I own a Chaub Lorenz TV it is locked on one channel only. The remote is fine and I cannot change to other channels using the controls on the TV. I tried a factory reset but nothing happens
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
  • 99 Answers
SOURCE: panasonic tv channel reset
Unplug your tv for 24 hours and replug. This should set your tv back to ch 3
good luck----------------tomtaso
Posted on Nov 27, 2007
  • 280 Answers
SOURCE: remote control changing channels
Make sure to push the TV button on the remote. some times it will be in the wrong mode ie VCR.
Posted on Apr 18, 2008
SOURCE: Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
I have the manual and it is called "child lock" go figure it stumps us adults. Anyway...holding the power button down for approx. 8 seconds can toggle this feature on / off
Posted on Dec 20, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
I'm using a Time Warner remote as a universal for my TV but when I go to change channels, it just lights up the CBL button and doesn't change the channel. Can I program it to my TV or will it
Hi, you need to de-activate the "programming channel control lock" option. You can see instructions in the manual for the remote. They are as follows:
  1. On the remote control, press CBL once; It will blink once, Press and hold SETUP until the CBL key blinks twice.
  2. Enter 9 7 3. The CBL key will blink twice.
  3. Press CH- once. The CBL key will blink four times.
    Now the remote control will provide TV and VCR channel-control capabilities while in the TV mode.
for any other information with programming this remote:
Download the 1056B01 operating manual with codes for free.
Nov 30, 2012 | Televison & Video
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
Cannot change channel to a 2 digit channel eg.
some remotes used to have a key to switch between single or double digits marked ( -/--)
Oct 27, 2009 | Samsung TV Remote Control
I need to reprogram my rcr317w remote contact with manual
Turn the tv on. Hook up your components, turn them on, go in to tv menu and auto program the stations. It will see that there is a signal on channel 3 and lock it in for you.
Jun 30, 2009 | Universal Remote Control DIRECTV Universal...
Remote control changing channels
Apr 18, 2008 | Televison & Video
Parental lock
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Hughes Remote works the satellite but not the TV
You have to push and hold down TV and Mute button (for 2 seconds at the same time), then release them at the same time, then push channel up until the TV turns off.  Be patient and continue channel up until the TV turns off.  When it turns off, then push TV again to lock the code.
You were doing fine, but missed to push channel up to fine the code.
Oct 25, 2007 | Hughes HRMC11 Remote Control
FPA Lock
After doing a little research, it looke like the front panel lock , can only be removed from the parental control menu using your remote. If your universal remote does not get you into the menu, see if you can borrow a friends rca remote long enough to get you into your menu & remove the fpa.
Nov 03, 2006 | RCA 14F512T 14" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
