Question about Dishwashers
Location of thermal switch for a KUD1021RBL2 kichen aid dishwasher
5 Suggested Answers
  • 3422 Answers
SOURCE: Have a kichen aid model
Can you give me more details on your problem so that i can help you fix it.
Waiting for your reply.
Posted on Apr 12, 2008
  • 43501 Answers
SOURCE: kichen aid dishwasher leaking water
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
Posted on Dec 12, 2010
  • 2047 Answers
SOURCE: How do change a filter
Find the water filter cartridge cap, which is positioned in the front base grille and looks like a small dial. Place a towel underneath the filter area to catch any water that may drip. Turn the cap counterclockwise until the cap handle is vertical. Pull gently to remove the filter cartridge. Slide the cartridge cap off the old filter and set it aside. Remove the new filter from the packaging and take the cover off the filter. Place the cartridge cap on the new filter and position the cap so that it is vertical. Push the new filter into the hole inside the base grille. Turn the cap clockwise once the filter is completely pushed into the grille. Place a container under the water dispenser and push down on the dispenser. Fill at least 2 to 3 gallons of water, discarding them to remove any impurities that may be present in the filter.
Hope this solution has been helpful?
Posted on May 02, 2011
  • 79 Answers
SOURCE: Where is thermal fuse located on my Bosch dishwasher model number SHX 43mo5uc
Call Bosch direct. -800-944-2904
Posted on Feb 12, 2015
I cant get my dishwasher to start
Defective Door Switch?The next thing that could be causing your dishwasher to not start could be the door switch. This door switch is also sometimes called a door lock or door interlock switch. This switch is a safety feature and makes it so the dishwasher will not run if the door is open. If your dishwasher won't start, then it is possible this switch is bad. This switch is located inside the door panel. To determine if the door switch is bad, remove the control panel, locate the door switch, and test it for continuity.
Blown Thermal Fuse?Another part in your dishwasher that could be causing it to not start could be the thermal fuse. This fuse is designed to blow if the dishwasher overheats. If this fuse blows, it will need to be removed and replaced to make your dishwasher work. Most dishwashers have the thermal fuse located in the control panel area. To determine if the thermal fuse is bad, remove the control panel, locate the fuse, and test it for continuity.
Broken Door Latch?The part that holds your dishwasher door shut is called a door latch. 99% of the time this latch is made from plastic. If this latch becomes broken or cracked, it will prevent your door from closing properly. To determine if your door latch is bad, inspect your dishwasher door and be sure the latch is not broken.
Defective Main Control Board?The control board in your dishwasher supplies power to all components. If your dishwasher won't start, this could mean that the board is bad. If you have tested and confirmed working all the other steps above, then the control board in your dishwasher is most likely bad and replacing it would be a smart option at this point.
Jan 15, 2017 | The Video Game Consoles & Games
Control panel not working. Where is thermal fuse located?
Go to and enter MDB5601AWS. You may get a clue as to where to find it. You also will get an illustrated list of common replacement parts which will aid further identification.
Feb 09, 2016 | Maytag 24 in. MDB5601AWS Stainless Steel...
Water from garbage disposal backing up
Check to see if there is a loop in the drain line. The drain line coming out of the disposal has to have a loop in it that is higher than the disposal. That way water can't drain back into the dishwasher.
Dec 31, 2017 | KitchenAid Dishwashers
My Kitchen Aid dishwasher was running and we had to open door to remove something. Door was closed and button pushed to restart. No power at thr panel. Checked for power to the dishwasher. OK There is...
The thermal fuse is clipped onto the conrtol board and to check it ya would need to disconnect power to teh dishwasher and use a multimeter and check for continuity on it here is what the thermal fuse looks like oldtech2332_150.jpg
Oct 31, 2011 | Dishwashers
No power kitchen aid dishwasher mod kuds01flss6 what do I check first after checking the door switch?
Hello, welcome to FixYa.
I understand by reading your post which indicates it is a
kitchen aid dishwasher mod kuds01flss6 you appear to have a concern with no power to the control, correct ?
The one thing I'd suggest is the thermal fuse, typically the symptom you've described is associated with a bad thermal fuse. (part #
Here's a helpful link below to a video from "" to assist in changing (or simply checking it as shown in the second link) the fuse generalizes on most Whirlpool built dishwasher's such as yours, but if slightly different it is essentially the same.
I'll watch for your reply and try and help going forward. Hopefully this will provide you with the solution you seek, but please keep me posted if not.
...If so, please take a moment to rate the assistance provided for you here today. Good luck and thank you for choosing FixYa.
Macmarkus :)
Oct 12, 2011 | KitchenAid Dishwashers
I dont have the manual for the BEKO DWD 8650x dishwasher. The light for rinse aid is currently on - do this mean I need to top the rinse aid up? and how do I know how much?
There is a switch to flick behind the numbers wheel - this is located next to the dishwasher tab dispenser on the inside of the door. G
Feb 02, 2010 | Dishwashers
KUD101FKSS Kichen aid dishwasher does not work.
There are three tabs that are holding the whole assembly, accessible from the bottom...they need to come out. Only then you can remove or even move the assembly...
Apr 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
No water entering dishwasher
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely
replace it. It's usually located behind the lower access panel on the left or right side. It's the device
with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two
wires attached to it.
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor."
Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills
the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised
position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Sep 29, 2008 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
