Is it possible to make changes on a DVD player if the remote is missing
I have a DVD player which only plays black and white even on colour DVDs and has subtitles selected. It came with no remote control as the vendor could find it.
  • 56 Answers
SOURCE: color to black and white and back again
if you are using S-video cables for your video, try replacing the cable. svideo has 2 lines in it, one for color (chroma) and another for brightness (or black and white-ness (lumina) if one of those little pins is broke, or missing, or the cable is bad, this may be the case.
Posted on Aug 16, 2007
  • 3 Answers
SOURCE: Lost Remote Control
Posted on Apr 24, 2008
  • 105 Answers
Try to check the TV system it might be set to PAL or NTSC...
Posted on Jul 08, 2008
  • 17 Answers
SOURCE: Hi, how do I turn
Some DVDs can't change the Audio or Subtitles in Button of the Remote, try change in the Menu,
Try again with the Remote with another DVD Disc...
Bruno Gamba
Posted on Jul 23, 2008
SOURCE: black rectangle at bottom of screen when playing dvds on sony dvd player
Had the same problem but was able to fix it by simply doing the following:
"this is closed captions turned on your TV. get your original TV remote and look for a button that says "Captions" or "CC", and keep pressing it until the TV says "Off". if it doen't have one of those buttons, you will need to get into the menu of the TV and turn off closed captions there. It is probably set on "Text1 or Text 2" right now, and it needs to be set on "Off"
Posted on Dec 20, 2008
Have a panasonic dvd recorder model number Dmr-Ex77. which worked fine now it records and only lets us watch in black and white.
programs recorded from tuner are now in black and white
Frank, try new cables and inputs if you can, cables or inputs could be faulty.
Apr 01, 2016 | Panasonic Televison & Video
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) -, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ... > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
DVD Playback is only Black & White
Different areas use different colour systems. The most common types being PAL and NTSC. What I think you might have done is changed the colour type setting to one that is not compatible with your TV. If you have the manual look up the colour settings. If you haven't got the manual look around the main menu for them. If all else fails use the factory reset.
Mar 12, 2017 | Toshiba Bdx1200 Blu-ray Disc Player
Panasonic DVD Recorder DMR-EZ48VEB. Colour missing
I have a Panasonic DMR EH50 DVD recorder and have just discovered this evening that everything on it is displayed in Black & White (tuner, recordings, menu, dvds etc). Yesterday everything was working in full colour. I have checked all my leads and have no solution to this problem and also need help.
Jan 03, 2010 | Panasonic Televison & Video
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Plays dvds in black and white
need to change recording format!
May 18, 2009 | Televison & Video
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
