I cannot get install up on the menu bar it is greyed out
  • Ali Asghar Khambati
    Ali Asghar Khambati Dec 29, 2016
    Hi Kiwi White, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Kiwi White
    Kiwi White Dec 29, 2016
    Hi Ali my TV a Schaub Lorenz is locked on one channel. I tried a factory reset but it does not work. In menu options the Install is greyed out so I cannot to an auto scan. Can you help thanks
Cannot insert photo in body of email.menu grayed out
You cannot insert a photo, you have to attach it. See how to send attachments n your mail program.
Feb 27, 2015 | Computers & Internet
It will not recognize my sound bar the section for turn off speakers are grey out and it also doesn't see the sound bar.
If the sound bar is missing and speakers are grayed out--if using a box means a setup option there is causing this.
If in set means a similar issue---most likely is a cable box if used is disabling the sets menu for this.
You may if using a box want to disconnect all connections to the set and unplug both set and box to see if after a wait both will reboot when plugged back in.
As a last resort with the model number call Toshiba customer service.
Apr 01, 2012 | Toshiba 19SLV411U 19 in. LCD TV/DVD Combo
My browser bar or address bar has disappeared on my firefox how do i get it back
Right-click in an area without text or icons directly under the title bar. Click "Navigation Bar" and it will return
I hope this helps & good luck. Please rate my reply. Thank you.
Apr 08, 2011 | Mozilla Firefox
I just upgraded from os x 10.3.9 to os x10.5.6. Now on start up I get the grey screen with rotating wheel then a darker grey screen with message to reboot the computer. I can get no further.
Not a good sign but not the end of the world. Put the install disk into the Mac and hold down the option key (in a moment you'll see two disk icons appear) once you see the icons, click on the install DVD then up arrow in the circle.
When you get to the install screen click next thru the next couple of screens. You should see a menu bar at the top of your screen, click and hold on utilities then select Disk Utilities. When Disk Utilities is running on the left side of the window select your Hard drive (not the DVD) On the right hand side some new options should appear, Click on First Aid if not already selected then click Repair Disk Permissions.
When complete restart the machine normally (DVD should eject) If that does not fix it you'll need to try the install again.
Jun 16, 2010 | Apple Mac OS X 10.4 Tiger for Mac
Grey screen with a blinking folder and question mark
Two possible things are wrong either your hard drive has gone or your system has corrupted. Put your instal disk in start it up holding down the c key. Once it has started check that the hard drive exists by go to the menu bar and selecting the disk utility. If the hard drive shows it means that it is okay run the disk utility check drive and then run the repair permissions. Then try restarting, if it works then you are back up and running again. If the drive shows up and you restart and the same thing shows up with the grey screen, you will need to reinstal your system. You do this by starting up with the instal disk holding down the c key and run the instal script. To keep your hard drive contents your will need to use the preserve users instal.
If your hard drive does not show up the hard drive is probably a gonner and you will have to purchase a new hard drive and instal a fresh system.
Hope this helps
Mar 23, 2010 | Apple Power Mac G5 Desktop
How do i restore menu bar(file--view--tools etc)
Press the alt key, the menu bar would come back automatically
Mar 19, 2010 | HP Pavilion dv9000z Notebook
I can't share my webcam with my contacts, I can hear and see them but they can only hear me. Using Windows Live messenger, on tool bar I went to actions, then I scrolled down to video, on share webcam it...
If the option is greyed out its telling you the feature is not available.
Check your settings
Open Menu > Tools > Audio and Video setup - run through audio > Next - set your webcam as default and see if it launches - adjust settings > Finish
Aug 05, 2009 | Microsoft LifeCam VX-3000 Web Camera
Task bar is grey upon start up
^Try going do the display properties again but this time on the Appearance tab.
You will have a dropdown box and select windows xp default.
let me know if it helps
Jun 20, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
