My machine show in display code 010-338, please help its sollution
  • uwbfritz Dec 29, 2016
    Hi bidyut pramanik, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the make/model of your washing machine?
The ECG shows only lead I on display,the other 2 are flat lines. What can I do?
Sorry I haven't any idea on your query, But have a sollution that if you want any kind of medical cable then Peterstechnology is a best option for you. It is providing best medical cable with an affordable price.
Custom Medical Cable Assemblies Manufacturer
Jan 15, 2016 | Ge Medical Systems Ge Marquette Mac 1200...
Fault code h6
Hi my washing machine ( a swan sw3010b ) keep draining the water and after a while it shows a foult IE. Can someone helps please
Nov 14, 2011 | Washing Machines
Hitachi washing machine error code Fb indicates problems. what prolems is that? Can you list out the meaning ot each error code.
My washing machineSF-110SS
have a display FD. Anybody know what's that means? And how to solve it. Please
Jun 23, 2011 | Washing Machines
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
Apr 15, 2011 | Toshiba e-Studio163 Copier
Hi my alana stereo is stuck in safe mode as i entered code from my old seat ibiza thinkin it was this one now safe mode on all the time and will not let me put code in
My Seat Ibiza has been in storage with battery disconnected. On connection of the battery the Alana radio now shows '1000' (not 'SAFE', then '1000' as it has done previously. This does not allow me to enter the radio's code. Can you help me?
Oct 20, 2010 | Car Audio & Video
I came in this morning and the machine is stuck on (paper jam)2 There is no paper jam anywhere and I have turned it off and on unplugged it etc... HELP PLEASE
Mine does the same thing, and I'm trying to get a sollution also, but in the mean time, I've been pulling out the toner cartridge and popping it back in, and then it'll print, but you might have to do it 2 or 3 times before it'll print again, but the only problem with mine, is that it'll start jamming again, so I'm still looking for a permenant sollution. If you find out please let me know.
Oct 12, 2009 | Dell 1600n All-In-One Laser Printer
L5 show in display and won't work in calypso washer
ss13679,
I believe your code is actually 'LS'. This codes shows up when the controller cannot detect the lid switch opening and closing properly. This error code may also be used if there is a diagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if you press the start key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Your lid switch may be bad. Click here for some help. Also it looks lik this: click here
Hope this helps. Please give me a vote!
-samson39
Jul 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Blue display
the phone's firmware is corrupted please try update the firmware.
you need serious gear to perform that, so i recommend you to give me a good reate and take it to a phone repair shop that you will never cost you more than 6$ ^^
Mar 26, 2009 | Motorola Mobility C168 Cellular Phone
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Forgotten nokia n70 phone lock code..
this will show ur lockcode
install it from
http://files.myopera.com/manujha/soft/UnlockMe.SIS
Nov 02, 2007 | Nokia N70 Cellular Phone
Washing Machines Logo
Top Washing Machines Experts
