Question about Printronix Office Equipment & Supplies
I want to print 15in x 11in document in Printronix 7010. I already create custom paper in driver, but when I print my document I got error "EXECUTE form too wide for current setting"
  • 883 Answers
SOURCE: Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
Posted on May 31, 2007
  • 38 Answers
SOURCE: "Shuttle jam" see manual problem on Printronix line matrix P 500E printer
Verify that there is nothing clamped between the platen and the shuttle.
Last time I had this fault, it turned out to be a broken wire in the harness that connects the CMX board to the shuttle module.
Other possibilities include a failed shuttle or CMX board.
Steve W
LazerTek LLC
Posted on Jul 17, 2008
  • 1901 Answers
SOURCE: Custom Paper Sizes for HP Photosmart C3180
I have a 3100 series HP. On it you select "Properties", then the "Features" tab. On that tab, there is a "Resizing Options" menu item. It has a drop down menu with "Letter", "More...", and "Custom" choices. There you can define the size.
Posted on Oct 15, 2008
  • 76 Answers
SOURCE: Printer prints all pages on one sheet of paper
what application are you printing from? also, can you do a print preview to see if there are more than one page? if that works, then your printer mechanism is not following the driver information from the print queue manager.
Posted on Nov 21, 2008
  • 4 Answers
SOURCE: Can't print custom paper size on HP Photosmart C6180
Printing anything other than 8.5" x 11" I have found challenging but there is a way around it. When you are ready to print select Print and go to
"Properties" button beside the name of the Printer.
Select normal for your print quality,
Paper source select Main Tray,
in resizing options select the size you need. In this case you would make a custom or perhaps the Card Envelope 4" x 6"
Select "Scale to paper size"
under the Resolution button there is a box "Show preview before printing" I select that so that I can see for sure before printing that it is recognizing my special paper and not the usual 8.5 x 11 sheet.
If it all looks good and it should, START PRINTING
You have to do this everytime you want to print a special size paper. If you print a lot of this size of paper custom name it something easy like your name"Krissy card env" so you can find it quickly and remember easily the process you follow.
Posted on Jan 09, 2009
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Selecting Scaled Printing changes the printable area.
Hope this helps
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
Tally 6212 - Landscape Documents Printed Vertically
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
  • Ensure you are logged in with administrtor rights
  • Open the Printers Folder
  • Ensure the FORMS tab is selected
  • Tick the CREATE FORM button
  • Enter a NAME for the form
  • Enter the dimensions (be careful of the units you are using --- best results use inches)
  • Do NOT set margins printable areas etc
  • Click on the SAVE button
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
Jul 28, 2009 | Tally Line Matrix T6050 Printer
Can't print custom envelope on HP Photosmart 7280
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Nov 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
HP 1280 Error message
well...the printer settings will be the key. open them up and make certain that you're tray assignments are in line with your A4 paper.
Aug 20, 2008 | HP DeskJet 1280 InkJet Printer
How to change paper size on axerox phaser 8500
From a Windows Operating System:
  1. From the computer, open the document to be printed within an application program.
  2. Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
  3. Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
  4. Click on the [Paper / Quality] tab.
    NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
  5. Select the required paper size from the Document Size pull down menu, if available.
  6. If the required custom paper size is not available click on the [My Customer Sizes…] button.
  7. To create a new custom paper size setting click on the [New] button.
  8. In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
  9. In the Width field enter the width of the custom paper size.
    NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
  10. In the Height field enter the height of the custom paper size.
    NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
  11. Click on [Save]
  12. Click on [Close].
  13. Select the required paper size from the Document Size pull down menu.
  14. Click on [OK] twice to print
From a Mac OSx:
  1. Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
  2. From the Printer Description pull-down menu, select the correct PPD file for your printer.
  3. Select the custom paper size for your document from the Paper Size pull-down menu.
  4. If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
  5. To create a new custom paper size setting click on the [+] button.
  6. Double click on [Untitled] and enter the name to be given to the custom paper size.
  7. At the Page Size field enter the width and height of the custom paper size.
  8. Click on [OK] twice.
Apr 22, 2008 | Office Equipment & Supplies
Prints four blank pages between each printed document...
this is your data cable problem change datacable
and change setting to your computer cmos setup
go cmos setup find parralal port mode option select EPP+ECP
First you change your datacable if problem can't solve so change
cmos setup option
Aug 15, 2007 | Printronix Line Matrix P5210 Printer
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
