Question about Health & Beauty
I have a tanning bed that has L14-20P and i was wondering if i can take that off and put on a 14-30P to plug into my dryer outlet
The L14-20P does say that it is a 30AMP PLUG. THE TANNING BED HAD A 14 AMP STICKER ON THE CANOPY PART OF IT. BUT IM GUESSING THE BED PART YOU LAY ON IS 14 AMPS AS WELL . AM I LOOKING AT SOMETHING DANGEROUS OR FRYING THE BED OR AM I ALL GOOD
Gophering
  • 187 Answers
SOURCE: i need a manual for a sunual 3200 tanning bed ,i
Try this link...
www.freemanualsonline.com
Kind regards!
Posted on Sep 13, 2011
  • 3 Answers
SOURCE: i started using Betrayal tanning
Betray is a tingle lotion!!! It is supposed to burn and make you itch for a few hours after use. I love tingles :) If you have never used one before than it burns like heck, giving you a sunburned lobster look but then that turns to a nice brown the next day. The ingredient that causes this feeling is Benzyl Nicotinate. It works by bringing more oxygen to the skin. You could try a "warming" lotion such as DS Obsidian(a litle pricy), it works well and you barely feel the warming, another few warming/blushing lotion I like i are DS Rue La, AG Raydiant, Ds Steamy Confessions, Ed Hard Faux Sizzle, AG First Blush and AG Puppy Love.
You could always mix your Betrayal with another accelerator or maximizer lotion to tone down the heat. I love mixing lotions:)
One last thing try not to shower for a few hours == Water tends to re-activate the tingle ingredient. It will make it twice as hot.
I hope this helps.
Good luck & happy tanning:)
Sara Beth
Posted on Jun 19, 2013
  • 51587 Answers
SOURCE: My tanning bed won't come on. Tanned last night and went to turn timer on and nothing happens. I have Checked the 220 outlet and it Is fine and all connections are Good. Help
sorry but wife won't let me
Posted on Mar 17, 2015
rjones12
  • 34 Answers
SOURCE: Accidentally plugged a 110 tanning bed into a 220 outlet. What may be damaged?
prob. just burned out the first 4-6 of the ballasts....
Posted on Apr 27, 2015
Testimonial: "Thank you for the info. Will check the ballasts."
  • 51587 Answers
SOURCE: tanning bed stopped working when i dropped one of the fan wires it hit metal and bed shut down checked breaker and thats good wondering if maybe theres a fuse in the bed
Maybe there is google make and model
Posted on Apr 30, 2015
What kind of extension cord can I use on my sunquest 24 series tanning bed. I have 220 in my house but no way of getting my bed close to plug
you hire an electrician to put an outlet close to where you need it . no extension cord is suitable for this purpose .
Apr 23, 2016 | Electrical Supplies
Why does my tanning bed keep blowing fuses
Check the tanning bed for how much electricity it is supposed to use. In the US, most outlets are 15 amp, and if your tanning bed uses more than that, it will blow fuses.
Mar 19, 2016 | Health & Beauty
Actually the lights them selves might be damaged or the ballasts that start them. I do not know how you can test them. But if you look at the ends and they are black that is not a good sign. if they are the same shade from end to end thats good, the next thing might be the ballast's or starters. I do not expect you to have starters but they would be cheaper and easier to change if you did. To find the ballasts you would need to disassemble the bed. they would most likely be located between the lights and might power two four or eight lights each. and be connected to many wires. all leading to the lights at each end and the power supply. unplug the bed before you start they will be heavy and usually black color does not matter but they will be heavy. unless they are starters.
Sep 14, 2014 | Wolff Sunquest 14SE Tanning Bed
Need manual for a sun quest tanning bed super 32 xl?
http://www.tanning-bed-parts.com/files.php?cat_id=3
Jul 19, 2014 | Wolff Sunquest 16se Tanning Bed
How can I wire a 110 outlet to a 220 outlet?
If the bed is a 220 volt, you can only use a 220 volt outlet.
If the bed is 110/220 you should check the web for specs and wireing.
May 31, 2014 | Health & Beauty
I have a 4 prong tanning bed 220v and my appliance outlet at home only accepts the 3 prong plus such as the ones you see on a dryer. How can i get this converted to a 3 prong so that i can plug it in? Or...
It is because you tanning bed requires L1 and L2 (240V) and a seperate neutral, and a ground. You need an electrician to install a proper outlet. A dryer (years ago) was installed without a neautral. However per NEC electrical code even new dryers have to have 4 wires. Do not attempt to use on 3 wires !
Oct 02, 2013 | Coleman Powermate Premium Plus 6250W...
240 v should work right?
no, voltage is not the issue, what is the amperage you need. If you need more than you have, then you could have 2000 volts and it will not work. Also your taking AC to AC, or DC to DC. There's a big difference in what you need for each.
look up Ohms law for for the calculations needed for voltage vs amperage using one socket.
good luck
Apr 30, 2013 | Health & Beauty
Fues keeps blowing
maybe you have too many things plugged into the same outlet section. Try spreading out the plugs to different outlets (maybe buy some extension cords) and see if that helps.
Feb 23, 2013 | Health & Beauty
Are tanning beds safer than tanning in the sun?
Although tanning beds are more controlled than tanning outside in the sun, ultimately all exposure to UV rays is potentially dangerous to the skin and can put you at risk of skin cancer and premature aging. For a safer way of tanning - look for sunless tanning products rather than using tanning beds or laying on the beach for hours.
Feb 18, 2013 | Health & Beauty
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
