Question about PRINTER Office Equipment & Supplies
Haven't received help on my copy printer with error code.P-96-972
  • PRINTER Master
  • 19,110 Answers
Thread Riso RZ 220UI Code 96 569
Exchanged drum pcb and rf. problem resolved.
Posted on Dec 29, 2016
Receiver error message code 232 what is this message
We need a bit more information. What manufacturer and model of printer or copier are you using? Also, are there any letter before the error code number? Prior to the error message what were you trying to do? pint? copy? scan?
Printer Repair Service in Miami and Fort Lauderdale FL
Jan 15, 2016 | Office Equipment & Supplies
I have a HP C5180, receiving error message 0xc18a0206 Ink System Has Failed. I have replaced all cartridges, unplugged power supply and USB cable for reset and am still receiving error message. Help! ...
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Mar 09, 2011 | HP Photosmart C5180 All-In-One InkJet...
Error Code: 39,003.40:133671 Yesterday the copier/scanner would not work. I shut the printer down and restarted it and received the above error code. I shut the printer down again and restarted it and...
this is a scanner problem that can be associated with the scanner lock under the scanner bed. make sure the lock is in the 'unlocked' position. it is easy to move this when lifting the scanner bed to reload the ink blocks. if this does not solve the problem you may have to replace the scanner assembly. hope this helps.
Aug 19, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Receiving error code 6A00, and alarm light is
That error says the purge unit is broken. You will need to have the purge assembly replaced.
It's # QM2-3032-000 but a shop should replace it for you.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a Ink System Failure.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Wait two minutes.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Error 0xc19a0031 Ink system failure what do I do? HELP!! Jude
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 11, 2008 | HP Office Equipment & Supplies
Ink system has failed
Solution
Wait two minutes.
Jul 18, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart d7368
Solution
Wait two minutes.
Jul 16, 2008 | HP Photosmart 3210 Printer
Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
Apr 23, 2008 | Konica Minolta bizhub C450P Laser Printer
26 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Roger Knight
Roger Knight
Level 1 Expert
R Daniel Wolfe
 Andrew Henderson
Andrew Henderson
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
