Question about Xerox Office Equipment & Supplies
Hi sir xerox machine 5335 and 5235 fuser same? please answer me
5 Suggested Answers
  • 24 Answers
SOURCE: Where to put fuser oil in a xerox 5624 copier
I don't believe this machine uses Fuser oil. I bet it was picked up from a sight that had other machines and the oil was just put inside the machine as it was being wheeled away.
Posted on Sep 09, 2009
Testimonial: "Thank you, this is the most common sense answer that I have heard from the USA to India!"
SOURCE: Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Posted on Jul 04, 2010
  • 239 Answers
SOURCE: Need to replace the fuser unit kit in a xerox m20 copy machine
First unplug the machine.
Open the right side door. there are four screws to remove. Unplug the two plugs to it.
Pull out the fuser modual.
Insert the new fuser modual, and release or flip the green jam tabs.
When put on the four screews make sure not to over tighten, just a gentle snug is needed.
Close the door, pug machine, and turn it on.
If the fuser fan is not working, this can cause the fuser to over heat again. Make sure the fan is truning by viewing it from the back.
Good luck.
Posted on Aug 23, 2010
  • 5 Answers
SOURCE: sir 010-398 in my colour xerox machine model no
010-398 Fuser Lock Failure RAP
Description
The Fuser Fan failed.
Power OFF/ON
Procedure
Turn on the power.
Visually check the rotation of the Fuser Fan
Posted on Feb 26, 2011
Xerox Fuser will not warm up? Any idea why?
The fuser is nothing more than a heater element. One fuser is broken and the other isn't. You need a new one.
Or did you mean the broken one works in the other machine? In which case the power to it is disconnected somewhere.
Dec 27, 2015 | Xerox WorkCentre 4150 Black and White...
Kyocera xerox machine c-6 400 error
fuser related
=clear jam if any.
=reset error
clear - 1-0-8-7-1-0-8-7 -- 163---ok
=replace fuser if damaged
Jul 09, 2014 | Kyocera TASKalfa 180 Copier
Sir 010-398 in my colour xerox machine model no 1632 plese give me solusation whats problem give me answer
Description
Power OFF/ON
Procedure
Turn on the power.
Feb 26, 2011 | Xerox DocuColor 1632 Laser Printer
Xerox Workcentre C226 - Error H5-01
This might help, but I don't know how to put it in tech mode.
"The fuser error reset code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on."
Jul 29, 2009 | Office Equipment & Supplies
Xerox Work center Pro 423
The most common explanation for the error 'U4-2' in all the 'Xerox' machines is "Fuser warm up failure occurred". I am very sorry that such a problem has occured for you. It cannot be solved by you, if you are not a qualified technician and without proper tools.
Please do call the nearest service centre for a visit and they will probably solve it in a day. Remember, they need the service manual procedures for solving it properly.
Don't worry, it is a very common problem. But only authorised service people can help you in a good way.
Bye
Have a nice time.
Nov 22, 2008 | Office Equipment & Supplies
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Jan 02, 2008 | Panasonic DP-150A Copier
26 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
