Question about Asko Dryers
ASKO dryer t760. How many drum rollers are there, and where are the drum rollers located?
Rotu
  • 175 Answers
SOURCE: Drum makes a clunking sound when rotating, even when empty
This machine has roller wheels in the front that are not adjustable, but rather need to be replaced if they have a bad spot or something. Usually what I see with a clunking noise(clunks once or maybe two quick clunks in succession) is that the dryer has been set down hard on the ground and has put two dents in the roller surface of the drum. To check this, just unplug it, pop the top off (3 screws in the back and tilt it up) and look at the very front edge of the drum. rotate the drum by hand (carefully so you dont pop off the belt) and look for any imperfections in the suface, such as dents. If you are getting more of a vibration type of noise, I would also suggest taking off the lower front cover then taking of the blower wheel cover located to the left side and checking that there is no lint built up in the blower wheel as well. Good Luck!
Posted on Dec 17, 2006
SOURCE: i have an asko dryer
Try taking the lint filter out and gently washing it with a soft scrubber. The screening is very fine and it might look clean to sight but might still need a more thorough cleaning.
Posted on Mar 07, 2009
dmftrucker
  • 1922 Answers
SOURCE: Asko T760 Dryer - Computer Screen Blank
you have either a frequency related issue or there is a lot of t.h.d. total harmonic distortion on the line, this will raise cane with electronics, I would try a power line conditioner on the dryer power circuit
Posted on Sep 26, 2009
SOURCE: My asko T760 dryer shuts down after a few minutes.
Remove bottom panel. The condenser unit is on the left side. Open the section by undoing the clips, and look inside the little "cage". That's the sensor. Remove any lint using a toothpick and you should be good to go!
Posted on Jan 10, 2010
SOURCE: Replacing drum support rollers on a Asko T760
http://www.repairclinic.com/Asko-Parts
Posted on Oct 22, 2010
How to Replace the belt for a Asko T700 Dryer?
I have a T760, and the way I do it is to take the top off (3 screws in the back and slide it out from under the front lip), take some pics of the wiring so I'll know where they go (they're marked, but pics still help), and take the back off (perimeter screws). The drum bearing is mounted in the back, so I have to tap the drum shaft thru the bearing (take the washer off and put the nut back on so it is flush with the end of the threads). Asko has a special tool to hold the drum in place while the back is off, but I made one out of a coat hanger (a hook on one end to hang on the lip of the drum, bend a couple of right angles to fit thru the holes in the front panel, make it before the back comes off). The real hassle is holding the drum in place while reinstalling the back and the tool does this nicely. The belt has a spring loaded tensioner, make sure the wheel and bearing are ok, put it back together, and you're back in business...
May 10, 2012 | Asko T700 Electric Commercial Dryer
ASKO T760; Drum "Thumps" rapidly
I have replaced the drive belt and rollers, to replace front support rollers you need to take drum out to gain access to them. the part that takes the longest is removing rear panel, the 4 screws around the drum bearing and the screws that hold heating element to the rear panel. Then you can rotate rear panel out of the way, having a small stool or chair for it to sit on makes it a whole lot easier. With this out of the way you can remove drive bely from drum and lift it out of the way. The rubber rollers sre held in by bolts with nylon nuts on the front, be careful when taking out the bolts that you don't knock the nut out of its holder, if this happens you will need to remove the screws around the inner door opening to be able to put the left side one back in. I had the dryer laying on it door to remove the drum an belt, then placed it in the normal position to change the rollers.
Hope this helps, took about 45 minuetes, I'm not a appliance tech.
Jan 02, 2011 | Asko T761 Electric Dryer
My asko T760 dryer shuts down after a few minutes. It starts again after hitting reset button on back. I read a similar problem was fixed by cleaning the sensor behind the safety cap fixed the problem, but...
Nov 28, 2009 | Asko T780 Dryer
Jul 30, 2009 | Asko T761 Electric Dryer
Apr 07, 2009 | Asko Dryers
I have an asko dryer model t760 that overheated the other day. it did finally trip the overheat protection switch on the back, but it did get hot enough to distort a few plastic pieces and put flat spots...
Aug 25, 2008 | Asko Dryers
Dec 11, 2006 | Asko T781 Electric Dryer
Open Questions:
Dryers Logo
32 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
