I have a thermablaster wall heater that hooks up to a gas line and thats it we can get the flam going for a little bit then shuts off?????
SOURCE: Natural Gas wall heater
It could be either the thermostat or thermocouple is not getting correct voltage so will intermittent turn on and off.
Posted on Jan 21, 2008
  • 3238 Answers
SOURCE: Pilot wont stay lit
A short pilot flame not playing on the thermocouple or a faulty thermocouple , loose connection at the gas where thermocouple is ,
blocked pilot flame to small , air in gas line did he purge the gas line first? other wise you will be there a long time .
Posted on Dec 16, 2008
  • 12 Answers
SOURCE: My husband ran a gas
Make sure that you are holding down the button long enough to heat up the thermocouple before you let go . The thermocouple needs to be hot enough to signal the presence of flame or the gas valve will stop sending gas to the pilot. If you are letting it get hot, but still have the same problem, the unit may have a bad thermocouple. This is the thin copper tube that goes from the gas valve to the pilot.
  • 4088 Answers
SOURCE: gas dryer flam will burn for about twenty minites
Try cleaning the air intake and exhaust vents for the burner of lint or other debris.
Posted on Aug 28, 2009
  • 2976 Answers
SOURCE: how can i split an existing gas line to hook up my
Just put a "TEE" into the line. Make sure you use "BLACK IRON" pipe fittings on gas lines. Galvanized will create problems and you will not only have leaks in the future, galvanized pipe in gas lines is a violation of almost every building code.
Posted on Nov 22, 2009
Pilot light goes out when you relase the gas controll valvue
your gas heater needs cleaning
you can do it yourself
shut gas off to heater
disconect line going to pilot
and the other end into valve
get a straw and blow into line and where it conects
also use vacuume on the end where pilot flame comes out
clean the end of thermcouple( where flame hits)
put it back together BE SURE CONECTIONS ARE TIGHT
dont want gas leaks
Oct 10, 2013 | Williams (5009622) Ceramic Gas Wall...
I am replacing ignition control unit for pool heater laars lite 2 LD325. New replacement I/G unit do not have a F/S(flame sensor) wire connection terminal what can I do the original flam sensor circuit?
sounds like you have a universal replacement go by the directions it will show you how to hook it up if you don't have instructions call jandy tech line
Aug 10, 2013 | Teledyne Laars Pool & Spa
Have a honeywell hot point gas furnance how do I bleed the lines
Never heard of bleeding them, but everything i\'ve bleed and its been alot in 60 years...anyway the way that i was taught and have seen,you go to the last movable joint on the line,loosen it a bit ....but 1st make sure theres no open flames,sparks anything of that type ..in fact if you have aluminium pipe wrench,they don,t spark....anyway after pipe is loosened things are safe all around,airy area if possible...turn on gas a little and loosen the joint a little more until you can smell gas at the loose fitting,hand tighten joint,shut off gas all in same motion,just to get it done...Then carefully tighten joint,most heater pipes are using spark proof piping anyway......your through bleeding it .But check other sites or opinions to double check if you want...
Nov 28, 2012 | Heating & Cooling
How do i get gas out of the line after i shut it off
Light the heater and burn off what is in the line will not take long .
Sep 22, 2012 | Heating & Cooling
We noticed water beginning to mist out of what appears to be the supply line (the braided line, not the copper line). That same braided line is connected to the line in the wall...and the top of the water...
If you can shut the cold water off at the water heater you should not have to turn the water off outside. Drain hot water from taps at lowest point in house, hook a hose up to boiler drain at base of WH and drain some water from here. Do as you stated and shut gas off to be safe. Change supply line.
RJ
Jan 08, 2011 | General Electric GE SmartWater Household...
Heater still lets out heat
Hi, if you can't find the pilot shut off, all wall heaters have a gas line that supplies gas to it, the main line at the unit. There should also be a gas flex line going to it. It will have a valve on it to shut gas down to the unit for the summer. This will solve your problem. You will have to look for it, as it may be hidden from site for looks and decoration. You will find it.
Sincerely,
Shastalaker7
Heating Contractor.
Please be kind when rating. Thank you, I know you will.
Jul 15, 2010 | Williams 3003622 Ceramic Wall Mounted...
How do you hook up the gas line
Is there a gas line at the installation location? If you mean where on the heater, Then please tell me why you ask? Isn't it sticking out the side or back? If not, you may have to take a panel off that should have a hole in it and install a fitting to hook the flewable gas line. Its ther and the main gas valve is or should have a open threaded hole the fitting goes into. The flex line come with the fittings.. Good Luck, Ned
Oct 06, 2009 | Desa International GWP10 Wall Mounted...
My heater will shuts off automatically
lp or natural gas sounds like moisture in the line look for a trap should look like a tee with a cap on it turn off gas and remove cap and see if any moisture in line replace cap and turn on gas check for leaks with soapy water and a small brush if not moisture it could also be air in line if so it will bleed itself out in a little while and work normally
Dec 17, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Pilot wont stay lit
Dec 16, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
