Question about Microwave Ovens
Microwave wont come on but there is power to the plug.
  • Microwave Ovens Master
  • 9,098 Answers
This would require a few simple checks which I can walk you through.
You can e-mail me at pupista@gmail.com and include your full model number and FCC ID number from the tag in the cooking cavity.
I'll be happy to help you.
Posted on Dec 31, 2016
Samsung Over-The-Range Microwave Oven just went out, wont come on at all.
Hello Terrell,
If "wont come on at all" means no light when door is open, no clock, nothing, then assume complete loss of power to that circuit.
These are often powered by an isolated circuit with its own breaker. The first place to look is your power distribution panel and see if you can find a tripped breaker.
If yes, then reset the breaker and see if the microwave has lights, clock, etc.
If no breakers are tripped, the actual microwave plug is often in a cabinet above the microwave. Sometimes, these may get pulled out while moving items in and out of the cabinet, so check that too.
If unsuccessful, microwaves also include an internal line and/or thermal fuse which fail due to overloading. Also, the control panel can go bad or become unplugged from slamming the door, etc.
If you do have lights, clock etc., then a faulty door latch will prevent operation of the microwave generator.
Unfortunately, will need additional information to properly identify the potential.
I hope this helps.
Jan 10, 2018 | Samsung Microwave Ovens
I have a Whirlpool Gold Accubake System Microwave. I have no power to the microwave. The outlet it is plugged into have power running to it and the circut breaker is good and only runs to the microwave...
Most likely the power supply has to be replaced; but it could be the safety switch too. Do you have any experience or knowledge in using meters and troubleshooting electronics? If not and you want to repair the microwave- send it out to a qualified/ certified microwave repair shop. Or else buy a new one. Best regards ~
Mar 13, 2014 | Whirlpool GT4175SPS Stainless Steel 1200...
Model 85610 shut off and won't turn back on
  • Magnetron failure
  • Door interlock failure
  • Control board failure
  • Internal fuse failure
Jul 22, 2017 | Kenmore Microwave Ovens
Beeper wont shut off
Remove the power plug and Allow the voltage present on the board to drain OFF. After an hour please recheck and if the beep still stays there is fault in the motherboard. Possible that the beeper driver is short and is continuous. If all the other functions are working without any issues, all you can do is to cut off the beeper connection if you are able to remove the board and snip off . Attempt with power plug removed .
Nov 06, 2011 | GE JVM1850 1000 Watts Microwave Oven
Light is burned out and turntable wont turn with glass on...should i replace it or should i get it fixed...built in unit above jennaire wall oven
open the bottom you can see the motor and with volt meter check if it get power , if it does get power but wont turn its the motor and it coast 30-60$, it might be the plug that got disconect.
but if you dont get power to the motor wile runing the unit then the problem is the main board and it is not worth to fix it coast more then 1/2 of your unit.
Jan 19, 2011 | Jenn-Air JMC7000 Microwave Oven
Do my microwave havea fuse because it wont turn
Yes, there is usually a 2 amp fuse located on the inside near the where the electrical cord feeds into the power supply. There might also be another fuse as well, be sure to check all around the power supply to be sure that there is only one fuse.
Plugging your microwave into an extension cord that is not rated for its use, or plugging the microwave into an un-grounded electrical socket could cause that fuse to blow.
I hope that this information was helpful to you in any way.
Apr 27, 2010 | Sharp R306L 1100 Watts Microwave Oven
Went to use my microwave and it wouldnt work. so i got another one and plugged it in to the same outlet and now that on wont work!
I wonder if your Circuit breaker or Fuse has blown on that outlet, please check that. Try the microwave in another Power point to prove.
Jan 25, 2010 | Kenmore 63252 Microwave Oven
Kenmore built in microwave displaying "D" and wont heat.
"d" may mean demo mode. The first thing to try is a "hard reset". Unplug it from the power outlet for 10 minutes, plug it back in, set the clock, then try again.
Jun 06, 2009 | Kenmore 62622 Microwave Oven
Small fire n microwave
check mains supply at control circuit, and check all the high voltage circuit diode and condencers and magnetron.
Dec 20, 2007 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
