Question about Fossil Watches
How to remove stem crown from automatic fossil
Glass face got chipped , chip is rollin around inside. I would like to glue chipped piece back in place but need to remove movement
s4u311
  • 813 Answers
SOURCE: how do i remove crown?
hummmmmmm
u need to go experts of watch reper i think its its problem in watch curcuit thats y this happen
& thnx useing fixya
Posted on Mar 28, 2008
VOTIT
  • 2071 Answers
SOURCE: Removing the crown
The video i want to see you,is using older kind of watch,screwing before he can pull the crown ,the new model watches now like your Tag Heuer is pushing, use a needle to push, while pushing the stem lock you pull the crown .That's why ill tell you in advance so you aware.I know because i'm a watch technician working in rolex before...
remove the crown
if i helped,please,click FOR RATING .It is the only way i get paid for my works also,please consider leaving feedback..
Regards,
VOTIT
Posted on Sep 08, 2008
  • 5 Answers
Hi, on the back of the movement there should either be a screw or a dimple in line or next to the line of the stem. If a dimple, press in with a pin or similar sturdy tool and gently withdraw the stem. If a screw, only one turn should be enough to release the stem
Posted on Nov 18, 2008
escapement
  • 2334 Answers
SOURCE: remove the winding stem/crown.
There is a tiny point (end of small metal piece called setting lever) on the left side of the stem (on watch movement, very close where the stem is entering the movement).
You have to push that point down with a metal pin or tweezers. Crown (winder) must be pushed in to normal position otherwise you will not be able to put the stem back properly.
So, do as follows:
1) Push the crown in,
2) Lay the watch down on flat surface and push on setting lever point,
3) While holding setting lever pushed in- extract the setting lever by gently pulling crown out of watch.
Do not forget to rate, please.
Posted on Jan 09, 2009
SOURCE: Removing the crown/stem of CASIO EF-321
Other case for a simple Casio quartz watch :
Posted on Jan 08, 2010
Need a new glass for men's seconds watch
I assume you mean a Sekonda watch.
Watches from large scale manufacturers like Sekonda come with a wide range of glass sizes. 30mm diameter is a common one, but you would need to remove the glass in one piece to measure it. Watch glasses are commonly in 0.5mm steps (e.g. 30.0mm, 30.5mm,31.00 mm etc.) and may have rounded or bevelled edges so it is often very difficult to determine the exact size without removing the glass.
Additionally, there is the thickness of the glass to consider.
Finally, the 'glass' may be plastic, mineral glass or sapphire crystal.
All in all, you will have to know how to remove the back of the watch, how to remove the crown and stem in order to remove the movement, how to remove the glass in one piece, how to fit a replacement glass, how to refit the movement, how to refit the crown and stem and how to refit the back.
Alternatively, take it to a watch repair centre - you'll still have a working watch after they've finished with it.....
Oct 18, 2017 | Watches
The red bead (?) on the stem of my Michele CSX watch came off and was lost.How do I get a replacement? Thank you. Patty
I also chipped the enamel on the crown. You should take it to the place you purchased it and they will send it to Michele (actually Fossil) for repair. I had my Michele for 5 years before sending it in to have the crown repaired and have since lost the stem. Prior to that first repair, I did not have any issues with my watch. I really think that the parts used on my watch for the first repair were shotty. Very disappointing, but what do you do?
Apr 21, 2011 | Michele CSX Diamond watch
I have a F ossil Arkitekt (fs-2990) that is a several years old. I removed the back and the battery to change out the battery and noticed that one of the numeral bars on the face has dislodged itself. in...
The knob that adjusts the time is called the crown, and it will have a stem attached to it. You will need to remove crown and stem together.
If it's a screw-down crown, unscrew it.
Examine the watch mechanism very carefully while pulling out the crown (as if you were adjusting the time) and pushing it back, What you are looking for is basically anything that moves. If you do see parts of the mechanism move, look very carefully around that area for an arrow mark impressed in the metal pointing to a small dip in one of the metal parts.Often, this is on a tiny lever but not all manufacturers bother with the arrow.
