Question about Sanyo Televison & Video
I can't get any atv or dtv channels on my Sanyo led tv tv in Australia. I've tried tuning too. Please help
  • Sanyo Master
  • 10,137 Answers
Download an app on your phone called DTV Antennas. It will show you the locations of the antennas and in what direction so you can accurately aim your antenna.
Posted on Feb 04, 2017
SOURCE: When in Antenna mode (DTV from the Aerial) some channels do not tune in....
I found I needed at least 80 percent.
Posted on Apr 30, 2008
SOURCE: Can't tune in my Samsung DTV channels
WDDW
Posted on Nov 17, 2008
SOURCE: how to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Posted on Jan 30, 2009
  • 273 Answers
SOURCE: unable to tune in my LG Electronics TV (model 37LC2d-ec) to receive digital channels. Bought in UK, now living in Australia.
use a scart lead connected between your digital receiver to your tv
Posted on Jun 03, 2009
SOURCE: Unable to tune my LG Electronics Digital TV (Model 37LC2d-ec) to receive digital channels (have tried auto and manual program). TV will only receive basic standard channels. TV bought in Uk - now livi
My LG plasma TV 50pc3d when power-on only see vertical bars. what 's going on. please help. Thank you
Posted on Jul 22, 2009
How do I go back to Digital add on search when my boyfriend scanned for the analog channels. Sanyo TV model # dp42545
Usually you have to go to chanel setup and scroll down to DTV setup up or DTV auto tuning and click on the remotes enter button and choose to scan for the Digital channels (DTV) Then tell your boyfriend that they don't broadcast in analogue anymore.
May 09, 2015 | Sanyo Televison & Video
Lg 26lh2000 wont auto retune, help please.
There is the digital tuner (DTV) and the analogue tuner (TV). Make sure you are tuning the digital side as there are no longer any analogue TV broadcasts in the UK.
Sep 04, 2014 | LG 26LH2000 26 in. HDTV LED TV
Why can I only tune in one channel
Tuner fault. Check and replace it. Do a reset to this TV first, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 07, 2017 | Televison & Video
We just bought a Sanyo LED tv and channel ten is not found when auto tune is done someone please help!! :)
Test the signal strength using analogue tv mode and teletext page 284. If this shows no issue open up the TV tuning menu and use 'Manual Tume' until the missing channel shows on the screen and then Save.
Apr 03, 2012 | Sanyo Televison & Video
Sanyo Plasma DTV turns it self on
No solution sorry but i have a problem too... I usually watch my tv on "dtv" now it just went black no channel is working it automatically went to "ATV" where the channels are fuzzy and my extra channels aren't working. I tried scanning on "DTV" for all the channels but automatically scanned and defaulted back to "ATV". Does anyone know how to fix this?
Mar 26, 2010 | Sanyo Televison & Video
Tv wont pick up channels
Have you been into scanning settings and set to DTV , it seems like you are either on ATV or have a bad Antenna connection. If signal is weak from your Antenna you can add a booster in the section between your wall socket and the TV. You cannot use Satellite dish connections to receive either ATV or DTV signals without a set top box ...
Dec 05, 2017 | Coby TF-TV1901 19 in. LCD Television
LCD-32 TV.Can not tune in channel 7
81CM HD Sanyo LCD: Was still under warranty, took it recommended repair man and he simply tuned it at his shop!. Perfect when I connected it at home...Bob Tape
Jul 29, 2009 | Sanyo Televison & Video
Can not change channel on my Sanyo LCD TV
I have not solved it but, when I play the dvd player it seems to make everything else work....
Feb 14, 2009 | Sanyo Televison & Video
Televison & Video Logo
43 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
