Question about Fisher Refrigerators
Fisher and packel active smart is beeping when door is closed and is now defrosting the freezer and freezing foods at back of fridge... How do I fix this?
  • 1,933 Answers
It is evidently not out of refrigerant then. It will beep at you to advise that it was set to bottle chill and time is up, or that either door was left a bit open.
Also make sure the slot at the upper back of the fridge compartment is not blocked with items. That has to be left clear as it is where the cold air comes out to circulate.
Try turning it off for 30 min and then back on.
If the condition persists you will have to call F&P service. Take note of just when it beeps and the exact number of beeps. They may want to know this.
Posted on Dec 29, 2016
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
The fridge alarm will not stop. The fridge compartment is not cold and the freezer is just freezing. Since the problem started, have the fridge turned off for 3 days. Defrosted the freezer, turned it...
this alarm is activate if the temp. of the fridge rises and because the freezer section is full of ice form thats why affect the circulation of cold air. try to check the defrost timer if yuor unit have or heater if working if dont have defrost timer or heater try to lessen the setting of your themostat to cut of unit after reaching desired temp. or conduct weekly defrost manually.
Feb 12, 2011 | Fisher and Paykel Active Smart E522B...
Ice building up back of freezer and fridge not cooling this is a fisher and paykel active smart fridge frezzzer
I dont work on that brand, however you describe a typical defrost problem, could be the heater t-stat or defrost control.
Oct 05, 2010 | Fisher and Paykel Active Smart E522B...
I have an active smart fridge freezer. The freezer seems ok but the fridge has stopped working but it doesent get cold. how can it be fixed. It is only 18 months old.
Check fan in the freezer
Also check auto defrost (ice on the freezer coils anot allowing
air to the fridge.)
If so go to appliance parts store to learn the parts to fix auto defrost.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Fisher and Paykel Active Smart E522B...
Fisher & Paykel active smart fridge keeps beeping for no apparent reason, while door closed
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Nov 04, 2009 | Fisher and Paykel Active Smart® E522BR...
Our N369B fridge freezer has a large amount of ice clinging to the upper back of the fridge how do we stop this happening?
Your freezer door is not closing properly. if it is not on wheels then make sure the bottom nut that also holds the front wheels or slider in place is tight. Also maybe have the seals replaced and check door alignment on both doors. You will of course have to defrost the freezer.
Oct 27, 2009 | Fisher and Paykel Active Smart E522B...
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
Jun 07, 2008 | Fisher and Paykel Active Smart® E522BR...
Refrigerators Logo
Top Fisher Refrigerators Experts
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
John Tripp
John Tripp
Are you a Fisher Refrigerator Expert? Answer questions, earn points and help others