Ensure that the crown is pushed back to it's normal position. Put a tiny amount of pressure on the dip (a needle is ideal for this), and carefully attempt to pull out crown and stem.You may need to apply slightly more pressure to get a result, but please take care not to press too hard or you may damage the mechanism.
Hopefully, that should sort it out. To refix the numeral bar, I'd recommend super glue - but you only need a tiny, tiny amount. Apply it with the tip of a needle and you shouldn't go far wrong.
Once you're looking at reassembly, you should be able to reinsert the crown and stem without depressing the dip but do it gently and don't force it - it may need a slight turn to relocate properly before it slides back in.
I hope this was easy to follow - get back in touch if you get stuck.
Sep 15, 2017 | Fossil Arkitekt Watch for Men
The hands have come off my fossil FS3087 wrist watch. I would like to know how to take off the glass in order to fix it myself. Thank you
mcdevito75 here, In most cases the glass (crystal) come off or out thru the back of the watch which means you"ll have to remove the quartz mechanism, and that means removeing the stem, thse quartz stems are very prone to breaking while being removed form the quatrz mechanism and the cost of a repair may be more expensive then a whole new watch, shop around get a price from a small watch repair shop on repair verses a new Fossil watch.
Feb 09, 2011 | Fossil FS3087 Wrist Watch
How do I remove the crown/stem to take the watch movement out of the case? thanks Marc
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder.
Apr 04, 2010 | Watches
Find watch numbers, seamaster automatic
I hope you have Omega Dynamic?!
If yes, then the crown can be removed by appling slight pressure against the watch. The stem inside the watch is made of 2 pieces and the crown can be pulled out. But be careful, there are chances that the stem may break :-)
Sep 07, 2009 | Omega Constallation 1272.70 Wrist Watch
Missing piece?
You are not missing anything. The stem (metal bar, wich is going into movement) from the crown (you say knob) is broke. The stem is made of one piece and screws directly into crown. You've been unfortunate to brake it and the tiny end of stem still in the crown - the rest looks OK , but actually it is what's left of the stem. This is not the job you can do yourself, so, find the nearest watchmaker and ask for replacement. Do not forget to rate, please.
Mar 03, 2009 | Fossil Metal Casual Green Dial AM4071...
Remove the winding stem/crown.
So, do as follows:
Jan 09, 2009 | Fossil AM3425 Wrist Watch
New watch..Jules Jurgenson day-date..the stem cap is loose.
remove the cap and put a tiny drop of locktite glue on it. spill some glue onto a piece of glass or an old plate and use a sewing needle to put a tiny drop of glue in the hole then screw it back on and wait till the remaing glue on the glass is gone hard before pushing the stem back in .. this last bit is important so as not to glue the stem to the watch. if this helps please rate me joe
Nov 12, 2008 | Jules Jurgensen 5004PB ( ) : Swiss Quartz...
Skagen watch
Yoy have to take off the back. Does the back have notches(5 of them) around the back cover? If it does take a pair of needle nose pliers and turn counter-clockwise to loosen. If the back has no notches then there must be a little lip where you have to pry off the back. Look carefully sometimes it is hard to see.. You have to use a sharp strong knife, like a swiss army knife, something that is sharp but has a little meat to it. Once the back is off,look at the movement. Now pull out the crown ( the part for setting the watch) and as you do, look for a metal piece that is in the movement (probibly to the derect left if you are right handed) that has a little dimple and moves as you pull in and out on the crown. Once you find that, use a small pin and LIGHTY push down on the that piece as you pull out the crown. The crown and a long piece should come out (the crown and the stem which are connected) You should be able to take out the movement now. Some advice: don't use super glue, it has gasses in it that will ruin your face of the watch.Maybe a model glue would be better, I being a watchmaker usr jewelers glue. Do not put the movement back in for about a hour just in case of any gasses.When done gently push the stem and crown back in and close the back. If you have any problems,please let me know. Maybe I can walk you through it. Good Luck!!!
Aug 04, 2008 | Watches
Watches Logo
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
