Question about Drills
SHOW me the Fusable link on BL1830 18v LITHIUM ION battery ON THE CIRCUIT BOARD
SOURCE: I lost my battery charger and i need to charge my camera battery
I lost mine too and did a search on ebay found one from hong kong that worked just fine it was cheap too! just search ebay.
Posted on Apr 10, 2009
SOURCE: i just got a hp PB360t digital camera and lithium
This recharger must be for several types of batteries, which is why it this battery seems not to fit in it. I, too, was perplexed until I looked at the icons on the recharger and the icons on the battery. When looking at the recharger with the LED on the left, place the battery in the top right corner. It just fits and will fall out if you nudge it just a bit. HTH.
Posted on Dec 12, 2009
SOURCE: Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
Posted on Dec 15, 2009
SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
i have the same problem and have returned once for replacement charger and battery, still no working well help andykrin@yahoo.com
thanks
Posted on Mar 26, 2010
  • 2527 Answers
SOURCE: Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion
You are the thrid person in the last couple of days with this same problem and i check who was posting the problems all differant people all RYOBI 18V lithium-ion batterys and they all got them for christmas. SOMETHING is not right there is now warranty on the batterys but there is one on faulty workmenship there must be a problem with this type of battery good luck
Posted on Jan 16, 2011
Does somebody have a schematic of the PCB inside of Dewalt 18v lithium ion battery. In particular, the P/N of the power transistor. Thank You
You'll have to contact Dewalt for that info--this is a reach---also I was unaware that there was a circuit board inside a 18V lithium ion batt---GL
Dec 20, 2016 | Dewalt Drills
Vupoint dv-dv1-vp camcorder needs a new battery
Buy a "np-60" battery on ebay or other store. Some will come with a charger.
You can charge the battery via the usb cable from any working usb port.
Mar 19, 2008 | VuPoint DV-DV1-VP Camcorder
18 V Ni-Cad charger repair
From what I've seen.....usually when Lithium batteries won't charge it's because they lost too much of there charge. As soon as a Lithium battery shows signs of weakness they should be charged. But to answer your question most chargers do have a fuse soldered to a circuit board so yes it's possible to be a fuse but not usually "simple".
Jan 01, 2013 | Porter Cable PCL318IDC-2 Tradesman 18V...
Can you charge a 18v lithium battery in a nicd charger?
Do not try this since the charging circuit for lithium batteries are different than nicad! Improper charging of lithum batteries can cause a fire.
Dec 06, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
How do you take apart a ryobi lithium 18v one battery
This applies to Li-ion. NiCd is probably somewhat different.
Unscrew four security screws on the bottom of the battery. If you don't have the right bit you can grind down the center pins in the screw heads and use a T15 bit.
Unscrew the hex-head screw in the center of the protruding post at the top of the battery. It may be non-standard in size but a small metric hex key wrench works if you are gentle. The four corners of the battery cover should be loose now.
There are still two plastic clips holding the top cover to the main unit near the centers of the long dimensions. Gently push a knife blade into the crack between bottom and top to release the clip on each side.
As you lift the top cover off you should push down on the contacts near the top of the post so you don't pull on the attaching wires. Eventually the contacts should pop free and the top cover detaches.
Detach the wiring harness for the status LED from the circuit board. You can now remove the combined circuit board and battery pack from the lower case.
Six screws attach the circuit board to the battery assembly, along with several solder connections, but you probably don't need to go this far. You can now test and possibly replace individual cells.
Oct 07, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Dremel Model 800, 10.8v Lithium-Ion cordless Tool voltage reg.
Read off the identity on the regulator. That is the part number to order from an electronics outlet.
Feb 24, 2018 | Dremel Saws
Vupoint camcorder battery
This camera is designed to use a rechargeable Lithium Ion battery.
(1050mAH) NP60 Lithium Ion Battery
Available from many websites, including:
http://www.nextag.com/np60-lithium-ion-battery-3.7v-1050mah/search-html
Also available from many stores including Wal-Mart, Best Buy, Circuit City, and Radio Shack
Vupoint camcorder has a dead battery
Recording/other info avail in user manual:
http://www.vupointsolutions.com/support-dv.asp
Konica Minolta Lithium-Ion Battery Recommendation (warning against the use of non-genuine or counterfeit batteries)
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100 For further assistance concerning Konica Minolta products, please contact Konica Minolta technical support by phone or Interactive Q&A or visit our website at http://www.konicaminolta.us Thank you for your understanding and cooperation in this matter. We look forward to your continued support for Konica Minolta products.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
Drills Logo
65 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
