Question about Refrigerators
When I start of a/c unit the condenser fan is run but the compressor is not running
    Top Expert:
  • Refrigerators Master
  • 46,732 Answers
Could be a problem start/run capacitor or failed compressor motor
call an accredited ac technician for a proper diagnosis
Posted on Dec 29, 2016
  • 26 Answers
SOURCE: sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Posted on Oct 24, 2008
  • 833 Answers
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
peyton32034
  • 410 Answers
SOURCE: Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Posted on Jan 20, 2009
  • 1218 Answers
SOURCE: beverage air mt 17
their web site says it is to maximize defogging.
http://www.beverage-air.com/images/glassDoorMerchandisers/manuals/809-005A.pdf
See if you can get to their web site. In the operations section, under initial start up, it talks about this. Can't find anything else on this.
Good Luck-Hope this helps.
Posted on May 24, 2009
imufo2
  • 3773 Answers
SOURCE: Refrigerator & frezzer no longer
HI,
Yes, very much. The fan has to be running every time the compressor does/
Check power to fan before you condemn it then replace it.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Posted on Jul 24, 2011
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Tip
Replacing a condenser fan in centralized A/C
On of the common problem with centralized A/C unit is a bad condenser fan. I have known people who called an ac technician to fix their ac because of a bad condenser fan and suggested replacing the whole unit! Costing them a lot of money when all it needed was a 50 dollars condenser fan! If the condenser fan do not run or it runs only when you give it a push, it'sbad. You will also notice that it is vey hot. When replacing a condenser fan you may want to replace the starting capacitor too. Replacing a condenser fan is not very hard, just make sure that the power to the ac unit is turned off at the breaker box. Confirm that the wires are not live by using a meter or an ac tester. The fan motor are held with brakets sometimes just screws. Most fan you can buy that has reversible rotation by just reversing the plug. Make sure it is blowing upwards. If not reverse the rotation. So if you notice that the unit is not putting out cold enough air and you went outside and noticed the compressor running but not the fan, turn off the AC right away and do not use it untill the fan is replaced. Running the unit with a defective fan can damage the compressor caused by overheating.
on Jul 10, 2010 | Heating & Cooling
HVAC fan is on, but the compressor attempts but will not start
Sounds like you have a condensing unit that has a lock up condition; commonly known as "Locked Rotor'.
A simple step would be to be sure the compressor is cool.
Start the unit, and as it try's to start, bump the compressor on the shell sideways to jar it , with a rubber mallet.
If the compressor starts... it may or may not start again at one point.
You can try adding a start assist, or commonly known as a Hard Start Kit. It's simple and the two wires go on the Run Capacitor In parallel with the wires with the compressor wires.
Usually the capacitor has a C common ..F fan.... and M motor terminals . The start assist wires piggyback on Common C and M motor. NOT THE FAN side of the run cap.
http://www.grainger.com/product/SUPCO-Hard-Start-Kit-4E240
Apr 30, 2014 | Heating & Cooling
U-Line ice maker compressor won't run
Dose compressor fell too hot ? There could be several things wrong. First you will need to get out your Volt meter to make all test. With unit calling for freeze cycle the condenser fan and compressor should be running. Check at the compressor to make sure your getting power to the over load switch and then through it to compressor. if not then check to see if compressor is to hot and has the switch open> If so then unplug unit to let compressor cool down so switch will close. when switch closes plug unit back up and start up unit check to see it compressor starts if so then you will need to see what is causing compressor to over heat. could be dirty condenser, low charge, fan dropping out, Bad compressor.
Mar 07, 2014 | U-Line Icemaker
My condenser fan runs and blows cool air but isnt cooling down the house. Any help.
Check the outdoor unit (condensing unit). Keep in mind, because the condenser fan is running it's not an indication that the compressor is working. On a split system,there's a dual capacitor that serves the fan and the compressor. The capacitor has three terminals.
1. common
2. fan = fan
3. Herm = compressor
This is a common problem; The outdoor fan (condenser fan) runs, but not the compressor (you have to know the sound of a running compressor or you'll mistake it for the sound of the fan) doesn't, because the compressor side of the capacitor is too weak to give it that needed phase angle that it requires to start. If you're referring to the outdoor fan spinning, but no cooling, I can bet the compressor isn't working and needs a new capacitor. Very common problem, I see it all the time. Before you change the capacitor, make sure that you cut the power to the unit, and then use an insulated tool such as a screwdriver and short the terminals together first. A capacitor holds a charge even after being de -energized.Buy the new one with the same exact rating written on it as the old one. Do not mix up the wires when replacing. Write it down or take a picture with your phone
Aug 20, 2013 | Heating & Cooling
Can't lower cooling temp
Is you indoor fan running? Is the out door unit running? (Condensing Unit) If both are true, is the larger of the two copper lines on the Condensing Unit colder than the smaller one? If not, is the compressor in the Condensing Unit running? The compressor is the big can under the fan in the Condensing Unit. Please reply to this as you may need a service tech. at this point.
Apr 01, 2011 | Heating & Cooling
Hi, I have a goldStar GA 1866VHR split Airconditioner, (5050w cooling and 5040w heating capacity). Today I noticed that compressor/condenser unit was still running after I turned off the aircond: from the...
Thanks for your detailed information. But solution is very simple. The compressor contactor in out door unit. Struck. And hence, when you power on, without indoor commanding, the out door starts running.
Replace same type Contactor relay (In out door unit) immediately. Hope, it's helpful.
Jan 19, 2011 | Heating & Cooling
What controls the condenser fan?
Your condenser fan motor should run any time the unit is calling for cooling, if the compressor is running, the condenser fan should also be running.
Hope this helps....GOD BLESS....Randy....
Nov 07, 2017 | Sub-Zero 650 / O Bottom Freezer...
Refrigerator and freezer both are not working. fan in back of unit running but internal fan not running. i also cannot hear the compressor kicking on.
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
A/C FAN MOTOR SHUT OFF, BUT CONDENSER KEEP ON RUNNING
The condenser fan might be going out. It'll start when cool but shuts off as soon as it starts to warm up.
Jun 28, 2009 | Heating & Cooling
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
