Question about Black & Decker Garden
Where can I buy a black & Decker 550 grass hog spool?How much does it cost?
  • 313 Answers
SOURCE: Black & Decker CST1000 Grass Hog Grass Trimmer
common problem battery.
Posted on Jun 08, 2008
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
darth yoda
  • 4 Answers
SOURCE: Motor runs but base doesn't spin to do the trimming. How can I fix this? I have a Black & Decker 14 inch Grass hog- electric trimmer.
gearbox!! get rid of it
Posted on May 29, 2009
  • 133 Answers
SOURCE: how to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Posted on Apr 21, 2010
  • 221 Answers
SOURCE: We have the Black & Decker Grass Hog xp 7.2
You should be able to download a new manual at the following link. I hope this helps.
Normal 0 http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jul 12, 2010
Engine runs, but spool with trimmer line doesn't spin. Is it repairable?
If the spool doesnt spin check the driveline for damage.
If you just have a broken drive cable you can replace or repair it.
If the drive cable is spinning but the connection to the spool is bad then you might look for a replacement spool.
The problem is that the cost of buying these parts is on par with about 40-50% of the cost of replacing the whole unit.
Good luck and be careful!
Aug 06, 2010 | Black & Decker 14" Grass Hog Xp...
What replacement line is used for the BLACK & DECKER Grasshog. 5,063,673 5,620,336 6,443,753 6,443,762
For the cordless Grass Hog, the replacement spool is AF-100. You can purchase these spool heads online or maybe find them at your local hardware store, but they may be hard to find because the Grass Hog is not made any more.
Jul 13, 2010 | Black & Decker 14" Grass Hog Xp...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
How to restring back and decker grass hog
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
Have a grass hog that has two lines in the spool. How do I restring the spool
wind in direction of arrow on spool. Use 2 separate pieces. 1 at top and 1 at bottom. Feed 1 through each opening in hub when done.
Apr 10, 2010 | Black & Decker 14" Grass Hog Xp...
String will not advance on black and decker grass hog electric trimmer
Did you re-string it? If you did it is possible that you crossed the string over itself and it is stuck. Check that and good luck...Lee
Oct 20, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Describe your Black & Decker
You can order these thru black and decker at blackand decker.com
Sep 12, 2009 | Black & Decker 14" Grass Hog Xp...
I don't undestand how to fix the line after it
The string is wound the wrong direction; it should be wound clockwise on the spool.
Jim
Jun 18, 2009 | Black & Decker Black and Decker & Grass...
Garden Logo
49 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
