Question about Dishwashers
OMG! I posted a question under dishwashers that pertains to an old jewelry box! Help please
2 Suggested Answers
  • 77 Answers
SOURCE: OMG I'm forget my old password..please help me
Depending on the operating system in some cases you can go into safe mode or you will need a bypass in the bios. Click here for immediate assistance.
Posted on Mar 26, 2013
My dishwasher Bosch number 11122 is dead. OMG. What can i do now?
Check the plug at the wall check fuse box for blown fuses
Jan 24, 2018 | Bosch Dishwashers
HOW TO REMOVE PLASTIC MELTED ONTO GOLD JEWELRY
Hi! I found this answer on the internet.....use oven cleaner!! Here is the text of the webpage, and I will list the link at the bottom.
This is a emotionally difficult post to write, but if you've had this experience or know someone who has had their jewelry damaged but not melted because it was in a fire, I'm going to tell you how to save it and make it look new.
I can't give you a photo demonstration because our home burned 20 years ago, but the photo above is a few of my pieces I saved.
Just a couple of days before our fire, we had gone out of town. All my gold pieces I had packed in a plastic jewelry box for traveling. Other than loosing them, nothing could have been worse. My Son found this big chunk of melted plastic and jewelry.
Off and on for a year I would get the mess out and pry my jewelry of the chunk of plastic. It was still coated with black thick film of plastic and gunk. I placed it in a safe place and a couple of years after the fire I saw a commercial, I don't even remember what it was for, but they were offering a free booklet how to clean old gold with oven cleaner.
A light bulb went off in my head.....oven cleaner cleans really burnt on crud off the oven. I had nothing to loose by giving the oven cleaner a try.
Figuring out how to, was risky and frightening, but it paid off.
1) I lined a cookie sheet with aluminum foil.
2) placed the jewels on the cookie sheet and baked it until it was hot to the touch (350 degrees)
3) Took them out of the oven when they got hot to the touch. Immediately sprayed them with the oven cleaner.
What was happening was a miracle ! I rinsed them good with water and repeated the process( changing the aluminum foil each time) until all the melted plastic and gunk was gone !
My jewelry looked as if nothing had ever happened and new again.
Here is the link to the webpage:
glenda World How to Clean Jewelry That Has Been Through House Fire or...
Mar 26, 2015 | Clothing Accessories
I HAVE A SUZUKI SIDEKICK TRY STARTING CAR WANTS TO START PLENTY OF CHARGE WANTS TO START WHAT CAN BE PROBLEM PLEASE HELP
Any codes set? If not, check for spark at plugs. If none, could be coil/module, cam/crank sensor but last two usually set code. May be worth reading codes even if no check engine light on. Parts stores can often test modules for free.
Feb 09, 2015 | 1994 Suzuki Sidekick
Mar 26, 2013 | Computers & Internet
The dishwasher runs on both the "regular" and
Hello, Welcome to FixYa. Your dishwasher is suffering from the same thing thousands of Bosch built machines have suffered from. I'm presently on my iphone so I can't post my normal solution to this, but I can share the address which will take you there if you copy&paste the address below. Although it refers to a "SHU66" series, all the same info pertains to yours. Good luck, let me know if I can help further. Regards, Macmarkus :) http://www.fixya.com/support/t7445895-turn_off_dw
Jan 07, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher has been flooding my floor off and on for months. Repairman coming Mon but now it will not run. Timer started at 90 minutes, went to 88 minutes and froze. No water went in, nothing. I HATE this...
Hi
Thanks for using FixYa. To start with you can open the lower front panel of the dishwasher and check the hoses as water under the dishwasher may be originating from a leaky hose or loose hose connection. Other things that should be checked are door gasket, drain hoses and/or main tub seal. Also check the pump seal and if the dishwasher is too old then its really time for a new one. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 22, 2010 | Bosch Dishwashers
No power to dishwasher
Start by checking for loose or melted wires under the dishwasher underneath in the "junction box". if the wires arent melted and the plice is ok. then you may need to look for the thermal fuse by the control board. make sure your breaker isnt tripped. go and turn it all the way off then back on.
Nov 28, 2008 | Dishwashers
How can I take pictures of something small and detailed, like jewelry
Try using the mode that shows the icon of the flower, it is for close-ups. Also try using bright desk lamps to illuminate the jewelry well enough so that a flash is not needed. if you can, set up a white box or white posterboard to bounce light around, this too will help. Placing the camera on a tripod or something to steady it while shooting will help as well.
May 15, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Dishwashers Logo
Top Dishwashers Experts
