Question about Refrigerators
How long does it take for the fridge to get to the right temperature after turning it on for the first time?
How do i set temperature
Most fridges have only a plastic dial located somewhere in the rear of the food space inside the fridge that simply says "cooler" or "warmer" Turn this dial to change the temperature. If you want to know what the temperature is you will have to put a thermometer inside the fridge for a few minutes , open the door, and quick read the temp before the thermometer warms up. I keep a cheap thermometer with a large dial with a red indicator inside my freezer all the time and that way I can see how cold it is every time I open the freezer.
Oct 30, 2014 | Freezers
Beko CDA751FW/1 mostly on all the time - fridge 4 degC, freezer -30degC
there is no thermostat in cda751fw/1. apparently the pcb controls fridge temperature. which pcb, the main one or the one behind the temp dial I dont know which.
Apr 11, 2012 | Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Hi, my admiral side by side fridge is having problems. The freezer is working fine but the fridge is not cooling. I noticed 2 days ago that the temperature indicator for fridge was bleeping at 4 degrees. I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
How do you lower the temperture in the refrigerator?
Letting perishables such as milk and eggs get warm doesn't just effect the taste; it can also allow bacteria to grow. It's essential to guard against this by adjusting your refrigerator temperature when necessary. Read below for how to do it.
1 Measure the temperature of you refrigerator. To measure the temperature in a fridge without a thermostat, just place a normal thermometer in a glass of water and place it inside the fridge. Check back 5 to 8 hours later to see what temperature the water is. This allows you to determine the temperature indirectly.
  • 2 Adjust the temperature. Once you've identified your refrigerator's temperature, it's time to change the settings. Turn the indicator to the left to make the temperature warmer, and to the right to make your refrigerator colder. It is important to only change the temperature gauge by one setting, regardless of how much you think it must be adjusted. This prevents freezing or thawing of food by making the change gradually.
  • 3 Check the temperature again after 6 to 8 hours. If it's the temperature you want, you're set. If not, move the dial one setting colder or warmer, depending on your needs. The ideal temperature for a refrigerator is 40 degrees. Wait at least 24 hours in between each adjustment to allow the fridge time to achieve that temperature.
  • 4 Prepare for changing seasons. Where you live can have a big influence on your fridge's temperatures. You may need to adjust the temperature lower in the summer and higher in the winter to maintain a constant 40 degrees. Those who live in moderate climates can worry less about weather effecting their refrigerator's temperature.
  • 5 Check the air vents. If you're having trouble achieving the right temperature, even after numerous adjustments, make sure the vents on the inside of the fridge aren't covered. This can prevent air flow, making it impossible to cool the refrigerator
  • Hope this would help you.
    Have a nice day!
    Jun 23, 2011 | Kenmore Refrigerators
    Fridge freezer kept in cold garage. Freezer works from time to time but fridge stopped work. Could it be a thermostat problem or due to temperature of garage?
    The problem is with the garage temperature. The temperature sensor for the refrigerator is in the fridge compartment, but the evap coils are in the freezer. Refrigerators were designed to work in an air conditioned space. When they are put into unheated spaces, it does not work well. The fridge thermostat typically is set to 40 deg F. If the outside temperature is close to that, then it does not turn on the compressor as much so the freezer will have a hard time staying below freezing.
    There are garage refrigerator kits for people who put fridges in un heated garages in the winter. They just simple electric heaters that warm the fridge's thermostat to cause the compressor to run more often. This helps the fridge to maintain temperatures better in the freezer compartment. The same thing can be accomplished by putting a small wattage bulb in the refrigerator compartment. Just remember to remove it during the warm weather otherwise you will pay a large electricity bill in the summer months.
    Dec 09, 2010 | Smeg FAB46X Top Freezer Refrigerator
    Temperature setting
    The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
    Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
    Electrolux frost free fridge freezer
    i have the same fridge freezer and the same problem and have no manual can any 1 explain thank you
    Mar 31, 2009 | Electrolux Refrigerators
    Refrigerators Logo
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
