Question about Garden
Husqvarna 227 snowblower drive cable adjustment. Only goes in reverse.
2 Suggested Answers
ssimons47
  • 12962 Answers
SOURCE: Ariens snowblower won't move changed belts,drive disk,cleaned drive plate, adjusted traction cable,still drive disk won't make contact to drive plate about 1/4 short of plate. Ariens#924109
go here http://www.snowblowerforum.com/forum/#snowblower-forums-main
and ask your question there. great website for snowblowers... tell em fixer sent ya
Posted on Mar 21, 2018
Testimonial: "Unable to go to site"
Forward or reverse will not engage - cluthch problem?
happened to me. found loose drive clutch cable. Adjustment bolt is just under the handlebar, attached to the cable. adjusting lock nut came loose and tension adjusting bolt spun out from vibration. retighten sleeve onto adjustment bolt and see if drive drive will engage. IF NOT.......look to other end of cable......UGH!
Mar 04, 2014 | Tecumseh Snowblower Snow Blower Starter...
Will not go in reverse
yes adjust the linkage so the drive wheel goes past center
of the alum drive disk
Mar 03, 2014 | Ariens Sno-Tek 28 In 2-Stage Gas Snow...
Problems shifting toro power max 726 oe snowblower
adjust the cable easy to do , get the manual or just look good at it ,
Feb 04, 2014 | Toro Power Max 726 OE Snowblower - 37771
The drive quit working on simplicity snowblower
the drive as far as to make it go forward and reverse?
may be adjustment or the belt is bad or the drive wheel is worn too far to adjust to make drive
Dec 16, 2013 | Simplicity I924E 2-Stage Snowblower...
I have a 1999 Tecumsah Lawnboy 824E 8.0hp, model 28232, snowblower. Last snow the forward and reverse stopped working. The snowblower runs but the wheels locked up. I was able to get the forward and...
Here is a link that may help,ihttp://www.partstree.com/parts/?lc=lawn_boy&mn=28232. Adjust and lube the cables for drive engagement, and the other cables and Hiem joints. This usually will rectify the problem.
Apr 16, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
I have a MTD 5/20 snowblower that won't engage in Forward. It will transfer to neutral and reverse, but I can't any forward power. If I tilt it forward, the wheels will spin. I installed a new belt and...
ALL SNOW BLOWERS HAVE WHAT THEY CALL A FRICTION DISC DRIVE IT SOUNDS LIKE THE FORWARD SIDE OF THE DISC IS WORN OR THEDRIVE WHEEL HAS A RUBBER DRIVE RING THAT IS WORN. IF YOU REMOVE THE BOTTOM PLATE YOU WILL SEE TWO DRIVE WHEELS ONE IS JUST A METAL DISC AND THE OTHER LOOKS THE SAME BUT HAS A REBBER RING FOR GRIPPING THE DISC TO MOVE THE BLOWER FOREWARD, WE END UP REPLACING ALL THE DRIVE DISC AND DRIVE WHEELS ON OURS EVERY SPRING THE FOREWARD DRIVE TAKES THE MOST PUNISHMENTTHERE FOR WHEARS OUT THE FASTEST. MTD HAS A WEB SITE FOR ORDERING PARTS AND ARE NOT HARD TO INSTALL.GOOD LUCK LET ME KNOW HOW IT GOES
Feb 05, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Ariens SnowBlower I recently blew a belt on my Ariens 5.5 hp snowblower Mdl# 932140 I replaced it and it blows snow and when i put it in 1st gear the machine goes into reverse. All my other gears work...
Hi dwva, I think you have the belt on properly seeing the other gears work fine. The difference between 1st and reverse can be as little as 1 half in on the drive wheel. It depends on which side of center is the friction wheel riding. Remove bottom pan with the machine in 2nd or 3rd gear notice which side of center is the friction wheel riding. (the friction wheel is the one with a rubber outer ring). Now put it in 1st, is it on the same side of center? There is an adjustment on that linkage, adjust so in 1st is on the same side of center. Happy New Year, hope that helps.
Dec 29, 2010 | Garden
I have a Husqvarna YTH20B42 and the snowblower keeps throwing the belt...what size belt do I need to order? I can't see it on the belt...Serial # 122906B002271
Its likly the belt is OK the problem is there is on idler pulley that has an adjustment so when the augers are engaged it puts force on the belt witch tightens and makes every think turn and when disengaged every stops turning. There is always an adjustment involved with this. If you can remove the belt then with the mechine not running of corse engage the drive and watch how it fucnitions then look for the adjustment that would move the idler closer or further away from the belt
Dec 16, 2010 | Husqvarna Garden
Everytime I put my car i park it goes into reverse.
It sounds like you have a damaged shifter cable.It is an adjustable cable but if it is that far out of adjustment then it is probably damaged. Replace it.
May 07, 2009 | 2000 Pontiac Firebird
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
