper and lower clas adn rollers busings ect there is a fuser kit that you can purchase from konica it comes with all the parts to replace on the fuser unit
when replacing the parts on the fuser unit this must be done by a certified technician only if you are not trained to do this leave it alone
The best option is to replace the fuser unit assembly and have it installed by a certified engineer you will save a lot on labour
Once the new unit or refurb unit is done you will need to switch of machine hold down 2 and 5 at the same time switch on the machine and then go into dipswitch 3-1 and change from 1 to 0
Jan 20, 2011 | Konica Minolta Office Equipment & Supplies
I have a 7750 xerox printer. paper keep wraping around the fuser roller and jamming. the fuser has been used for only a short time. Is this a damage unit and need to be replaced or is there something I...
Hello sir; Try to move out fuser unit, check the fingers against the fuser rollers, does it build up toner on the finger tip if it does, clean it up otherwise replace it.
Nov 06, 2009 | Xerox Phaser 7750DN Laser Printer
BLACK LINE
Greetings,
usually this would be either a cartridge or a fuser.since you changed a cartridge and it's still there.most likely it is the fuser.
you could double check by doing a half stop test.start a print from tray 1 and when the trailing edge of paper is just entering the machine,open the printer to stop print and take out the cartridge,open it's shutter and look at it's drum and the paper just underneath.if the issue ios not at either of those places,then probably the fuser.
if you take out the fuser ,you may be able to see an issue with a fuser roller.like a tear or other anamoly.
Also More than likely your fuser is peeling. Pretty easy to check...power down printer and pull rear door then unlatch the fuser and look at the fuser rollers...more than likely the bottom roller is peeling on one side...you'll know it when you see it...
Regards,
TechSup1
May 01, 2009 | Lanier 5235 Printer
Paper coming out from the tray is folded for richo 2015
You do have a fuser problem. There are a set of stripper fingers that are supposed to keep the paper from wrapping around the heat roller. One of them may be damaged and is catching the paper. The Pressure roller can also cause problems if it is torn. You need to have the fuser looked at by a tecnician to determine the problem. Hope this helps.
Jan 26, 2009 | Ricoh Aficio 2015 Copier
Copy machine problem
hello, sir
i have a photo copy machine of canon ir2018N.
my problem is when i start my photo copy machine his inistailzation process start and then given to messeage System ERROR E261 is show.plz sir slove this problem very urgent.thanks
Nov 24, 2008 | Office Equipment & Supplies
Paper struck
Fusing rollers are not turning, Grease the bushings / bearings.
Perform Shipment Set.
May 27, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Minolta CSPRO EP2030
You Can make reset for this code by: 1. Open the front door of the machine & lift the upper half 2. Turn the machine on 3. Locate the srvice switch on the main board( backside of the machine you can reach even without opening the back cover) 4. If this code is coming from time to time just change the upper heater roller
Oct 05, 2007 | Office Equipment & Supplies
k24674
jasbo
jasbo
