Question about Xerox Workcentre 5335/p 5335 Mono Advanced Multifunction Copier/printer/scanner
My xerox machine 5335 show in display foult code 010-338,and hide copy option in display please help its sollution
  • 2072 Answers
What that is saying is that somewhere, most likely in a print job, either the paper tray settings or the settings on the driver are incorrect.
What you need to do is look at the machine paper tray settings and see if they all say the proper size and paper type, and that they match the driver settings.
An example. See that the letter tray settings are 8 1/2 x11 plain paper on the machine and driver. Be for example that the driver doesnt say plain paper and the machine bond, or recycled, or heavyweight. They MUST match or you will receive that message.
The paper SIZE snd TYPE must match.
Posted on Aug 15, 2008
  • 10 Answers
SOURCE: Xerox XC820 Copy Machine
three lights are for paper jam, replace toner cartridge and replace dru, cartridge. If there is zigzag line it is paper jam if there are six small dots it is for toner cartridge and if it is one circle it is for copy cartdisge. You can contact me for mfurther support at
Posted on Dec 26, 2008
  • 2072 Answers
SOURCE: Need to establish PIN/Code for machine - help xerox c123
The following information describes how to register userIDs and usernames, login names, and passwords for authenticating accesses attempted through the network for scanning services, and impose restrictions on the maximum number of pages to be copied or scanned. Up to 500 user accounts can be registered.
NOTE: You must be a System Administrator to perform this solution.
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings]. The System Settings screen will be displayed.
  6. Select [Login / Auditron Administration]. The Login Setup / Auditron Administration screen will be displayed.
  7. Select [Create / Check User Accounts]. The Create / Check User Accounts screen will be displayed.
  8. Select a user account number or use the numeric keypad to enter a user account number in the Go to (001-500) field.
  9. Select [Create / Delete]. The User Account screen will be displayed.
  10. Enter a userID using the keypad on the Touch Screen, and then select [Save]. The Create / Delete screen will be displayed.
  11. Select from the following options:
    • UserID: Allows a userID to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • User Name: Allows a username to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • Password: Allows a password to be entered using the keyboard on the Touch Screen. 4 to 12 alphanumeric characters can be entered. The Password button is also displayed if a password was selected on the Login Setup / Auditron Mode screen.
    • Remote Login Settings: The following settings can be modified on this screen:
      • Login Name - Allows a login name to be programmed that needs to be entered when the machine is accessed through the network.
      • Password - Allows a password to be programmed that needs to be entered when the machine is accessed through the network.
    • Account Limit: Select [Copy Service] or [Scan Service], and then select [Account Limit]. Using the numeric keypad on the Control Panel, specify and restrict the maximum number of pages to be copied or scanned for the account. The maximum number can be entered within the range of 1-9,999,999 pages.
    • Reset Total Impressions: Deletes all data tracked for the selected account.
    • Reset Account: Clears all settings and data for the selected account.
  12. Select [Save].
  13. Select [Close] three times.
  14. Select [Exit].
Posted on Jan 08, 2009
  • 2072 Answers
SOURCE: My Xerox Copy centre C123 shows error code 124-315
Thats a weird one. The machine is detecting the wrong speeds.
Try this.
  1. Enter Diagnostic Mode ( UI Diagnostic Mode).
  2. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
  3. Press buttons 6, 7, 8, and 9 on keypad and press Confirm.
  4. Press the Log In/Out button (button with Key symbol) on the Control Panel.
  5. Select System Settings.
  6. Select Common Settings.
  7. Select Maintenance/Diagnostics.
Then look at these 3 locations and see if they match, If they do not set them to match the machine speed.
  • [700-600]
  • [700-601]
  • [700-602]
Posted on Feb 11, 2010
Testimonial: "Thankyou,and need more help. chose NVM read/write & enter value700-600, it shows 65000 current value what should i enter as new value?"
  • 57 Answers
SOURCE: Have a Xerox M20i Copier/Scanner/Fax. Display
If you look under the scan assembly you will see a yellow or green tab which locks the scan head. Try locking and unlocking it a few times then on the final unlock reboot your printer.
Posted on Jan 19, 2011
Xerox WC 5330 error Code 010 338
I think it is a toner or maybe paper issue, as a first step I would remove and re install both
Jul 13, 2016 | Xerox WorkCentre 5330/P Printer
Error code 116-330 xerox workcentre 5325
4+power saver button+stop button press&hold then machin on disply hard disk formet then machin off& on Now ready your machin
Jan 10, 2016 | Xerox WorkCentre 5325 5330 5335 Black...
Fault Code: 016-405 Xerox WorkCenter 5335
This FC (fault code) 016-405 means that there is an error with your security certificates on the 5335 .Copy the link below into your browser and type 016-405 in the search field and it will provide guidance on how to resolve this issue.
NOTE When working with security certificates on Xerox equipment it is recommended you call them for support or have your IT person investigate, this is because if you delete any certificates and not initialize them again you can break some custom services installed on your machine.If you;re not sure if you have custom services running please call your IT department or Xerox for assistance.
I hope this helps ...
Mar 06, 2015 | Xerox Office Equipment & Supplies
Xerox 5325 fault code 124-374
this error is mismatch serial no
go to dignostic mode go to adjusment other re input serial number
Sep 19, 2014 | Xerox WorkCentre 5325 5330 5335 Black...
Stop the beeping noise when a print job is done
Here is how to do this :
1.Login as the System Administrator or Key Operator.
2.Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed.
3.Select the [Tools] tab on the Touch Screen.
4.Select the [System Settings] button.
5.Select the [Common Service Settings] option from the Group section.
6.Select the [Audio Tones] option from the Features section.
7.Select the required option to configure or modify, and then select [Change Settings] button.
8.Select the required audio tone. Audio tone options include: [Off], [Soft], [Normal], [Loud].
9.Select the [Save] button.
10.If necessary, repeat steps 7 - 9 to configure each option.
11.Select the [Close] button.
12.Press the [Log In / Out] button on the Control Panel. An "Are you sure you want to logout?" message will be displayed.
13.Select the [Logout] button on the Touch Screen.
Sep 04, 2014 | Xerox Workcentre 5335/p 5335 Mono Advanced...
Pls machin off
Now press & hold 2 minutes 4no button+power saver button+stop button press and then machin on showing hdd formet after some time ready to copy your machin
Aug 21, 2014 | Xerox WorkCentre 5325 5330 5335 Black...
004 error code350
I am afraid that that foult code means that the machine's software has to be reloaded. The only way this can be done is by a qulified xerox tech. It need a laptop with special software to connect to the machine to do the download.
Nov 28, 2013 | Xerox CopyCentre C20 Black and White...
Fault code h6
Hi my washing machine ( a swan sw3010b ) keep draining the water and after a while it shows a foult IE. Can someone helps please
Nov 14, 2011 | Washing Machines
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
Xerox copy machine
The lamp is n/g Replace it. Lawrence
Oct 22, 2007 | Office Equipment & Supplies
Xerox Workcentre 5335/p 5335 Mono Advanced Multifunction Copier/printer/scanner Logo
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
