Question about Kyocera Office Equipment & Supplies
My kyocera taskalfa 1800 asking me to call service C6000. How can fix this error
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 194 Answers
1087 1087 163 reset or fuser is bad
Posted on May 04, 2017
  • 40 Answers
SOURCE: Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Posted on Jan 12, 2009
SOURCE: Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
Posted on May 26, 2009
SOURCE: i also need a service
call service c3100
Posted on Nov 09, 2010
shawn38
  • 200 Answers
SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Posted on Mar 02, 2011
SOURCE: Free service manual with code
To reset -
C-TECH INFOWAYS
Posted on Nov 19, 2011
My kyocera TASKalfa ask me to call service C6000 what to do?
need new fuser then you have to clear the error by 1087 1087 163 start
Apr 18, 2017 | Kyocera Office Equipment & Supplies
Kyocera taskalfa 1800 call service c7900
Kyocera-Mita TASKalfa 1800 Error Code: 7900DescriptionDrum EEPROM error
No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively.
CausesDR PWB. Main/Engine PWB.
http://printcopy.info/?l=en&mod=erc&brand=Kyocera-Mita&model=TASKalfa 1800&code=7900
Aug 08, 2016 | Kyocera Office Equipment & Supplies
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
It is fuser error try resetting it by running mode 163, otherwise replace the fuser unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Feb 26, 2016 | Copystar Kyocera Taskalfa 181 Copier
1087 1087 then 163 reset it may prompt to turn off and on again,
if that does not reset copier replace the fuser assy
Mar 03, 2015 | Kyocera Office Equipment & Supplies
C6000
http://fix-your-printer.blogspot.com/2012/05/solving-error-c6000-on-kyocera-mita.html see this
Feb 17, 2013 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
On the display it says call service c6000 and how to correct this error massage?
Hi
Error C6000 means Broken fixing heater wire. In fixing warm-up, the time to reach
50°C/122 °F exceeds 13.5 s, the time to reach 100°C/212 °F exceeds 10 s, the time to reach the primary stabilization exceeds 10 s or the time to reach the secondary stabilization exceeds 24 s. To resolve this try this reset procedure--
Turn off the copier by opening the top toner cover. Turn copier on, when you see message "close top cover" press "system menu" button. Scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time. Now scroll down to "maint mode", press "enter" then enter 163 press" enter " turn off copier then turn back on.
If this doesn't resolve your issue then you'll need to check whether heater M or S is installed correctly. If it is installed correctly then make sure that the heater M or S wire is not broken. Hope this helps...
Daniel
Oct 09, 2010 | Kyocera Office Equipment & Supplies
122 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
