Question about Xerox Workcentre 5335/p 5335 Mono Advanced Multifunction Copier/printer/scanner
My xerox machine 5335 show in display code 010-338, please help its sollution
2 Suggested Answers
donaldayers0
  • 2148 Answers
SOURCE: xerox 5335 fault code 059-314
This may require replacement of the fuser unit as mentioned on page 774 of this document, meant to be used only by Xerox technicians. I would not even be accessing the document on my business computer as it appears from a foreign source.
https://docviewer.yandex.ru/view/0/?*=L3ZM3UDX5Z6%2FXfW9EzCsDWJS1297InVybCI6InlhLWRpc2stcHVibGljOi8vRVh2M2Y1Yko5ZjdXcHJjdnlxeHVpVnNYTWxteXJwNG54Mkx6SmE1MHU2cz0iLCJ0aXRsZSI6Ilhlcm94X1dDXzUzMzVGX1NELnBkZiIsInVpZCI6IjAiLCJub2lmcmFtZSI6ZmFsc2UsInRzIjoxNTA1NjM0NDQ2NjgxfQ%3D%3D
Posted on Sep 17, 2017
How can fix error u4 code in xerox photocopier machine
http://xeroxmachineerrorcode.blogspot.com/2016/07/u4-error-code-xerox-wc50165020.html
Unsure what model Xerox is displaying error u4.
To pursue your question further, please provide Model name and number that is on the equipment in question.
My Xerox Workcentre 5020 machine showing U4 error How can solve this...
Feb 19, 2018 | Xerox Office Equipment & Supplies
Xerox WC 5330 error Code 010 338
I think it is a toner or maybe paper issue, as a first step I would remove and re install both
Jul 13, 2016 | Xerox WorkCentre 5330/P Printer
Error code 116-330 xerox workcentre 5325
4+power saver button+stop button press&hold then machin on disply hard disk formet then machin off& on Now ready your machin
Jan 10, 2016 | Xerox WorkCentre 5325 5330 5335 Black...
Sln for Xerox wc 5330 error code 092-315
092-315 ATC Fail RAP
BSD-ON: BSD 9.3 - Development and Toner Dispense Control
The frequency at which the ATC Average Fail or the ATC Amplitude Fail has been occurring
has exceeded the threshold value.
NOTE: •
Although this Fault can be cleared by turning the power OFF and ON and it will be possible to output a few sheets of printouts, when this Fault has occurred a certain number of
times, it will no longer be clearable by turning the power OFF and ON. To clear it, clear the
value of NVM location [752-022] (ATC Average Fail) or NVM location [752-023] (ATC
Amplitude Fail) to "0" (
NVM Read/Write). If the machine is not repaired back to normal
status, this Fault will occur again during the operation.
• When turning the power OFF, turn OFF the power switch first and then the main power
switch.
Procedure
Check the following:
• The connection between the MCU PWB
P/J413 and the Xero/Developer Cartridge P/
J615
for open circuit, short circuit, and poor contact
• The Toner Dispense Motor for revolution failure:
Component Control [093-002] (PL 8.2)
• The Toner Cartridge for internal toner blockage
If no problems are found, replace the following parts in sequence:
• Drum Cartridge (
PL 8.1)
• MCU PWB (
PL 18.2)
See Service Manual page 827 (2-831):
https://docviewer.yandex.ru/?url=ya-disk-public%3A%2F%2FEXv3f5bJ9f7WprcvyqxuiVsXMlmyrp4nx2LzJa50u6s%3D&name=Xerox_WC_5335F_SD.pdf&page=827&c=55716712dd0d
Xerox WorkCentre 5335 Family 5325 5330 5335 Service Manual
Jun 05, 2015 | Xerox WorkCentre 5325 5330 5335 Black...
Fault Code: 016-405 Xerox WorkCenter 5335
This FC (fault code) 016-405 means that there is an error with your security certificates on the 5335 .Copy the link below into your browser and type 016-405 in the search field and it will provide guidance on how to resolve this issue.
NOTE When working with security certificates on Xerox equipment it is recommended you call them for support or have your IT person investigate, this is because if you delete any certificates and not initialize them again you can break some custom services installed on your machine.If you;re not sure if you have custom services running please call your IT department or Xerox for assistance.
http://www.support.xerox.com/support/workcentre-5300-series/support/enus.html
I hope this helps ...
Mar 06, 2015 | Xerox Office Equipment & Supplies
Xerox 5325 fault code 124-374
this error is mismatch serial no
go to dignostic mode go to adjusment other re input serial number
Sep 19, 2014 | Xerox WorkCentre 5325 5330 5335 Black...
Pls machin off
Now press & hold 2 minutes 4no button+power saver button+stop button press and then machin on showing hdd formet after some time ready to copy your machin
Aug 21, 2014 | Xerox WorkCentre 5325 5330 5335 Black...
How to fix fault 116-365 of wc 5330
Solutions for : Fault Code 116-365: An Internal Shutdown Occurred After an SPL Processing Error Related Fault Code: 116-365 Solutions ranked by relevance:
  1. Delete All Jobs From the Job Queue
  2. WorkCentre 5325/5330/5335: Power the Printer Off and On
May 27, 2014 | Xerox Office Equipment & Supplies
Xerox workcentre 5020/Dn c1 error
i have one xerox 5020 machine, there is display showing C1 error code in first tray and C3 error code in bypass tray .if open and close the machine will be idle and ready to cpoy. there is no paper pick up in both trays. please help to resolve the problem.
Dec 17, 2012 | Office Equipment & Supplies
Xerox Workcentre 5335/p 5335 Mono Advanced Multifunction Copier/printer/scanner Logo
257 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
