Question about Samsung Televison & Video
I have a Toshiba TV that only has HDMI input. I have the Samsung R-120 recorder that only has RGB and RCA output. Can I hook it up to the TV with RCA to HDMI cable or will I need more that that?
  • Samsung Master
  • 6,694 Answers
Try to by an RGB to HDMI converter . It will be available in all electronic spare part shop.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Dec 29, 2016
Problem? * The signal from componenant input,RGB,@ 1080i + 720p,doesn't work at all when outputting at component output or HDMI. 100% failure.
you cant record an hd picture and sound through component input rgb,for 1 you arent inputting hd,you are inputting analog,you cant up convert,
Apr 16, 2015 | Televison & Video
How do I find a video to hook up my Samsung TV? Model BN68-04027A-03 The TV was a Xmas gift and did find a video and now I can't find it Tx. Wanda
The English owner's manual for the part number listed is available at...
http://www.manualslib.com/manual/146620/Samsung-Bn68-01171b-03.html#manual
Page six (6) indicates the back panel of your Plasma TV has two HDMI inputs, one component (RGB) and a specialized AV input/output connector. The latter requires a cable that is popular in Europe. Adapters to use it with US standard S-Video and RCA composite video are difficult to locate.
HDMI and component cables are available at big box stores (Best Buy, WalMart etch) but are much cheaper from generic internet sellers.
I am not sure about the second half of your question concerning "get to channel 3 to get to all other channels).
I must assume you have told the TV to "scan" for other channels (cable or over the air (OTA) with the black antenna/RF cable connected directly to the back of the TV.
If you have done so I am guessing you have connected the antenna cable first to a RECORDER or CABLE BOX. In many cases, these will only output channel 3 or 4 and block all other channels when turned on. In order to see other channels, you will need to buy a 2-way RF splitter so that both the recorder or Cable box can be connected at the antenna cable at the same time. Please note, doing so will mean you cannot see the output of the recorder or cable box on channel 3 or 4 but must use its the video/audio (HDMI, component, composite, S-Video) outputs from it to the TV. Again, this splitter is available from big box stores or the internet.
Jan 05, 2015 | Samsung Televison & Video
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
I have a Samsung LCD TV model #LN46B301FUZA, a dish VIP622DVR a pioneer VSX-D307 reciever and a Pioneer DV-414 DVD player that I am trying to get hooked up. The Dish tech hooked up the TV and DVR using a...
I can't find your TV model to have a look at the manual. Normally you'd use a 3-plug RCA cable (Red, White, Yellow) to connect the audio and video outputs of the DVR to an RCA input on the TV. Then, hoping you have RCA OUTPUTS from the TV, you'd use a 2-plug RCA cable to take an Audio OUT from the TV into one of the receiver's Audio inputs (assuming you want to play TV sound through the receiver.
If you have no RCA inputs on the TV, you can get an RCA to HDMI Converter from Amazon for $10-$15 to convert the output of the DVD player from 3-plug RCA to HDMI, then put that into one of the HDMI inputs on the TV. Likewise, if you have only an OPTICAL audio output from the TV you can get a converter for that -- Optical audio to RCA stereo -- and put that into your receiver as an input.
Jan 20, 2018 | Pioneer Computers & Internet
I tried hooking up my laptop to my 37lh20 tv. I connected the avi to the pc input and an audio cable fro the headset jack on the tv. If I put the tv input on rgb pc I get the picture but no sound and if...
Unless you hook HDMI to HDMI, you won't carry sound across the HDMI cable. If you're using a VGA to HDMI converter, you'll get the picture but no sound.
I have a feeling the headset jack on the TV is an output rather than an input. Most TVs accept HDMI, RCA, or a digital audio input (either coaxial or optical). Unless you have a S/PDIF optical output from your laptop (and you obviously don't have an HDMI output), then your only other choice is likely to get a cable that splits a 1/8" headset type connector into two RCA plugs that you'll plug into an AUDIO IN input on your TV.
Jul 14, 2011 | LG 37LH20 37 in. LCD HDTV
I have a LG 47 inch flatscreen.i cant find any audio output plugs to hook it up to surround sound.how are you supposed to hook it up.
this is from the LG website about that TV.
- Rear,
2 x Composite video/audio input (RCA phono x 3) - Side,
2 x S-Video input (4 pin mini-DIN),
1 x USB (4 pin USB Type A),
1 x Audio line-out (RCA phono x 2),
2 x Component video input (RCA phono x 3),
2 x Audio line-in (RCA phono x 2),
1 x Digital audio output (optical) (TOSLINK),
1 x Digital audio output (coaxial) (RCA phono),
3 x HDMI input (19 pin HDMI Type A),
1 x RGB input (15 pin HD D-Sub (HD-15)),
1 x Audio line-in (Mini-phone stereo 3.5 mm),
1 x Serial (9 pin D-Sub),
1 x Remote control (Mini-phone 3.5 mm)
Mar 20, 2011 | LG 47LC7DF 47 in. LCD HDTV
I just got apple tv and don't know if I can hook it up to my gm-v42ug flatscreen tv Apple TV takes HDMI but the tv doesn't have an hdmi input that I can see. Can I hook it up? If so, how/ Thank you!
the tv has as follows. Use the bnc conectors to hook it to the RGB & R and L Audio. or reg Comp input ( Yellow ,Red White.) can get adaptors at the Shack. Inputs
Composite BNC Back Composite RCA Back Component 3 BNCs Back RGB 5 BNCs Back RGB 15-Pin Dsub Back RS232 DB-9 Dsub Back
Dec 25, 2010 | JVC GM-V42UG 42 in. Plasma EDTV
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
Televison & Video Logo
Henry  Thomas
Henry Thomas
