Question about Safe International Electronic Gun Safe Lock Box Digital Home Jewelry Bank
I want to identify an unusual jewelry box I have, wooden with glass lid, maybe 1980s? Appears to be a poker hand etched in the glass? No maker detail info at all!Could have secret compartments?
The poker hand is in this order: ace of clubs, king of hearts, jack of spades, king of diamonds, queen of hearts. Pair of kings only? Any significance to this? The box is kinds weird a can be creepy in a certain light!
Magnet on lid of soup Mate lost. thus he machine will not start. Magnet is a particular size. Where can I get a replacement? I'm in Perth Western Australia
contact the manufacturer on the net
go to an appliance repair shop and see if one is available
how big is the magnet and will cutting up a fridge magnet help
what about cutting up a magnet from a fridge door seal
just ideas to consider along with magnets from tools , diff plugs
small speakers ( head phones etc)
Sep 14, 2015 | Blenders
What are the most common kinds of jewelry display cases?
the vast majority of display cases are made out of aluminum, either as just an aluminum case that opens like a briefcase, or with aluminum rods and glass casing
Jan 13, 2013 | Retail Supplies
Where can I get a replacement lid hand for my Rival slow cooker model no scv655?
Rival is now Their parts page for your model shows no parts, but they list a toll-free number you can call. Try that and see if they have a different model lid or handle that will work.
When a friend's cooker lid needed a handle, I picked up a plain round wooden drawer pull at Home Depot, used a wood rasp to round the end of the knob a little to fit the curve of the lid, and put thin rubber washers from the plumbing aisle under the screw head and between the knob and lid so I wouldn't crack the glass when tightening the screw for a snug fit. Nearly two years now and it's still holding on. If you can't get an original replacement part, maybe you can roll your own.
Mar 03, 2011 | Rival SCV655 687Quart Slow Cooker
The water isn't fully coming out when brewing a cup of coffee and won't fill the cup. I am maybe getting 1/4 cup of coffee
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 15, 2010 | Keurig B70 Coffee Maker
I was cooking popcorn on my glass cooktop and the pan appears to have scratched to surface.
You may have melted the bottom of the pan you were using into the glass. Copper bottom and alum pans sholdnot be used at high temps on a glass top. (never use porclin or glass pots)High temps can etch(mark or discolor) the glass.
Oct 30, 2009 | KitchenAid 30 in. KECC506R Electric...
Dishes and glasses being etched; looking dirty; embarrassing
First of all, if you're talking about actual glass as opposed to crystal, glass can etch easily. Why? Because like crystal, there are variations in its quality. Cheap glass will etch faster with the use of an electric dishwasher compared to higher quality glass.
Did you know that the main constituent in most automatic electric dishwasher detergents is sodium hydroxide (lye) and chlorine bleach (another caustic acid)
A Bosch dishwasher has very long wash cycles, further exposing your dishes to the possibility of etching damage. You should stop using the sani-rinse cycle if there is such an option and switch to a gel format detergent as opposed to a powder. Use a rinse agent such as Jet-Dry. This should solve your etching problem.
Apr 23, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
Need plastic handle on Rival Crockpot lid.
For what it's worth, when the handle on my mother-in-law's crockpot broke, I went to Home Depot and bought a cheap wooden drawer knob (about $1 as I recall). I put a plastic washer between the knob and the glass and another under the screw head from the bottom (to prevent cracking the lid), tightened the screw and good as new.
Feb 20, 2009 | Rival 38601 Smart Pot 6-Quart
Coffee maker leaking
Did you fix the problem? I am looking for a replacement for my glass pot.. If you are willing to get rid of this maker please let me know. Thanks
Jan 01, 2008 | Kenmore KCP12PRO Coffee Maker
Safe International Electronic Gun Safe Lock Box Digital Home Jewelry Bank Logo
96 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
