Question about Dryers
Dryer too hot no low heat - Dryers
    New Friend:
  • 25 Answers
It could possibly be a bad thermostat inside the dryer.
Posted on Dec 29, 2016
2 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: Dryer seems to get too hot even with low heat selected.
Just a thought. Move the drier away from the wall if it close to it and try again. If the air intake is reduced, it will cause the temp. to rise significantly.Also, chech and see if intake andor exhaust is not dirty.
Posted on Sep 24, 2009
Dryer runs does not heat up. Why?
There are several possibilities why your dryer will not heat. If it is an electric dryer you make have a tripped high or low limit thermal cutoff. You may also have a failed heating element or operating thermostat. If your dryer is gas you make have a faulty hot surface ignitor, flame sensor, or gas valve. What type of dryer do you have? This may help in diagnosing your problem.
Dec 27, 2015 | Kenmore Dryers
Why is my tumble dryer hot on a low setting
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Feb 14, 2015 | Dryers
Why is an Asko 7304 dryer running hot, so much so it melted fuse holder?
GOD IS still GOOD !!!!
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 16, 2014 | Asko Dryers
Wont heat on low heat only on high heat and keeps running
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 15, 2011 | Whirlpool Dryers
Dryer runs hot on low heat setting
What kind of dryer do you have? Some dryers use a bimetal or snap-disc thermostat with a heating element under it to control temperature. the heating element is used for the low heat setting to make it turn off early since it will sense a temperature higher that what is actually there. If the heating element is bad then the thermosat will only operate at the high temperature. You should look at replacing that element.
Nov 29, 2009 | Refrigerators
Sep 24, 2009 | Siemens ultraStack WT46E300US Electric...
Dryer heats but doesn't dry
Sounds like it is only heating on "low". The problem is most likely a thermal limit switch/thermostat which is bad.
Apr 21, 2009 | Electrolux Dryers
Low heat with matag dryer
I have been to the Maytag website and I could only find the installation instructions. Sometimes the wiring diagram will be located in an envelope on the unit. If the dryer isn't getting hot enough and you are sure that there is nothing empeding the airflow, then the thermostat is the only thing that can be wrong. These units are typically pretty simple.
Apr 09, 2009 | Maytag MDE8000 Dryer
GE Profile dpsr473ewoww timer doesn't work and heat level is low
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Feb 01, 2009 | GE Profile DPSR473EW Dryer
Dryer doesn't dry clothes. seems to run on low heat.
Make sure dryer is unplugged. Take the back off and you will see two heater exchanges and probably the element. One of those heat exchangers is for hot setting. When you find out which one go to nearest electrical shop with it and order. I reckon thats what your problem is. I've changed mine and everything was alright.
Oct 04, 2008 | Frigidaire Dryers
Dryers Logo
Top Dryers Experts
