Question about Car Audio & Video
I can't get the face plate off the box to replace speaker. Help please
2 Suggested Answers
kenw392
  • 2226 Answers
SOURCE: replacement face plate
try pacparts.com
Posted on Sep 14, 2009
Steps to Replacing a Clutch on mitsubishi express
for the full steps then get a workshop manual as there are some details that will be missed . Basically it is Remove the battery terminal. remove the rear drive shaft ( front also if 4wd). Remove the gear lever at the tower bolts on the gear box. Drain the gear box or be prepaired for the gear oil to run out the end of the transmission when you pull the box. . Place a bottle jack under the sump at the rear of the engine . Place a trolley jack under the gear box. undo the rear transmission mount cross member Undo all the bell housing bolts. lower the jack and the trolley jack and pull the gear box back. Undo the bolts holding the pressure plate on the flywheel a bit each at a time as you go around the plate . Remove the plate and the clutch plate ( be aware that the clutch plate will only go back in one way so watch the way the clutch hub was facing. Remove and replace the bearing in the back of the crank shaft. clean up the flywheel face ( good idea for a good non shudder job is to have the flywheel re-machined ) fit the clutch plate the right way and fit the pressure plate . Use a clutch aligner tool as it will be impossible to fit the gear box with out it. Replace the clutch throw out bearing. Now re install using the reverse processes As I said a manual shows it all
Dec 14, 2013 | Cars & Trucks
Install clutch on 1996 f150 302 5.0
Drop the tail shaft . remove the gear lever from inside the cab. remove the housing bolts and pull gear box back out of the way. remove the clutch pressure plate by evenly undoing the pressure plate cover bolts. lift away along with the clutch plate Remember the way the clutch plate is facing as it will only go in one way. If the flywheel is badly blued or scored remove it and have it machined flat. Check and if necessary replace the bearing/bush in the end of the crank shaft. Fit new clutch plate the correct way or the flywheel bolts will hit the clutch plate and you will have to do the job again. position up the pressure plate and use a clutch aligning tool to hold the clutch plate exactly in line with the bush/bearing in the crank. tighten up the cover plate bolts evenly so as not to warp the pressure plate. Replace the clutch throw out bearing as it will be on the way out. Reposition the gear box back on to the motor making sure that the flange faces remain parallel at all times so that the splines of the input shaft do not bind on the clutch plate splines. Push the gear box all the way home and bolt up. Do not use the bolts to pull the box in as there is something wrong and you will damage something. The box will go all the way home easily if you have done everything correctly. Finish the job.
Oct 13, 2013 | Cars & Trucks
I have a 1991 toyota pickup with a 3.0 liter v6 4x4 with a manual transmission, it would only go into gear if i shut the motor of shifted and restarted other wise it will not go into gear with out...
indicates you have installed the clutch plate incorrectly
the raised hub section is hitting on the flywheel bolts instead of facing back into the pressure plate
opening
only fix is box back out and turn the plate around
Sep 22, 2017 | 1991 Toyota Pickup
I have a non-lighting Cobra 29 NW face plate, or EL Driver problem . EL Driver is the small metal box mounted inside, to the side, of the the Cobra 29 near the channel selector control . Can anyone tell me...
that is a power inverter. dc to ac inverter. 13-14volts to 40+ volts ac. to run the el display.. if the display is pulled away from the face like the glue is coming loose that indicates the el display is burnt and will not work unless replace the face plate the el face.. you should have 45volts AC on the two wires feeding into the main chassis face to the el display.
Nov 28, 2009 | Cobra 29 LTD CB Radio
Kenwood KDC - MP 235
I would also check the speaker outputs from the deck. If any of the speaker outputs are touching any metal on the vehicle, it could give that message.
Dec 08, 2008 | iLO XM-MP3-CD Car Stereo
Z2300 satellite disassemble
1. Remove the black face screen. 2. The 4 holes on the satellite that hold the face screen on have a rubber stopper in each.  Pop those out with a screw driver.  There are now 4 screws to take out. 3. The front silver face plate is now only held on by glue.  Take a hair drier around the edges to soften the glue, then carefully pry the front face plate off, being careful not to damage it (I pried it from the bottom so any damage wouldn't be noticed).
Note: the 3 screws on the bottom have nothing to do with removing the face plate.
Sep 28, 2008 | Logitech Z-2300 Computer Speakers
Where do i find the lamp inside my tv it's a magnavox 50" projection dlp model #50ml8105d/17
Take off the speaker screen on the bottom of the set, next to the left speaker (if facing the front of the tv ) there is a plate with two screws, remove this plate and the lamp module is behind it, remove it and replace with a new one
Aug 18, 2008 | Televison & Video
Detachable face plate for DEHP47DH on and off buttons and other function buttons not working.
make sure the connections are clean on face plate and base make sure no grease or anything like that failing this then contact the makers or even place of purchase usually as long as you have the face plate and the whole unit they will replace the face for free but you might need to show them both as stolen ones people were getting the face for free so they stopped this so get in touch with makers or even place of purchase they should replace for you.
How old is device?
Have you tried pushing the face in whilst pressing it on further just in case the connections are not touching.
Do any buttons work?
Apr 21, 2008 | Car Audio & Video
Face plate replacement
You can't find faceplates for card decks since that will defy the safety feature.
Mar 19, 2008 | JVC KD-AVX33 Car Video Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
